Just another Factory 6 being fixed up |
raynekat |
May 19 2020, 09:01 PM
Advanced Member Group: Members Posts: 2,167 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Kroon wire harness co. sent me an email that my new chassis harness is done and ready to be shipped. I should see that in about two weeks. Gerard sent me a few pic of it so enjoy. (IMG:style_emoticons/default/drooley.gif) That Kroon replacement chassis harness will be killer. Expensive buy worth it on your project without question. |
Luke M |
May 20 2020, 08:11 AM
Senior Member Group: Members Posts: 1,400 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
It's a nice wire harness for sure but there maybe a wiring issue that Kroon was not aware of. I need to check it out to confirm. RD is now making a replacement 914-6 harness as well. I believe the price is about the same.
IronHillRestorations |
May 20 2020, 01:03 PM
I. I. R. C. Group: Members Posts: 6,792 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Pretty sure RD harness is much less
bigkensteele |
May 20 2020, 07:12 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Are you sending the machine work to Ollies?
Luke M |
May 20 2020, 08:20 PM
Luke M |
Jul 14 2020, 05:33 PM
Well after months of waiting (thanks to covid) I finally received my Celette 914 bench fixtures. I'm going to get the 6 off the current fixtures and back on the rotisserie for blasting. Once the blasting is done then it'll be on these Celette fixtures for the chassis repairs.
Jul 14 2020, 06:54 PM
914-6 GT in waiting Group: Members Posts: 19,649 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
What type of blasting are you having done?
sixnotfour |
Jul 14 2020, 10:44 PM
914 Wizard Group: Members Posts: 10,681 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Well after months of waiting (thanks to covid) I finally received my Celette 914 bench fixtures. I'm going to get the 6 off the current fixtures and back on the rotisserie for blasting. Once the blasting is done then it'll be on these Celette fixtures for the chassis repairs. Holy Grail...…..I got a nos left rear fender..pm me an offer..or trade for a right |
rgalla9146 |
Jul 15 2020, 05:25 AM
Advanced Member Group: Members Posts: 4,671 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Well after months of waiting (thanks to covid) I finally received my Celette 914 bench fixtures. I'm going to get the 6 off the current fixtures and back on the rotisserie for blasting. Once the blasting is done then it'll be on these Celette fixtures for the chassis repairs. WOW. Luke, thats a lot of equipment ! I see parts that are easy to understand for our cars and others that must be bases or mounts. Are there 911 parts too ? Great way to go. Unbelievable score. Be careful, that is some heavy equipment. Get to it. |
Jul 15 2020, 05:41 AM
Well after months of waiting (thanks to covid) I finally received my Celette 914 bench fixtures. I'm going to get the 6 off the current fixtures and back on the rotisserie for blasting. Once the blasting is done then it'll be on these Celette fixtures for the chassis repairs. (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) |
Luke M |
Jul 15 2020, 07:28 AM
Well after months of waiting (thanks to covid) I finally received my Celette 914 bench fixtures. I'm going to get the 6 off the current fixtures and back on the rotisserie for blasting. Once the blasting is done then it'll be on these Celette fixtures for the chassis repairs. WOW. Luke, thats a lot of equipment ! I see parts that are easy to understand for our cars and others that must be bases or mounts. Are there 911 parts too ? Great way to go. Unbelievable score. Be careful, that is some heavy equipment. Get to it. Hi Rory, All of the fixtures are for the 914 and 914-6. Only difference for the 6 is the special firewall engine mount bracket which is here as well. The front end fixtures could be used for the 911 up to 89 I believe. The cross beams are what the fixtures mount to then to the bench. I need to remove the 6 and current fixtures to figure it all out. I'm missing some mounting bolts but I should be able to pick those up locally. Yes they are heavy pieces and definitely a two person job setting it all up. As far as blasting goes, the blast co says a few different media will be used. Harder grit for chassis vs panels which gets lighter so panels do not warp. Then all gets epoxy coated. I need to get all of the seam sealer out prior to blasting. That's gonna be a fun day. |
Gint |
Oct 11 2020, 11:39 AM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
It's a nice wire harness for sure but there maybe a wiring issue that Kroon was not aware of. I need to check it out to confirm. RD is now making a replacement 914-6 harness as well. I believe the price is about the same. And that issue is that? Inquiring minds would like to know. Looks great so far. Subscribed |
Luke M |
Oct 11 2020, 05:22 PM
It's a nice wire harness for sure but there maybe a wiring issue that Kroon was not aware of. I need to check it out to confirm. RD is now making a replacement 914-6 harness as well. I believe the price is about the same. And that issue is that? Inquiring minds would like to know. Looks great so far. Subscribed Glenn and I did check over my Kroon harness to see if it had the same issues as the one he installed. My harness seams to be wired correctly. I wouldn't hesitate to buy the RD harness but I already have the Kroon harness on hand. |
gerakroo |
Oct 19 2020, 12:49 PM
Newbie Group: Members Posts: 18 Joined: 27-June 14 From: Sappemeer Member No.: 17,563 Region Association: Europe |
It's a nice wire harness for sure but there maybe a wiring issue that Kroon was not aware of. I need to check it out to confirm. RD is now making a replacement 914-6 harness as well. I believe the price is about the same. Hi Luke, can you explain about the "possible wiring issue" in the fan connector ? We just checked the pictures and 5 other original 914-6 harnesses but they're all the same and identical to the new one we produce ?, Red , top left, white-green top right, white-yellow, under left, white, under right ?. Many 914-6's around the world are equipped with a new wiring loom delivered by us and this is the first time we hear about this ? |
gerakroo |
Oct 19 2020, 12:58 PM
Pretty sure RD harness is much less How much less ? I think that a comparison can only be made if you put both sets next to each other and compare them in detail. I wonder if RD delivers exactly the same as what we do? I would love to see some more detailed pictures of the RD 914-6 harness set ? |
Luke M |
Oct 20 2020, 09:34 AM
It's a nice wire harness for sure but there maybe a wiring issue that Kroon was not aware of. I need to check it out to confirm. RD is now making a replacement 914-6 harness as well. I believe the price is about the same. Hi Luke, can you explain about the "possible wiring issue" in the fan connector ? We just checked the pictures and 5 other original 914-6 harnesses but they're all the same and identical to the new one we produce ?, Red , top left, white-green top right, white-yellow, under left, white, under right ?. Many 914-6's around the world are equipped with a new wiring loom delivered by us and this is the first time we hear about this ? Hi Gerard, My harness that you made seams to be ok. There was an issue with the harness that Glenn put in for a customer. Guess there were some wires not located in the proper pins for the ignition. Another member was asking for the fan housing wiring and after looking into it my kroon harness seams correct. My factory 6 harness was tampered with prior to me owning it. That's where the confusion set in but got all worked out. Looks like the RD 6 harness sells for $2500.00 USD. http://www.restoration-design.com/store/pr.../914-612-019-10 Attached image(s) |
Oct 20 2020, 11:18 AM
Pretty sure RD harness is much less How much less ? I think that a comparison can only be made if you put both sets next to each other and compare them in detail. I wonder if RD delivers exactly the same as what we do? I would love to see some more detailed pictures of the RD 914-6 harness set ? I’ll get pictures of the RD 6 chassis harness in the next week or so. Nothing against Kroon at, looks like you make a fine product. I’ve been buying from RD prior to the new ownership which is one of a few reasons I went with them |
gerakroo |
Oct 21 2020, 12:32 AM
It's a nice wire harness for sure but there maybe a wiring issue that Kroon was not aware of. I need to check it out to confirm. RD is now making a replacement 914-6 harness as well. I believe the price is about the same. Hi Luke, can you explain about the "possible wiring issue" in the fan connector ? We just checked the pictures and 5 other original 914-6 harnesses but they're all the same and identical to the new one we produce ?, Red , top left, white-green top right, white-yellow, under left, white, under right ?. Many 914-6's around the world are equipped with a new wiring loom delivered by us and this is the first time we hear about this ? Hi Gerard, My harness that you made seams to be ok. There was an issue with the harness that Glenn put in for a customer. Guess there were some wires not located in the proper pins for the ignition. Another member was asking for the fan housing wiring and after looking into it my kroon harness seams correct. My factory 6 harness was tampered with prior to me owning it. That's where the confusion set in but got all worked out. Looks like the RD 6 harness sells for $2500.00 USD. http://www.restoration-design.com/store/pr.../914-612-019-10 Thank you for your reply Luke, i'm just curious if this price also includes a new engine harness, wiper harness, dash harness, new relay sockets , etc ? (our set does) |
peteyd |
Oct 21 2020, 06:42 AM
Senior Member Group: Members Posts: 733 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
Our chassis harness sells separately from our engine harness. We do include the relay sockets and the dash harness. We list all our pricing, stock at least one of every item listed on the web shop and shipping of your wiring will usually happen within 2 days of the order.
Gerard, we know you do great work. But we also hold our work to a very high standard. We stand behind our product. Competition breads excellence. Pete |
Luke M |
Oct 24 2020, 01:45 PM
Getting the case ready to assemble. I have all the parts back from the machine shop and last of the back ordered parts are in. I didn't want to remove the outer perimeter case studs to clean the case halves mating surfaces.So I checked a few studs and they came off easily. The case cleaning must have compromised the loctite so all are coming off now to be safe and while I'm at it cleaning the mating surfaces.
Anyone know why Porsche went with the oval locking nuts on the later engines? I have the nylon lock nuts but not the oval lock style. Attached image(s) |
Lo-Fi Version | Time is now: 27th December 2024 - 10:43 AM |
