> Wiring Harness Questions for My Suby Swap, I have ecu pins i need to figure out
tazz9924
post Nov 6 2015, 12:08 PM
Hello 914 world! Im doing a suby swap into my 914 and ive ran into a stopping point. I have pins on my ej205 ecu i dont know what to do with them. With the wealth of suby swap knowledge on 914 world I figured someone could help!
my issue pins:
vehical speed signal
radiator fan relay 1/2 control
engine speed output
fuel tank pressure sensor
fuel tank pressure control solonoid
drain valve
fuel tank sensor control valve
fuel level sensor
fuel temp sensor signal
test mode connector
line end check 1
sorry if its a poop ton of stuff but any help you can spare is greatly appreciated. Thanks!
- Lo-Fi Version Time is now: 2nd January 2025 - 12:44 PM
