> Quick question, fuel lines, Firewall which one is which?
Mark Henry
post Sep 10 2015, 10:14 AM
that's what I do!
The lines coming out of the firewall, which one is out to the engine and which one is the return?
The one closest to the clutch tube or the one passanger side?
Unmolested car, but I'll double check at the tank later to be sure.
thanks.
ChrisFoley
post Sep 10 2015, 11:04 AM
I am Tangerine Racing
On early cars the supply is on the right,
and on late cars the return is on the left.
Mark Henry
post Sep 10 2015, 01:46 PM
that's what I do!
QUOTE(Racer Chris @ Sep 10 2015, 01:04 PM) *
Ummmmm....what? (IMG:style_emoticons/default/blink.gif)
theleschyouknow
post Sep 10 2015, 04:19 PM
QUOTE(Mark Henry @ Sep 10 2015, 02:46 PM) *
but I thought it was the other way around
on early cars the return is on the left
on late cars supply is on the right
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/biggrin.gif)
cjl
r_towle
post Sep 10 2015, 06:24 PM
Custom Member
Either....
There, now you have three answers.
Honestly, they can be switched at the tank, so that will help you decide....how the two rubber hoses are hooked up.
post Sep 10 2015, 06:30 PM
Isn't the supply on the right so it comes up the front hole after turning 90degrees w/o crossing over the return?
OU8AVW
post Sep 11 2015, 01:31 PM
Yacht Rigger
QUOTE(76-914 @ Sep 10 2015, 04:30 PM) *
The front hole is the correct hole. Don't let it slip into the back hole. That is the wrong hole. (IMG:style_emoticons/default/blink.gif)
- Lo-Fi Version Time is now: 2nd January 2025 - 02:09 PM
