jim kelly's 1975 914 suby build, water pump housing and header interference ??? |
jimkelly |
Sep 26 2015, 10:40 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i have a 1975 914 roller and a a few ej22 engines and a couple of suby 5 spd transaxles
https://www.diyautotune.com/shop/megasquirt...ed/microsquirt/ microsquirt with 8" harness $370 GM clt sensor 3/8 npt $17 GM iat sensor 3/8 npt $22 GM map sensor $75 3/8 npt tap $10 18x1.5 tap $12 18x1.5 bung for aem o2 sensor $4 AEM 30-4110 $165 Set of 6 Pcs Spark Plug Ignition Wire Lead For 2.8L VW Passat $30 VW bug Beetle golf oem 2.0 ignition coil pack assembly 032905106b $20 Subaru WRX OEM Crankshaft Timing Sprocket pn-13021AA141 $30 celica radiator 2 row - $170 (see post #2 and my v8 thread) exhaust header - $35 ebay (see post #152) (decided to go with wrx oem stock header for compactness) stainless fuel lines - $99 tangerine - 8mm supply and 8mm return stopper drive pinion - made myself http://www.914world.com/bbs2/index.php?showtopic=104513 stock 914 axles machined on one end - $150 Dutchman tires - 185x50x15 - $300+-[/b] engine cradle and trans hangars - mepstein $550 (see post #32) mr2 shifter - $35 ebay shift knob ebay $12 (see post #170) front bumper grills - $35 dflesburg stock style fuses - ebay $13 set of speed bleeders - $30 pelican brake peddle switch - $24 pelican ebrake handle assy with cable and equalizer - $56 bdstone914 lug bolts to roll car around my garage - free mark epstein set of nice complete late model doors - $150 (thanks lorin, series9, rat rod charlie) center section of fuse box - free mark epstein a front steel bumper - free mark epstein late model tach with single directional indicator - cabinetmaker $40 shipped : ) two pair front amber lens bought from 914rubber for both my cars. https://weddleindustries.com/products/1000186/1001853 - flange $50 shipped type 1 to type 2/4 starter 23300AA560 - http://www.914world.com/bbs2/index.php?showtopic=303903 /////////////////////////////////////////////////////////////////////////////////////////// looking forward to... good fuel mileage modern fuel injection modern 5spd transaxle - useable 1st gear for taking off from dead stop & in traffic light weight car big space in engine bay running some low profile 15 inch tires on 5.5" wheels - maybe 185x50x15 ////////////////////////////////////////////////////////////////////////////////////////// reference materials and links... http://www.shoptalkforums.com/viewtopic.php?t=136053 http://www.surrealmirage.com/subaru/swap/electrical.html http://legacycentral.org/ http://www.northursalia.com/modifications/...lschematics.pdf http://www.main.experiencetherave.com/subaru_manual_scans/ vanagon related links... http://subaruvanagon.com/conversion_services_Wiring.htm https://smallcar.com/vanagon/subaru-vanagon...cation-kit.html http://www.kennedyenginc.com/Pages/SubaruVanagonGen.aspx http://www.rockymountainwesty.com/v/vspfil...nstructions.pdf http://www.weidefamily.net/vanagon/HTML/05/main.html http://www.ultimatesubaru.org/forum/topic/...iring-diagrams/ http://www.numbchuxconversions.com/Files/Harness%20info.pdf http://consumerguide.com/used/1990-94-subaru-legacy/ pulling ej22 harness from subaru (Tim Seward) per tim 90 and 91 harnesses are same https://www.youtube.com/watch?v=GfQJnZBljsw be sure to watch all (busaru) segments https://www.youtube.com/watch?v=ENm6S3WkKJc Subaru engine test stand (Jeff Robenolt) https://www.youtube.com/watch?v=_IN5rfK9a_8 |
jimkelly |
Sep 29 2015, 02:30 PM
this ebay radiator was mentioned by a member. the price is right, so it may be what i will use?
update 19dec2015: I recently put one in my v8 car using a&p mech's mounting style and it is working fine. Attached thumbnail(s) |
jimkelly |
Sep 29 2015, 02:32 PM
some sensor fake output info... from tonyakavw and scott914...
Okay, so I THINK I WILL NEED TO fake/simulate the following sensors depending on which Subaru donaor car I buy.. Fuel level sender (0.12 to 4.95 volts) Fuel Temp sender (2.5 to 3.8 volts) Fuel Tank Pressure sender (2.3 to 2.7 volts) Rear O2 sensor signal (0 - 0.9 volts) Neutral position sensor (+12 in neutral, 0 when in gear) Rear O2 heater sensor signal (0-1.0 volts) Power Steering oil pressure sender (open/close) There may be one more, I'm still finalizing the wiring... Most of these wil use small 10-turn potentiometers to set the desired signal voltage, but I may end up using real metal-film resistors in the end, as they are a bit more reliable. -Tony Regardnig the sensor simulator, I won't be simulating the front O2 sensor. That is used by the ECU to run the enigne, whereas the second sensor is there just to verify the cat is working. Since I'm not going to be running a cat, I have to simulate the second sensor. that looks like you are mising a few plugs, but i cant see it all very well. dont tape it up too much you will probably have to open it up once to fix something. all the plugs i can think of are : brain 2 o2 plugs 3 for engine connection fuel pump relay main realy ignitor obd connector purge and pressure switching solinoids ( 2 plugs ) connection to relay board then loose wires are : power ground speed sensor temp sensor if you go stock then you need wires from the alt Attached image(s) |
Sep 29 2015, 04:04 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Wait, what?
Don't you have a v8? |
Smallblockbug |
Sep 29 2015, 04:31 PM
No talent hack Group: Members Posts: 39 Joined: 26-July 15 From: Yorkville NY Member No.: 19,001 Region Association: North East States |
Im pretty sure this is his other car. But yes he has a v8 car to.
jimkelly |
Sep 29 2015, 06:31 PM
i have a wife, 2 boys, and two 914s. that is about it BUT that is all i need (IMG:style_emoticons/default/smile.gif)
have we ever concluded whether or not this subaru spool ( pn - 498427100 )is a part that will work in our conversions? $134 https://subaru.service-solutions.com/Detail.aspx?id=86 vs $229 http://www.bremarauto.com/products/subaru-...conversion-kit/ vs $200 http://www.subarugears.com/Pricing/Pricing.html Attached image(s) |
Stacks914 |
Sep 30 2015, 01:48 AM
Member Group: Members Posts: 183 Joined: 1-April 15 From: Omaha, ne Member No.: 18,582 Region Association: None |
I am sorry did you mention fuel mileage??? LOL jk man looking good!!
jimkelly |
Sep 30 2015, 07:01 AM
YES, yes i did. it will be my daily driver once complete.
Sep 30 2015, 07:09 AM
YES, yes i did. it will be my daily driver once complete. Same here (IMG:style_emoticons/default/driving.gif) |
76-914 |
Sep 30 2015, 09:21 AM
When does the build start? Not a fan of acquisition threads, so much. Onward thru the Fog! (IMG:style_emoticons/default/beerchug.gif)
Sep 30 2015, 09:39 AM
When does the build start? Not a fan of acquisition threads, so much. Onward thru the Fog! (IMG:style_emoticons/default/beerchug.gif) There's a lot of stuff to acquire before the build. |
76-914 |
Sep 30 2015, 04:00 PM
When does the build start? Not a fan of acquisition threads, so much. Onward thru the Fog! (IMG:style_emoticons/default/beerchug.gif) There's a lot of stuff to acquire before the build. If you want to complete the build in one week, yes. Or someone that is paying a 3rd party, as in your case. JMHO |
Sep 30 2015, 05:52 PM
When does the build start? Not a fan of acquisition threads, so much. Onward thru the Fog! (IMG:style_emoticons/default/beerchug.gif) There's a lot of stuff to acquire before the build. If you want to complete the build in one week, yes. Or someone that is paying a 3rd party, as in your case. JMHO I'm going to get some help from my shop on the Suby build but I'm the one building the car. The Porsche build is getting done by scotty b. If I had the money, I would have both cars built 3rd party. I will say that for me, a non mechanic, just getting the parts together is a struggle, not a bad one and the people on this site are great and I'm having fun but for me, a lot of this stuff is pretty confusing. |
jimkelly |
Sep 30 2015, 06:53 PM
i'll try to blend ACQUISITION with ACTUAL BUILD photos and text.
my car needs some welding, but the rest will mostly be bolt in. nothing too fancy, that is for sure. super low dollar build. planning on frankenstein axles or have dutchman machine some. http://www.dutchmanaxles.com/ |
jimkelly |
Oct 1 2015, 06:33 PM
$35 ebay
actual unit as received Attached image(s) |
A&P Mech |
Oct 1 2015, 06:50 PM
Member Group: Members Posts: 400 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
All those pieces and parts look familiar. (IMG:style_emoticons/default/smile.gif) What motor are you planning on using?
mgp4591 |
Oct 1 2015, 09:06 PM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
i'll try to blend ACQUISITION with ACTUAL BUILD photos and text. my car needs some welding, but the rest will mostly be bolt in. nothing too fancy, that is for sure. super low dollar build. planning on frankenstein axles or have dutchman machine some. http://www.dutchmanaxles.com/ Do you know of anyone here or elsewhere using these axles or any idea of the cost? |
jimkelly |
Oct 2 2015, 08:52 AM
Dutchman has been recommended by bigkat_83 who is amazing resourceful and a phenominal fabricator.
as I understand it, not all conversions can use the same axle length but I have to recheck but I think bigkat had Dutchman machine stock 914 axles to work with his suby conversion. I think the cost is about $150 for the machining on one end. one end would retain the 914 cv spline, the other end would get a suby spline machined in, I believe. you (and I) need to read every suby thread, I have several listed in my signature. |
76-914 |
Oct 2 2015, 09:47 AM
Dutchman has been recommended by bigkat_83 who is amazing resourceful and a phenominal fabricator. as I understand it, not all conversions can use the same axle length but I have to recheck but I think bigkat had Dutchman machine stock 914 axles to work with his suby conversion. I think the cost is about $150 for the machining on one end. one end would retain the 914 cv spline, the other end would get a suby spline machined in, I believe. you (and I) need to read every suby thread, I have several listed in my signature. Yep, it's all covered. |
mgp4591 |
Oct 2 2015, 10:38 PM
Sweet idea for the axles- I may just send my SVX axles and have the other end reworked for heavy duty Porsche cv joint ends. Which cvs are the strongest that match up with our rear hubs once they've been modified for 5 lug?
Lo-Fi Version | Time is now: 26th April 2024 - 01:09 AM |
