8 Pages V « < 2 3 4 5 6 > »
> BUILD-OFF CHALLENGE: Olympic Blue Resurrection, More Winter projects.
Darren C
post Aug 2 2016, 02:34 PM
Post #61
Region Association: England
Hey Tom,
Looking Goooooooooooooooood :-)
Olympic 914
post Aug 2 2016, 06:42 PM
Post #62
QUOTE(Darren C @ Aug 2 2016, 04:34 PM) *
Hey Tom,
Thanks .. If I had your drive it would be done in no time...
Olympic 914
post Aug 23 2016, 08:01 PM
Post #63
Moved it outside for some pictures. paint turned out good. still will need a cut and buff.
And starting to put stuff back on... (IMG:style_emoticons/default/piratenanner.gif)
Refinished the headlight mechanisms and got them installed. Had to hunt down some little parts, Thanks for friends with parts cars... I need to get one of those..
Installed the PMB 914/6 GT rear calipers and the vented rotors. also got all the hydraulic lines and hoses installed , glad I kept the old lines to use as a pattern. still need a couple little parts for the parking brake
those rear calipers should play nice with the with the A calipers and vented rotors on the front.
PMB also rebuilt my pressure regulator... Thanks Eric..
It is really great to empty out some boxes and get parts on the car...
914forme
post Aug 24 2016, 12:25 PM
Post #64
QUOTE(Olympic 1.7 @ Aug 23 2016, 10:01 PM) *
(IMG:style_emoticons/default/dry.gif) only wish I was at that stage (IMG:style_emoticons/default/dry.gif)
Keep up the great work (IMG:style_emoticons/default/piratenanner.gif)
jkb944t
post Aug 26 2016, 10:48 AM
Post #65
QUOTE(Olympic 1.7 @ Aug 23 2016, 06:01 PM) *
You are making some huge progress!
Jeff B
JoeDees
post Aug 26 2016, 07:59 PM
Post #66
I imagine I'm not the only one sitting here on a Friday night, drinking a beer, looking at this thread with an intense melancholic jealousy.
Great work!
Valy
post Aug 26 2016, 10:11 PM
Post #67
Looking very good!
Great job with the paint!
rgalla9146
post Aug 27 2016, 12:08 PM
Post #68
Are they aluminum alloy rear calipers ?
Olympic 914
post Aug 28 2016, 06:19 PM
Post #69
QUOTE(rgalla9146 @ Aug 27 2016, 02:08 PM) *
Yes, Aluminum calipers
Working on bleeding the system now.
And starting to think about tires....
Olympic 914
post Sep 19 2016, 08:29 PM
Post #70
OK, well 9-14 day has come and gone and I am still not running yet, so that puts me out of contention for the win. For me it wasn't about the win anyways, I just liked the push to get some work done worthy of sharing with the 914 community.
Congratulations to those that did get their cars running
Andrew, Darren, Garland, Jeff and Philip. great job. (IMG:style_emoticons/default/beerchug.gif)
I worked through a few more setbacks. First when I finally started to strip off the doors to get them ready to take and be blasted I discovered that the drivers door was hammered. someone did a pretty good job of hiding the work and it stayed hidden for the 37 years I owned the car. but I didn't think it was worth my time to try and fix this mess. These are some of those rare doors, 9-72 thru 12-72 late window mechanism and no door bars. didn't think I was going to find another of those so....
so after checking out a couple doors a friend had, I contacted Garold and he picked me out a nice one.
they are at the blasters now then I will go to work on them.
I wanted to get it on the ground and started to look at tires to fit the 7 and 8 in Fuchs I wanted to run. Well in spite of getting the fenders flared it looks like the 8 inchers may not work, even with 225 / 50 -16.
I really like these wheels though........
I have another idea but I will do a little more research before I decide what to run. But this will have to happen soon. I want to get it on the ground before I put the engine back in.
Spent 4 days working on the brakes. two days to finally get the system bled and two more to get the venting clearance tight and have a working parking brake. The brakes feel good now ( at least pressing on them in the garage) so I think I am good to go with that.
I got the rear sway bar mounted and picked up a new creeper... this thing is like a Magic Carpet the way it slides around, No more fighting with my old creeper to roll around, or it eating my shirt....
This really helped while working on the brakes.
Still Moving along.
Tom
raynekat
post Sep 19 2016, 08:36 PM
Post #71
Hard to believe those wheels won't fit under GT flares?
Or are you talking under the stock fenders?
Car is looking great BTW!
jmitro
post Sep 19 2016, 09:04 PM
Post #72
man, very nice work!
barefoot
post Sep 20 2016, 04:51 AM
Post #73
Still Moving along.
Tom
[/quote]
The way the trailing arm rotates will bring the wheel inboard slightly under load. Disconnect the Spring/shock with the wheel on and lift it up to a loaded position to see if fender clearance improves
jd74914
post Sep 20 2016, 05:38 AM
Post #74
Its alive
QUOTE(barefoot @ Sep 20 2016, 05:51 AM) *
(IMG:style_emoticons/default/agree.gif) Your camber goes very positive as the suspension droops so if you jack up on that wheel it might tuck in nicely. Also, have you checked your toe? If it is very negative your wheel will also move outward.
jkb944t
post Sep 20 2016, 05:43 AM
Post #75
QUOTE(Olympic 1.7 @ Sep 19 2016, 06:29 PM) *
Tom
Thanks! Awesome looking wheels but I agree 8" might be too tight. You made great progress so far so you should be very proud.
It is a lot of work but it is worth it once it is running. Keep at it and you will have a great looking 914 on the road very soon!
Jeff B
Olympic 914
post Sep 20 2016, 05:46 AM
Post #76
QUOTE(jd74914 @ Sep 20 2016, 07:38 AM) *
I will take a look at this today. easy enough to unbolt the shock and see where it pivots to.
I haven't done any type of rough alignment, tough to do without the weight of an installed engine and other parts (or tires)
jd74914
post Sep 20 2016, 06:03 AM
Post #77
Its alive
QUOTE(Olympic 1.7 @ Sep 20 2016, 06:46 AM) *
Yeah, I know it's tough to do. With the shocks unbolted you could put the wheels on the back and try doing a rough string alignment (or even just visual toe check would be enough) to rule that out too.
Those are beautiful wheels-I really hope they fit!
Olympic 914
post Sep 20 2016, 06:04 AM
Post #78
Another little bit I spent too much time on.......
dug out the heater control lever and thought. I can't run this crusty looking thing.
I guess the carpet holds moisture against the lever.
So off to the chrome shop with it... A good friend runs the chrome shop, so he usually can get little parts through for me quickly. this piece took a LOT of sanding to get rid of all the pits and then he had it in the nickel tank for over 4 hours to build it up. then on to the chrome tank.
Looks much better now.
I could have just painted it but that wouldn't be right....
This is just an example of why it takes me so long when working on this car.... OCD.. Maybe..
ChrisFoley
post Sep 20 2016, 07:46 AM
Post #79
I am Tangerine Racing
The 8s with 225s should fit fine.
mbseto
post Sep 20 2016, 08:20 AM
Post #80
QUOTE(Olympic 1.7 @ Sep 20 2016, 08:04 AM) *
Good workmanship pays off. You and others will appreciate those details when you're driving it around. Keep up the good work!
- Lo-Fi Version Time is now: 3rd April 2025 - 01:12 AM
