Can you run a EJ20 Turbo as a N/A engine, then install the turbo later,.. |
flmont |
Nov 5 2015, 05:39 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Iam now thinking about running a turbo EJ20,..but can it be run as a NA,.Until I could put all the componets together,..meaning Fabing all the parts that wont come with the engine,..or is it a drop-in assembly,..Thanks FM
Mueller |
Nov 5 2015, 06:17 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I see no reason why not...it won't be as quick as a factory N/A 2.0 Subaru motor of the same size (if they even make one) due to the lower compression of the turbo motor.
flmont |
Nov 5 2015, 06:45 PM
I cant find a ez30 motor yet ,so I thought about those engines,seems to Be enough available,... how are the JDM engines..????
Mike Bellis |
Nov 5 2015, 07:49 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Lower compression = lower power without boost.
Then you have to tune it twice which can get expensive. I paid $2200 for tuning and parts for my Audi motor. Seems to me adding the turbo now will be cheaper and less work in the long run. |
JRust |
Nov 5 2015, 08:01 PM
914 Guru Group: Members Posts: 6,311 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Just run the 2.5 & add the turbo. You can do that with lower boost with no problem. Probably have to stick with about 8 lbs so not sure how great that would be. You'd just need fuel rails, intake & an ECU
matthepcat |
Nov 5 2015, 08:06 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Lower compression = lower power without boost. Then you have to tune it twice which can get expensive. I paid $2200 for tuning and parts for my Audi motor. Seems to me adding the turbo now will be cheaper and less work in the long run. (IMG:style_emoticons/default/agree.gif) Just wait and do it all at once. You have to run a different computer, exhaust and it will be a low compression dog. |
flmont |
Nov 5 2015, 08:13 PM
is there a lot of special mods to do,..?? or can you install the turbo engine,..and go from there...
matthepcat |
Nov 5 2015, 08:20 PM
is there a lot of special mods to do,..?? or can you install the turbo engine,..and go from there... Not really much more than an N/A motor: You have to cut the trunk to fit the turbo ( unless you relocate the turbo with the renegade hybrids up-pipe). You have to relocated the factory inter-cooler, or run a water to air inter-cooler. Other than that, everything else is pretty much the same as the N/A conversion. Will you be running a WRX transmission or the stock 901? |
Chris H. |
Senior Member Group: Members Posts: 4,050 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Take a look at the NA 2.0L JDM engines. They are CHEAP. Only 140hp or so but you can get one with low miles for like $700. Totally agree that running a turbo engine without the turbo wouldn't be the best idea. The ECU would be confused and even with the correct tune it'd be like a 2.0L bus motor. Low compression pistons, etc. You could mildly boost a NA engine as Jamie mentioned.
DBCooper |
Nov 5 2015, 08:59 PM
^^^ Agree totally. I think you'd be real disappointed with a N/A turbo engine. Some cheap Delta cam re-grinds in a naturally aspirated EJ22 and you're over 160hp with a really reasonable cost and amount of work. That or a stock newer SOHC EJ25 and you're at similar horsepower at a similar price. 165hp is enough for a lot of fun, maybe more than you think.
flmont |
Nov 5 2015, 09:19 PM
JDM in Phoenix,..has a 04-05 turbo for 1400.00 about 50 K miles,..on it,..??
Jake Raby |
Nov 5 2015, 09:30 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I have a ton of the EJ20T ancillaries and etc that I have no use for, if you need something. The same for internals, cranks, cams and etc that we pulled out to replace with our goodies.
76-914 |
Nov 5 2015, 09:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,648 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I cant find a ez30 motor yet ,so I thought about those engines,seems to Be enough available,... how are the JDM engines..???? You'll probably end up w/ a JDM which is OK if you can get the ECU too. Otherwise, buy a nice wrecked one and strip. There is so much you can cannibalize. |
colingreene |
Nov 5 2015, 11:01 PM
Senior Member Group: Members Posts: 732 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I am going to say if you dont have the money to do it right the first time dont do it.
Lo-Fi Version | Time is now: 3rd January 2025 - 02:19 AM |
