11 Pages V < 1 2 3 4 5 > »
> Just another Factory 6 being fixed up
IronHillRestorations
post Nov 22 2019, 08:35 AM
Post #41
I. I. R. C.
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
Luke M
post Nov 22 2019, 12:51 PM
Post #42
QUOTE(rgalla9146 @ Nov 21 2019, 03:45 PM) *
Holy Cow !
I think this car will be very straight.
Great work Luke.
Hi Rory,
You know how I am. I went back and forth on how to do the right long replacement for sometime. When Perry posted the bench for sale I had to jump on it. Thanks again Perry for making it an easy transaction. It's the only way to do this job right and not worry if things are out of alignment. With the bench I have control of the repair and I can take my time to make sure everything is correct. Once I have the current fixtures attached I will work on making some for the front end. Then the spot drilling and cutting will start.
Stay tuned...
Jamie
post Nov 22 2019, 02:36 PM
Post #43
It never ceases to amaze me seeing the skills and desire that some teeners show doing these rustorations. (IMG:style_emoticons/default/piratenanner.gif)
Tdskip
post Nov 24 2019, 08:00 AM
Post #44
Fantastic - thanks for all of the updates.
Superhawk996
post Nov 24 2019, 09:46 AM
Post #45
QUOTE(mb911 @ Jul 16 2018, 04:23 PM) *
I will have to tackle this shortly. I am not sure what it should be but I have never seen a 914 with consistent gaps..
@Luke M
@MB911
5-6mm gaps (and inconsitent) were not at all uncommon in any 1970's era cars domestic or imported.
I could write a dissertation on how body dies used to be cut in the Pre-CNC era. Basically, it was done by a Keller Tracing Mill that basically carved metal by tracing a cutting path on a 3-D master which was usually a Kirksite (Zinc based alloy that cuts sort of like Aluminum) prototype die that would only be suitable for low volume use. As the path was traced on the Kirksite die, a production die was simultaneously being cut out of cast iron. Think of a pantograph but cutting cast iron instead of tracing a drawing on paper.
Needless to say, accuracy wasn't what it is today.
Don't kill yourself trying to get a consistent 3-4 mm gap that you would expect today. It isn't going to happen without welding door edges.
mb911
post Nov 24 2019, 10:18 AM
Post #46
I have seen allot of cars with welded edges..
Luke M
post Dec 5 2019, 12:43 PM
Post #47
Got all the fixtures attached between the chassis and bench. The right side inner suspension console required some minor adjustment to fit into the fixture. I kinda figured it was going to be an issue seeing how all of the rust damage is around that area.
Otherwise other fixtures bolted right up. I need to level out the bench as it's off just a touch but need to go buy a huge wrench first.
Cairo94507
post Dec 5 2019, 02:07 PM
Post #48
Michael
That, in and of itself, is impressive. (IMG:style_emoticons/default/beerchug.gif)
Luke M
post Apr 26 2020, 04:22 PM
Post #49
With this covid thing going around it has set my project back. I had plans to have the chassis blasted and epoxy primed before I started cutting into it. The blaster emailed me and said per rules under the NY PAUSE act that my project is not essential and he couldn't do it until the state relaxed the rules. So now it's a waiting game there. I can do a few other things on the chassis before it goes. Got the new to me 3.2 in and started working on that. Apart she comes. Going with a 3.4 Mahle MS p/c's while doing the rebuild. Also in the works is a late model 3.2 915 with a Bott 916 shift kit. Stay tuned kids as I'll be working away when I can.
Be safe out there... (IMG:style_emoticons/default/beerchug.gif)
porschetub
post Apr 26 2020, 05:04 PM
Post #50
Top overhaul or full build ?,will be a quick car with those plans (IMG:style_emoticons/default/beer.gif)
Luke M
post Apr 26 2020, 05:45 PM
Post #51
QUOTE(porschetub @ Apr 26 2020, 04:04 PM) *
Going all in.. Bottom to top end.
Luke M
post May 1 2020, 09:16 AM
Post #52
Started the tear down on the 3.2. I'm gonna remove the head studs then split the case.
Supertech head studs are going in so these need to be removed. I hope none of them snap like my brothers 3.0.
3.4 MMS p/c's and a bunch of other parts are on order. It should all be here next week..
Mark Henry
post May 1 2020, 10:49 AM
Post #53
that's what I do!
For the Supertec head studs you'll need a thread reformer tap. Don't use a regular tap as it will cut too much of the threads.
I had to do this on my 3.0 or the studs wouldn't go in far enough.
post May 1 2020, 11:31 AM
Post #54
914-6 GT in waiting
I removed studs from about 25 engine cases when I worked at the shop. If you have 2 people, one heats up the case right at the register where the stud descends into the case. The other is removing pre heated studs from the case. I always hit it with map gas for 2-3 minutes before twisting the stud. My feeling is it not only helped to keep the stud from breaking but it was easier on the aluminum and especially magnesium threads in the case. If the stud wasn't easy to turn after a couple minutes of heat, it got another minute or 2 and would always come out easily.
Divlar studs are strange. I watched someone reuse them because they looked perfect and the next morning we came in to a couple broken studs on the floor. While we were standing there, we heard a ping, watched a broken stud with the nut on top, jump out of the head and fall to the ground. The engine got all new studs...
Luke M
post May 2 2020, 02:47 PM
Post #55
Got the head studs all off without any issues..
Gonna split the case on Sunday.
I did get an update from PMS on the 915/Bott 916 trans. The tech was wrapping it up on Friday so it should be shipped out this coming week.
Cairo94507
post May 2 2020, 04:26 PM
Post #56
Michael
Luke - I am loving that transaxle (IMG:style_emoticons/default/wub.gif)
rgalla9146
post May 2 2020, 06:58 PM
Post #57
Looking good Luke
Make hay while the sun shines !
Luke M
post May 3 2020, 01:19 PM
Post #58
I split the case today.. Main bearings looked good but the lay shaft bearings are showing wear. I need to get the rods removed from the crank then all parts off to the machine shop.
Luke M
post May 19 2020, 01:35 PM
Post #59
I received my converted 915/916 Bott trans back from PMS today.
I also purchased the PMS shift linkage kit to work with the new setup.
gms
post May 19 2020, 01:58 PM
Post #60
Nice addition to the build
- Lo-Fi Version Time is now: 26th December 2024 - 06:39 PM
