Teknon |
The more I learn the dumber i think I am ![]() ![]() Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains ![]() |
Where do the holes go? Ok, there are two different types of 2.0 heads out there, that I know about.
The two hole type was made towards the end of the production years and did what? Smog pump air pressure maybe, to where in the head and for what purpose? And the one hole type head was to evacuate pressure under the valve cover to allow oil to easily lubricate the valvetrain by the air being vacuumed to the air intake. Right? Has any one used either of these holes to superlube the valvetrain or other. Joe (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) |
Rhodes71/914 |
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 ![]() |
If I get your question, here is what I know...
The 75-76 heads have 2 holes on each head that go through to the exhaust valve and supposedly helped with emisions. I have these heads put they are now closed off. I'm not sure what years actually came with the head breather already there but from what I understand all the 2.0 heads at least have the boss for the breather. They got through to the rocker area from the front of the cyl 1&2 head and the back of the cyl 3&4 head. They relieve excess pressure from the heads to keep the valve cover gaskets and Orings from leaking. |
Teknon |
So basically the 75-76 heads are useless and should be plugged off, unless used in a running smog system.
But the 73-74 heads are helpful to the oiling system and should be used to relieve pressure in the head. Than this is the head when used with carbs is vented to a "puke box" Thanks Sean |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
for completeness, we should mention that there are also 2,0 Bus heads that occasionally show up on "2,0" engines. those are 2-liter engines (and heads) but they are not 914 2,0 heads. it makes a big difference... |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Super lube the valve train? Nah, tests show that the valve covers are half-filled with oil anyway! Roller rockers or needle bearinged rockers aren't needed unless you drysump maybe.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I'm just trying to learn and have no hands on experience with the 75-76 heads....
but.... about 3 weeks ago there was a thread that discussed the need to drill the pressure vent holes into the 75 style heads. now I'm really confused. I always heard that you block off the air ports on these heads, but then 3 weeks ago thought that you had to drill additional holes... Now I'm hearing that the late heads already have 2 holes in each head. what gives? is it that some do and some don't? |
ArtechnikA |
they're talking about two completely different things. Thing One: air pump cars pump air into the exhaust ports. it's an emissions thing. if you don't have an air pump, you have to plug the holes into the exhaust ports that you aren't pumping air into. Thing Two: most cars work better if the rocker arm area of the head is vented. i don't kow much about the specifics of what cars have vent ports in the heads and which don't, and why the ones that don't didn't. but it is these vent holes into the rocker arm ("valve cover") area of the head that people are talking about adding. Zat help ? |
brant |
Ok... maybe I got it. (1st to admit that I'm slow at times)
so on the late head that has 2 holes.. both of them are related to the air pump/emissions and no crank case venting exists? thus you plug 2 holes (not 1 like I previously thought) and then drill yet a 3rd hole? is that right? thanks for helping my coffee-lacking self understand this! TIA |
914ghost |
BOB ![]() ![]() Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 ![]() |
Yeah, the 76' style would have a hole for each cylinder and its piped directly into the exhaust port. Those are the hols you NEED to plug.
Then, (maybe) the 76' style has no hole to the actual valve cover area. This is the hole you would drill to "vent" to your breather box. One in each head or maybe better- just vent the valve cover. clear as an unmuddied lake! Do early and late 2.0 have all the same valve sizes? I assume so and the power difference comes from the smog system. (sorry to hijack the thread) Bob O |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Correct...the extra holes were to inject air into the exhaust stream to lower emissions. For normal use, you can have the heliarced up (from the inside of the port) or simply plugged with a pipe plug or bolt.
The "third" hole you are talking about is to do nothing but vent the rocker box. The internal pressure of an engine (due to blowby, etc) is vented to the atmosphere or plumbed to air cleaner. This saves seals and makes the engine run better. Even the smog heads have the "boss" for the venting of the rocker box. Merely drill a hole in it, tap it with the appropriate size pipe thread tap and screw in a 3/8" or so hose barb. Run the hoses to a "T" and then to the air cleaner or to a "catch tank". Oh, and if you think spraying oil, downstream of the valve, is going to "superlube the valve stems and guides", all you will do is create a very noxious cloud of oil smoke behind you(more so than the normal 914). |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I just did this. 1/4 NPT to 1/2 barbed fitting. Scary but fairly easy. I have a butt load of extra fittings if anybody needs them.
newto914s |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 ![]() |
What if you have 76 2 liter heads with no smog equipment and you don't plug the emision holes in the head. Will the car A. not run, B. run worse, or C. run better?
Thanks Samson |
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
you need to plug those holes. otherwise, you have a combustion leak. the car may run (mine ran when one came out), but not well, and it'll sound like a racket. ask me how i know... |
Teknon |
I see the spot that has to be drilled like the older head. I’m gunna have that done. The non-drilled ones just got back from Rimco. $650, missing a stud and never mentioned to me it would be better to drill them out. They don't even have email or at least never answer it. No more business with them. Attached image(s) ![]() |
Teknon |
And the one to be tapped
Lo-Fi Version | Time is now: 26th June 2024 - 06:53 AM |
