rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,670 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
Junkyard find or should i buy something newer? Working at the junkyard was quite a good time. There were a bunch of subarus to scavange. -Brett Stick with the hydraulic clutch. After looking back at your photos some more looks like you have almost everything you need. Now you just need someone to.come with it for you (IMG:style_emoticons/default/wink.gif) You'll still need the flywheel and clutch that mates with the transmission. Which yard did you go to? I would buy new, and honestly, would think about getting a slightly lighter flywheel. I have been wanting to swap mine for a lightened one for a while! |
brettrarnold |
New 914 owner in Lakewood CO ![]() ![]() Group: Members Posts: 90 Joined: 11-September 15 From: Lakewood, Colorado Member No.: 19,149 Region Association: Rocky Mountains ![]() |
upullandpay near washington and 70th.
saw this on ebay. Would i just search for subaru 5spd clutch and lightweight flywheel. Anything else specific that i should get? The trans came off a forester and ebay link says impreza/wrx if that matters. -Brett Junkyard find or should i buy something newer? Working at the junkyard was quite a good time. There were a bunch of subarus to scavange. -Brett Stick with the hydraulic clutch. After looking back at your photos some more looks like you have almost everything you need. Now you just need someone to.come with it for you (IMG:style_emoticons/default/wink.gif) You'll still need the flywheel and clutch that mates with the transmission. Which yard did you go to? I would buy new, and honestly, would think about getting a slightly lighter flywheel. I have been wanting to swap mine for a lightened one for a while! |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,694 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Shouldn't be if it's early 2000's. The only difference will be the 4:11's vs 3:90. You'll have a great Hi Way cruiser.
brettrarnold |
Spent the super bowl working on the
Screws going into hooks. I used #4-40x3/8" and i may have to grind off the lip on the back end. ![]() First side down and hooks are in! ![]() Both sides down. ![]() And the completion of the bottom pads with seat heaters. ![]() ![]() |
76-914 |
Looks great! May I make a suggestion? While your at it, throw in some heated seats. Your running at least a 150A alternator and they can be had for < $70 pr. Plus you live in CO and could really use those. They come compete with relays and switches. I remember being in AZ when it was 29F with those heated seats. My engine and wife were both purring. (IMG:style_emoticons/default/lol-2.gif)
76-914 |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,811 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Looks great! May I make a suggestion? While your at it, throw in some heated seats. Your running at least a 150A alternator and they can be had for < $70 pr. Plus you live in CO and could really use those. They come compete with relays and switches. I remember being in AZ when it was 29F with those heated seats. My engine and wife were both purring. (IMG:style_emoticons/default/lol-2.gif) I'm pretty sure I got a kit from ebay. 2 seats, top and bottom, $40. |
brettrarnold |
Yep have the heated seat kits and put in the bottom pads so far. Need to do the back pad but this is a must!
-Brett Looks great! May I make a suggestion? While your at it, throw in some heated seats. Your running at least a 150A alternator and they can be had for < $70 pr. Plus you live in CO and could really use those. They come compete with relays and switches. I remember being in AZ when it was 29F with those heated seats. My engine and wife were both purring. (IMG:style_emoticons/default/lol-2.gif) |
Yep have the heated seat kits and put in the bottom pads so far. Need to do the back pad but this is a must! -Brett Looks great! May I make a suggestion? While your at it, throw in some heated seats. Your running at least a 150A alternator and they can be had for < $70 pr. Plus you live in CO and could really use those. They come compete with relays and switches. I remember being in AZ when it was 29F with those heated seats. My engine and wife were both purring. (IMG:style_emoticons/default/lol-2.gif) At the point on mine that I have to sew the center back pad around the cardboard stiffeners, just not sure how I'm going to do it. |
brettrarnold |
Ya not sure myself. I saw in the master seat upholstery post the guys used zip ties. so may try that.
Also i ran into an issue with the foam headrest breaking apart when i was removing it from the seat. I used spray adhesive to get it back together and am hoping that will hold it. Photos forthcoming. |
Ya not sure myself. I saw in the master seat upholstery post the guys used zip ties. so may try that. Also i ran into an issue with the foam headrest breaking apart when i was removing it from the seat. I used spray adhesive to get it back together and am hoping that will hold it. Photos forthcoming. I meant the rectangular ones that are about 18" long. There are lots of old seat cores to borrow parts from if the headrest doesn't hold together. talk to bruce stone/bedstone or Garold or who ever is your local parts hoarder. |
76-914 |
Looks great! May I make a suggestion? While your at it, throw in some heated seats. Your running at least a 150A alternator and they can be had for < $70 pr. Plus you live in CO and could really use those. They come compete with relays and switches. I remember being in AZ when it was 29F with those heated seats. My engine and wife were both purring. (IMG:style_emoticons/default/lol-2.gif) I'm pretty sure I got a kit from ebay. 2 seats, top and bottom, $40. Me too. Just didn't want to undersell or guys. On eBay they wanted $60. They had a make offer price. I did and paid $45. You 2 guys really need these and they work sooooooo well. (IMG:style_emoticons/default/beerchug.gif) |
GenosYourGarage |
Newbie ![]() Group: Members Posts: 1 Joined: 3-February 18 From: Arvada, CO Member No.: 21,857 Region Association: Rocky Mountains ![]() |
New to the forum and wanted to say hello/ask a quick question for Brett's build. I'm a good friend of Brett's and will be helping him when I can for his 914 build. I don't have much experience with the 914's, but I have done some conversion work in the past and love to learn new things.
On to the question: I was looking at flywheel/clutch kit options for the 04' Forester 5MT we brought home from the salvage yard. I just wanted to be certain that Brett can buy the flywheel/clutch kit that fits the 04' forester and it will bolt up to the 01' Outback H6. If so, I think we are going to get that coming along with a engine gasket set (upper and lower). Then we will have some things to work on. |
brettrarnold |
So i started in on replacing the gaskets on the ez30 subaru engine and holy shit im learning a ton. Got her up on an engine stand and i watched a youtube video of a guy that did this project without taking it out of a subaru. gives me a new respect for those that attempt it.
Step 1 of 2,600: Got her up on the engine stand (yes we all felt accomplished so we sat around patting each others backs for the next 40 minutes) ![]() got one side off ![]() removed cover to expose timing chain ![]() removed exhaust on each end ![]() |
brettrarnold |
Questions for the 914 community.
1st my wife is laughing at me as it has been a year or so since i posted. Apparently no burglars wanted to break in, fix the porsche, and drive off in a sports car.... i even left the keys in the ignition, c'mon! ![]()
Remove cotter pin from castle nut (nut inside of rear hub). Use an impact wrench to remove castle nut. If you don't have an impact gun, borrow or buy one. You will wonder how you ever got along without it. If you really don't want to make it easy on yourself, use a long breaker bar on the castle nut and a pretty good size pipe wrench to hold the axle.
The impact wrench will also work great on the top nut of the front struts. The pipe wrench will work well to remove the top cap on the strut body. Good to see you back on it. (IMG:style_emoticons/default/beerchug.gif) |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,268 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
76-914 |
Drive the bearings and races out with a large socket and replace with new bearings and seals. They're cheap. Be sure to mic that rotor to check min thickness. BTW, that engine looks clean. No sludge buildup. (IMG:style_emoticons/default/beerchug.gif)
brettrarnold |
Got the castle nut off using the impact gun!! Too EASY! Thanks
Haven't done the bearings yet but thanks for the tip. Will do that tonight. Nice to hear my engine doesn't have much sludge. I had the head gaskets replaced, new timing chain, and a number of other components replaced from Dave @ Simply Subaru's. It too was also very reasonable. I am a little nervous about the first time starting it up though. But as you all know that is probably a year or two out. My seats got finished and i think they really came out nice. Dominick @ Monaco Auto Trim in Englewood CO was awesome to work with and cheap! Before ![]() After ![]() Thanks for all the feedback and help! -Brett |
76-914 |
I'm surprised he sourced the chains. I couldn't find them or the oilers but mine seemed in good shape. I've heard stories of these EZ30's turning 300,000 miles with proper care. Seats look great! (IMG:style_emoticons/default/beerchug.gif)
EDIT: you can open up those headers at the merge and pick up a little umph. There is a lot of meat in that area. |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:11 AM |
