tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,331 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
Time to trim / fit the patch.
Attached thumbnail(s) ![]() |
tygaboy |
(IMG:style_emoticons/default/sawzall-smiley.gif) then (IMG:style_emoticons/default/welder.gif) then (insert grinder emoji here) then prime and...
like new! Well, OK, except for that little dent thingy that used to be there. I think I can live without it. Maybe that will be my signature modification. Yeah, that's it... Attached thumbnail(s) ![]() Attached image(s) ![]() |
tygaboy |
Oh, and I almost forgot: After 28 years, that's right, 28, it's ALIVE!
Did a very minor service and it fired right up! Gotta love the ol' Type IV! https://www.youtube.com/watch?v=HprL5s4Cgjo |
tygaboy |
Total Change of plan:
This car will be left stock - or as stock as it can remain, given what I've already done - get completed and be put up for sale. I'd sell it as is, too, so if interested, PM me. (Hope this doesn't mean I get punted to the "Classified" section...!) And what of all the goodies I've purchased? Well, I've just purchased another car (very clean '75 roller) that will serve as the platform for the LS3 conversion. I'll post that in a separate build log. So this build will move to a 'get it mechanically dialed in, get it painted, put back together and sold! The fun continues, as always. |
iwanta914-6 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None ![]() ![]() |
I'm interested when it's all put back together!
tygaboy |
iwanta914-6 |
I'm interested when it's all put back together! PM sent - You can pick your color and other details... That would be sweet! I just don't have a clue how much everything would cost. Most likely out of my range but who knows... |
iwanta914-6 |
What was the original color anyway?
tygaboy |
iwanta914-6 |
tygaboy |
Wrapping up the front floor half install. Got to the seam sealing and since I'd only replaced 1/2 the floor, I decided to try and duplicate the factory seam sealer. Worst case, I could strip off the sealer on the back half and redo the entire outer seal.
Anyway, I saw that if you apply the sealer and blast it with an air hose, it creates what starts to look a lot like the factory sealer. So, I started practicing. Attached thumbnail(s) ![]() |
tygaboy |
Then I went after it on the car. I did my current best to try and blend/match. I think it turned out OK.
I may replace all the old stuff, just to make it all really matchy-matchy. We'll see how it all looks after I Wurth Stone Guard the bottom. I'm thinking that will soften some of the sharper peaks I got with the air hose approach. Attached image(s) ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
You may be able to duplicate the look of the seam sealer, but make sure the material you are using is just as durable or you will be inviting rust in. I never thought the seam sealer was that tough until we did the media blasting in the trunk. We would actually have to apply a lot of media to get it off. In the end we left in the areas that we didn't have to remove, but I plan to use the Wurth product even though it's expensive as I know it will not have an issue later.
tygaboy |
You may be able to duplicate the look of the seam sealer, but make sure the material you are using is just as durable or you will be inviting rust in. I never thought the seam sealer was that tough until we did the media blasting in the trunk. We would actually have to apply a lot of media to get it off. In the end we left in the areas that we didn't have to remove, but I plan to use the Wurth product even though it's expensive as I know it will not have an issue later. Thanks for the reminder. Yes, this is a 3M product, urethane, recommended by a local high end auto paint supply place. |
tygaboy |
Let's finish up the floor, shall we? Found time to wrap up the tunnel repair. I'm happy with the fact that I was able to get the piece to fit exactly as it did before I did the cutting and welding. It was tough to do the repair and get the patch tacked on both ends while ensuring I didn't build a twist into the part of the tunnel I'd removed. Hard to explain but no worries as it all lined right up.
tygaboy |
(IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) and I have a repaired tunnel! As Edd from Wheeler Dealers would say, "Result!"
iwanta914-6 |
I see she's up for sale at a very reasonable price. Good luck!
http://sfbay.craigslist.org/nby/cto/5727406271.html |
tygaboy |
And....... she's sold! Kind of a sad day but I need the space.
I'm about to start posting the build of the car that replaced this one as the base for the LS/Boxster set up. Lots to come. |
Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
and congrats to you Sir! Looking forward to seeing the PDK in there!!! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/poke.gif)
T |
Lo-Fi Version | Time is now: 24th June 2024 - 11:33 PM |
