MikeM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada ![]() |
Hi all...I have a 2 part question that hopefully someone can help me with.
1. It seems I can't tighten the front wheel bearings quite enough to get to the "tightness" that I want. The adjuster doesn't want to turn in any more and I don't want to force it. Is this an indication of not enough grease in the bearings? 2. I have the front wheels off the car. When I spin the hub and rotor back and forth I get a slight knock when the rotor starts and stops. I can really feel it in the strut also. Is this normal? Am I explaining this properly? It is not wheel bearing slop. Thanks, Mike |
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
Strut nut inside the cover?
Not sure on spindle nut. |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,999 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
MikeM |
Guys...I figured out my "clunk" issue. I removed the brake pads and the noise is gone.
They must move a little as the rotor starts and stops. Thanks, Mike |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Is it( the clunk) on both sides of the car ?
A galled spindle ? meaning a reduced diameter to support the races an the spindle. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Guys...I figured out my "clunk" issue. I removed the brake pads and the noise is gone. They must move a little as the rotor starts and stops. Thanks, Mike Yes this is a noise that drives some people crazy. If you drive your car forward and repeatedly press the brake, the pads dont move and dont make a noise they are hard against one side of the 'pad cavity' If you reverse and apply the brake, the first time the brakes will make a noise as the pads move to the opposite end of their "cavity". backup & stop again - no noise. Now chage dir & move forward & apply, they will make the noise again on the first press.. |
MikeM |
Thanks....still learning!!!
Lo-Fi Version | Time is now: 24th June 2024 - 11:19 PM |
