Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
yea, get a real hole saw.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,694 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I can't bear to look.......That wood bit could snag and break the lens real easy. You might want to try a hole saw instead. Good luck. Amen, but the pilot bit will want to pull into the plastic very quickly as it is a std bit. Plastic drill bits have a very acute angle (135 degree IIRC) which keeps it from pulling thru too quickly resulting in a broken plastic piece. So yes, a hole saw is best but pre-drill the pilot hole with a bit made for plastic or recess the pilot bit enough so that it doesn't bite into the material too early. Aircraft Spruce sells these bits if you can't find them locally. (IMG:style_emoticons/default/beerchug.gif) |
Garland |
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
Darren C |
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England ![]() |
Too scary for me... ;-)
Well done! Now, how you going to seal water out? |
Garland |
Thinking brutal, but can make a mess. So working on rubber seals. From scrap 914 weather striping, and seals. ![]() ![]() ![]() ![]() |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,525 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Looking good interested in how the rockers look completed now that they are textured and fit against the flares.. I might go this way versus using the fiberglass rockers I have currently.
whitetwinturbo |
REALLY nice lighting (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif)
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Awesome headlight solution!
But... Why did you mount the headlight cover upside down? |
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Those are definitely some "mad" skills you have my Man. Well done. You are in a league of your own. Nothing like this has ever been done. (IMG:style_emoticons/default/first.gif) |
Garland |
Awesome headlight solution! But... Why did you mount the headlight cover upside down? Thank you all, I have the running and turn lamp in the bottom hafe, and wanted to keep them amber. Thinking of adding daytime running/marker in the top. Without cutting the lens, anymore. Also stuck with stock white for headlamp souronds. (IMG:style_emoticons/default/smile.gif) |
Garland |
I ran in to a bit of a problem when starting my build engine, so I went to the "Garage"
LINK: > Oil filter bulge, like Jiffy Pop, Fresh Engine first start, help! Michigan Build, 2016 Build-Off ![]() ![]() ![]() ![]() |
Garland |
Garland |
First here is a few pictures of my home powder coating I did a few years ago. used a small oven, and home gun set up.
![]() ![]() Been busy. After the oil pressure concern was solved Garage postings Also a few of engine exterior build up. ![]() ![]() ![]() ![]() ![]() ![]() I moved the engine on to the trailer, yard trailer. ![]() ![]() Out with the old stock 1.7 still running well, after 40+ years, and 5 different cars. ![]() slowly down and away. ![]() ![]() ![]() ![]() ![]() |
Garland |
Garland |
Garland |
First start in car looks good, the oil pressure is 42. And no leaks. 3rd road test WOW oil everywhere.
Restart and oil pours out like a faucet. Cause, thick washers for the oil cooler to mount were installed between the cooler and the block. By me. Ug. They should be out side the cooler with the lock washer, and nut. In turn the seal won't seal! major oil leak, at 42 psi. ![]() ![]() ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Big day for sure, great job. I lost a Black and Decker Workmate once doing close to the same extraction method. So just be careful, I like the idea though.
Garland |
Well that took a while. Now I need to decide if I drop the engine to replace those seals or do I try to remove the cooler while the engine is in the car.?
Lo-Fi Version | Time is now: 3rd April 2025 - 01:20 PM |
