Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Thanks a bunch!
Hope you get it fixed! Im starting to think it may not be my clutch acutally letting go.. but possibly something else... (I think the linkage is catching and releasing the clutch just enough to spin at high enough torque...) Andrew |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
If you are still using the stock cable system it souds like the tube has pulled loose in the tunnel , or the pedal pin is broke. Same symptoms anyway. Good luck
ft.lbs. |
Newbie ![]() Group: Members Posts: 41 Joined: 30-December 04 From: Jefferson,ME. Member No.: 3,376 ![]() |
I had the same problem with my dodge superbee.I mis-matched Borg-beck and Diaphragm style pressure plate and clutch.The "fingers" of the Borg-Beck pressure plate were hitting the springs on the I.D. of the clutch plate causing it to never disengage the clutch. (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif)
John2kx |
Senior Member ![]() ![]() ![]() Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 ![]() |
Chris,
Have not been here in a while but it was a pleasant surprise to see your still wreching on what used to be mine. I agree with Brad and think it is just a adjustment issue and suggest you make 1/2 turn changes to make the clutch move "forward" until it shifts without grinding. Since you have changed to a different style clutch/pp, the location of pivot ball may not be in the desired location. Removing washer(s) will do the same as loosening clutch cable and adding washer(s) will provide more disengaging action (moving clutch forward). I would not go to the trouble of making washers changes until you've used up all your adjustment range with clutch cable. You may have to make several adjustments to get clutch in range and something I learned by spending allot of time on my back. I never liked the idea of throw out bearing riding on pp forks during my original installation but Scott @ Renegade told me this was normal and they have never experienced a failure. I followed the same shifter procedure you mentioned and marked shift rod by scribing fore/aft and left/right marks in the event it was ever removed again. It does not sound like you've done anything to prevent the use of those settings. To speed things up, you could tighten clutch cable until t/o bearing makes contact with pp and check for grinding. If this works, just take it easy the first few times you apply torque to ensure you don't have a clutch slipping issue. This is where the 1/2 turn or less on cable adjustment really comes in to play. There is a fine line between grinding the gears and clutch slippage. Needless to say, this is where the difference comes in when bolting 400hp vs. 80hp to the 901. With the flat 4, clutch slippage is not much of a issue once you get the gear grinding adjusted out. Not sure if we covered this while you were here but the clutch cable has been replaced and the pedal cluster was also rebuilt just prior to my purchase of car. A new bushing was also installed in clutch pivot fork when I installed the conversion. A couple of things that I picked up from other guys that have done similar conversions that can cause problems and are easily overlooked: -engine and transaxle mounting bolts to chassis are tight -engine to transaxle mounting bolts are tight -tall oil filters will cause contact with shift rod Sorry for being so long winded but I hope you find some of this useful. Regards, John |
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
Hey John,
Great to see you on the board. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Strange days around here lately. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) I think step one is tighten the clutch further. You probably hit it right on the head. I'm adjusting the V8 like it was a 1.7. I had some similar trouble with this the 1st time I put the engine back in. I thought I learned something then, but I'm probably being too conservative again here. I am also uncomfortable with the throw out riding on the p plate, and was hoping with the recent changes I could avoid that, but maybe not. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Temps went back in the toilet here today, so I may not get to fooling with it for a few days. I will let you all know. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
aircooledboy |
Did a little experiment when I got home tonight, and I think the result is clear: clutch just needs to be tightened.
I started the car in 1st gear, clutch in. Tried to then put it into reverse never letting clutch out. It was very stiff coming out of 1st gear and I couldn't put it into reverse without grinding. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) So, obviously even with the clutch to the floor, trans is turning a little. Not enough to make the car move against the brake, but enough to cause gear clash. I also let it run for a few minutes, which lubed the innerds up good and proper, allowing me to move it through the gears much much easier when I shut it off. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) I thought seriously about taking the 2 minutes it would require to adjust the clutch, even though I was still in a suit (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif), but I am hard enough on suits as it is, and it is 19' out there now, (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) I decided it could wait until later this week to get it right. Course, its supposed to snow again on thursday. Let's see, 1/2" of snow, so local knuckleheads will drop 2" of salt on the road, it won't rain enough to wash that away for weeks, so I should be driving her by, oh June. . . ish. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
aircooledboy |
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Grrrrrrrrrrrrr. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
I have had the trans in and out of the car 6 times in the last 10 days or so. I have experimented with bending the throw out arm, grinding the arm, and adding and removing washers under the pivot ball. Bending and grinding was all a big waste of time. In the end, one thin washer under the pivot ball was what turned out to be the right combination to give me what SHOULD be a working clutch. Instead I am left with a clutch that shows signs of being too loose and too tight at the same time. (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) Right now, I can start the car in gear and clutch in, and the car doesn't make any signs of wanting to move. If I set the e brake, and let out the clutch, the engine won't kill until the pedal is almost to the top. Thus it is not locking until the pedal is almost released, and normally would mean the cable is tighter than it needs to be. Problem is, I still can't shift the trans or it grinds like crazy. Not a little, and not just for a second. Loud, and relentlessly. Thus, the clutch is not seperating the engine from the trans, acting like the cable is too loose. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) At this point, I can only think of 2 possible causes. 1) My new pressure plate is somehow defective and not releasing in the course of what should be a sufficient distance of T.O. travel, or 2) my pilot bearing, with less than 2000 miles on it, has somehow failed, and is turning the tip of my trans input shaft even with the clutch in. Either way, looks like trans is coming out for #7. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) If anybody has any suggestions for other things I should be looking at, I'm all ears. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
aircooledboy |
I just got off the phone with Dave at KEP, and it seems I have the wrong throw out bearing (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
The bearing I have is a KEP part that is different than a stock 914. It looks similar to a stock bearing, but is mounted in an odd sort of "carrier" bracket. Turns out the style I have was made for a style of P plate that KEP used to sell, and it was designed to accomodate the only type of springs they could get their P plates made with. It is shorter than a stock bearing, which is why it is unable now to push the springs in far enough to release the clutch. Now KEP makes their own P plates, and use springs that work with a stock bearing. KEP tells me if my new P plate has "flat fingers" (and it should since it is brand freaking new), then I need to switch back to a stock throw out (which of course I don't have). Dave apologized, and said somebody should have told me that when I ordered the new clutch. So, out comes the trans again tonight hopefully. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif) |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Sorry for the drama Chris, but it makes for good reading! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
have you looked at the adj at the pedal end of the cable? the light didn't go through the windshield. that's one in the + column.
k |
aircooledboy |
Heck, I agree (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) I don't really have the time to waste on this bastard right now, but on the plus side 1) I'm NOT an idiot (at least not based on this anyway (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) ), this train wreck wasn't my fault 2)Weather still sucks here anyway, and I should have it straight by the time the weather finally turns in the next week or two. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
MecGen |
8 Easy Steps ![]() ![]() ![]() Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 ![]() |
Hope this works out for you
I have been seriously turned upside down with New/mixed up parts Maybe take 5 and check the flywheel specs, maybe he turned it wrong, depths, hieght. cost nothing to check and saves you a re and re of the trans if its out. Good luck with it cheers (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) Joe (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
aircooledboy |
ARRRRRRRRRRRRRRRRRRRRGH, clang, clang, clang, thud, CRASH!!! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif)
You have just enjoyed the Midwest Theater for the Automotively Retarded's rendition of "What it Sounded Like When Chris Heaved a Breaker Bar Arcoss the Shop Which Then Crashed into an Old Shelf Full of Junk, and Knocked it Over", with Josh Groban on backup vocals. (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) What the guy at KEP told me is crap. The press plate I have IS intended for the throw out I have, and there doesn't appear to be any freaking difference in the dimensions between the KEP and stock anyway. I am completely out of ideas. If anybody has any pointers here, I sure could use 'em. Other than the possibility that the new press plate was built wrong (and it looks right to me) I am stuck. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Oh, and the pilot bearing is fine. Rolls smooth and easy. |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Just to let you know, Josh Groban will be in concert in Rockford on Saturday the 26th. Go see him then all the car problems will seem small. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
aircooledboy |
Funny thing about that Allan. That same day I have a chance to have my balls Super glued to the side of a rocket which will then be fired into the sun. I wasn't that interested at 1st, but if my wife mentions that concert, I'm signing up for the glue. (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
Allan |
(IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) Good luck with that. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
John2kx |
Chris,
I would try something easier than pulling the transaxle back out right now. You mentioned that the clutch did not fully grab until clutch pedal was almost fully extended. That is what I remember as normal with the original Renegade supplied clutch. It would begin to grab at a little more than 1/2 and then fully engage when almost fully let go. Adjust clutch throw until your not crunching gears and give it a test drive..............no matter where it feels fully engaged by pedal travel. If you have a kevlar clutch (like what was originally installed in car, drive it like granny for the first 100 miles). The life of your clutch will depend on how you break it in if your running kevlar. If you can't get the gears to stop crunching, I'd go back through the shifter adjustment procedure at least one more time. What I remember when it was adjusted just right is that it would make a slight gear clash sound (going for reverse) when cold unless you double clutched it...............again, only required when stone cold. Something else I found abnormal was that with the rear wheels suspended, they would turn when trans. was in neutral and engine running. I thought this was abnormal but learned to accept it. John |
Lo-Fi Version | Time is now: 27th June 2024 - 08:47 PM |
