FS 2056, Decided to go a different route with the car |
tscrihfield |
Sep 3 2015, 07:59 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
So, I have decided to go a different route with the car and I need to prep for a move in the hopefully soon future...
You can see the details and images in the 4th page of my build thread in my signature. Engine was built on a budget but by far a "cheap" one. DRD built 74' 3 bolt heads, GA case -lined up by local reputable shop along with Crank inspected and polished, AA I beam rods, Web Cam & lifters, Dual Italian Webers... Fat shroud and 11 blade 911 fan. Engine will come with a 4-2-1 European style stub piped header w/ supertrapp I think it resembles what CFR sells, but I don't know who the mfg is. Would like to get $4K but would accept reasonable offers. I can promise you, you couldn't build one for this price. This engine has less than an hour of run time. Was run long enough to break in the cam and tune the carb... I thought the car would be done before now... (IMG:style_emoticons/default/blink.gif) |
tscrihfield |
Sep 11 2015, 09:06 AM
Figured I post the common asked questions so far
What HP does it make? Engine has not been on a dyno but estimated 130@crank estimated from DRD who also spec'd out the valve train. Any leaks? Not at this time, though during initial fire up, I had a small leak where I didn't tighten down on a crush washer quite enough. Have the valves been adjusted since initial run? Yes, I adjusted them after cam break in and checked them before installing the engine in the car. Spare cork gasket sets go with the engine for future valve adjustments since I have them. Oil cooling? Remote mounted, thermostatically controlled. You can mount it on the engine crossbar or on the firewall since you don't have the front shroud there. Ignition is a Pertronix flame thrower |
euro911 |
Sep 11 2015, 01:11 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
It sounds like a really good deal. If I weren't trying to reduce the amount of 'stuff' I already have, I'd be all over this.
tscrihfield |
Sep 11 2015, 08:36 PM
tscrihfield |
Sep 16 2015, 07:55 AM
mbseto |
Sep 18 2015, 12:37 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Hey, can you tell me a little about the custom diz... If I understand your build thread, it is a regular diz, just with a sensor added for the EFI system your were planning to use. Is that right? Was it running stock EFI when you broke it in? And would an off-the-shelf diz work on this?
tscrihfield |
Sep 18 2015, 01:51 PM
Hey, can you tell me a little about the custom diz... If I understand your build thread, it is a regular diz, just with a sensor added for the EFI system your were planning to use. Is that right? Was it running stock EFI when you broke it in? And would an off-the-shelf diz work on this? Sorry about the confusion. This engine is running on Carbs with a new Pertronix Flame thrower dizzy on it. I have the custom dizzy on a different engine right now along with a SDS injection setup. I never got far enough with the MegaSquirt to put it on this engine. The engine comes with everything needed to run, minus the oil cooler. I kept the cooler mounted in the car. Thanks, Thomas |
tscrihfield |
Sep 28 2015, 09:03 PM
$3500 buyer pays shipping or delivery cost. I will deliver to reasonably close locations. |
tscrihfield |
Oct 6 2015, 01:47 PM
euro911 |
Oct 6 2015, 03:36 PM
I can't believe this motor hasn't been snatched up yet (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif)
(IMG:style_emoticons/default/screwy.gif) |
JeffBowlsby |
Oct 6 2015, 08:36 PM
914 Wiring Harnesses Group: Members Posts: 8,480 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You never responded to my PM/email. Would like to know more. |
tscrihfield |
Oct 7 2015, 06:56 AM
You never responded to my PM/email. Would like to know more. Jeff, I apologize, I honestly have not received a message from you on here. You will have a PM in just a minute. Thomas |
tscrihfield |
Oct 7 2015, 06:58 AM
I can't believe this motor hasn't been snatched up yet (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/screwy.gif) Im Quite surprised as well, as cheap as I am offering it... The heads alone are worth well over $1,000... Lots of tire kickers... No one willing to pull the trigger yet. Thomas |
Kalani |
Oct 7 2015, 03:24 PM
Newbie Group: Members Posts: 3 Joined: 12-July 15 From: yorba linda CA Member No.: 18,950 Region Association: None |
Sorry, im a bit new to the site , hoe do I get to your build thread to view this motor
So, I have decided to go a different route with the car and I need to prep for a move in the hopefully soon future... You can see the details and images in the 4th page of my build thread in my signature. Engine was built on a budget but by far a "cheap" one. DRD built 74' 3 bolt heads, GA case -lined up by local reputable shop along with Crank inspected and polished, AA I beam rods, Web Cam & lifters, Dual Italian Webers... Fat shroud and 11 blade 911 fan. Engine will come with a 4-2-1 European style stub piped header w/ supertrapp I think it resembles what CFR sells, but I don't know who the mfg is. Would like to get $4K but would accept reasonable offers. I can promise you, you couldn't build one for this price. This engine has less than an hour of run time. Was run long enough to break in the cam and tune the carb... I thought the car would be done before now... (IMG:style_emoticons/default/blink.gif) |
steuspeed |
Oct 7 2015, 05:17 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Sorry, im a bit new to the site , how do I get to your build thread to view this motor
There is a link to his build thread at the bottom of his posts. |
Lo-Fi Version | Time is now: 26th April 2024 - 11:04 PM |
