Feeler Gauges - Got a recommendation? |
Big Len |
Aug 30 2015, 08:28 AM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
I'm thinking the bent ones are best, but what have you found that works best and where can I buy them?
ripper911 |
Aug 30 2015, 08:31 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I've been thinking about getting the long ones.
brant |
Aug 30 2015, 09:49 AM
914 Wizard Group: Members Posts: 11,613 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Wurth for a six.
Available through distributors or BMW shops |
Katmanken |
Aug 30 2015, 11:48 AM
Buy a bent one and a straight one- they are cheap. That way you can find the one you like. I like straight ones, there have been times when the bend seems to get in the way.
stugray |
Aug 30 2015, 12:19 PM
You can also get "Go-NoGo" feeler gauges.
For setting valves at say .006. You would use the gauge that has the thick part at .007 and the thin part at .005. If the thin end "Goes" and the thick end is "NoGo", then you are at .006. They work great for setting valves (unless your valve lash is zero). So I bought a set, then changed to chromolly pushrods, so I dont have a use for them anymore :-) |
Aug 30 2015, 01:40 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bent ones fit if you remove the one you need for the valve, use that, a dime, and a wrench.
Lo-Fi Version | Time is now: 26th April 2024 - 08:31 AM |
