JoeDees |
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None ![]() |
I'm looking at bumper hole filling in my future too, was the chrome already off of yours? Or did you remove it? If you removed it, how did you do it? Thanks.
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
This was never chromed, was steel painted black when new.
Garland |
Welded the rear fenders on, and the left front fender patch.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Getting cold in Michigan. ![]() When lining up the fenders I start at the bottom of the fender and line up the bottom edge to the same height as the stock fender. ![]() ![]() ![]() ![]() Cutting a wedge and angling out the valance mount channel. ![]() ![]() ![]() ![]() Im learning as I go. ![]() ![]() ![]() ![]() ![]() ![]() And did the right side. ![]() ![]() The left front fender patched in. ![]() ![]() ![]() Now Ill move on to the fronts and the valances as I move forward. Attached image(s) ![]() |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Did you purposefully make a notch in your front patch for your clamp?
Your work so far looks very good! |
Garland |
Garland |
i finished up the front fenders, and the 3 of the 4 valances. Lots of time with the hammer on the fenders to keep the welds flat.
Heres the fenders, and the change to the bottom before installing. ( for some of you, yes I still have and use my Mid-west cup) ![]() ![]() ![]() ![]() ![]() |
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
Nice Work!
Garland |
The side valance has to be more then bent to fit. Just bending would cause it to move down also. So I start with a cut, and a wedge.
![]() ![]() ![]() ![]() Then out come the close up lens for slightly (IMG:style_emoticons/default/shades.gif) improving my vision. ![]() ![]() Hammering the curve to reach a bit of a curve. ![]() ![]() ![]() ![]() Need to change the angle of the lip on all , due to the wedge added change. I want these to line up correctly with the fenders. ![]() ![]() |
Garland |
Done with the side's. I feel that they will work out fine, with out having to do to much fabricating. I wanted to keep it simple, with a little flare! (IMG:style_emoticons/default/lol-2.gif)
![]() ![]() ![]() ![]() I was sure to think 10 times, measure twice, and cut once. I could have cut paper templets, and built it all up first, but in the end I find you always custom fit and work each corner for a good fit. |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Nice Work, looking very good.
Garland |
Now for the rear. I have a snow plow/scoop and have all ready modified it to a duel port. So same as with the side valances, need to use a wedge shape.
The rear valance. ![]() ![]() ![]() Had to check fit to the car, many times. ![]() Clean up the first weld. ![]() And the second weld. ![]() ![]() Working the edge to fit the curve of the fender. ![]() ![]() Attached image(s) ![]() |
Garland |
And the last adjustment and fit.
![]() ![]() 3 done: Just arrived 2 weeks ago, and center caps at Christmas. ![]() ![]() ![]() Now onto the 5 lug conversion. ![]() ![]() And seeing if my calculations were correct, on these I just got mounted up. I know I should have gotten the rims and tires first, but went on with carful measuring and fitting when installing the fenders. I think I got it correct based on this. 5" 13/16s inside clearance on the factory Fuchs 6" On the Euromiester ![]() ![]() ![]() ![]() ![]() ![]() about 1/4" more on the inside. The 9" wheel, (Stock 5.5) that leaves 3 1/4 outside. Flares should add 2", Stock clearance is around 1" and I can work the lip for the last 1/4. Thats the plan…..at least for the rear. The front may require a spacer or a slight rework, to fit the also 9" rims up there. going with 9's, for the 1st time, on all 4. Happy New Year! (IMG:style_emoticons/default/driving.gif) Attached image(s) ![]() |
Garland |
Andyrew |
Great metal work there! That looks very well done!
mbseto |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,257 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States ![]() |
Nice work, looks like quick progress!
Flipczak |
Newbie ![]() Group: Members Posts: 1 Joined: 25-September 14 From: Detroit, MI Member No.: 17,953 Region Association: None ![]() |
Looks good, can't wait to see the finished product. (IMG:style_emoticons/default/biggrin.gif)
Triaddave |
Member ![]() ![]() Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 ![]() |
Hey, Nice exhaust. give me the serial number off the left flange (TW OOO) and I can give you some history on that... dave @ triad
Andyrew |
Old Yella |
Old Yella ![]() ![]() Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region ![]() |
I like how you didn't complain about the original disappointment with the car. Didn't bullshit around and just dealt with the restoration and build. Good onya.
Garland |
Hey, Nice exhaust. give me the serial number off the left flange (TW OOO) and I can give you some history on that... dave @ triad Dave, I'll have to one up you on that. I purchased this from you back around 03. As I recall you had lived in Michigan and we're coming for a visit during the dream cruise. I talk up my Traid every time, it's sound great, and it is a fantastic quality build. Not sure on the build date, but it was around 03. Thing is, don't think it will ever ware out. Any other history on this one would be appreciated. It a 2.0 used with 2.0 headers, on a 1.7 engine, fits beautiful. Thanks, John ![]() |
Lo-Fi Version | Time is now: 2nd April 2025 - 07:20 PM |
