914 6 color wiring chart |
xsurfer |
Nov 10 2015, 08:45 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
I'm looking for a 1971 six cyl. wiring chart.
Any help would be appreciated. Thanks |
gereed75 |
Nov 10 2015, 09:06 AM
Senior Member Group: Members Posts: 1,240 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I'm looking for a 1971 six cyl. wiring chart. Any help would be appreciated. Thanks There is a guy named Art Zapf who produced a color laminated diagram www.zapfenterprises.com/ . I got one about a year ago. he mentioned that he only had 1 or two left. It is the version printed over a 914-6 image. Around $100.00 He also has some black and white factory diagram copies - $25.00 I think. The laminated diagram is ok. Colors are just OK and the clarity is just OK. I suspect that he had some other versions that were better, but these were out of print at the time. The factory diagrams are great - perfect clarity and a bit more detail. I am very happy to have both. Suggest that for the $25.00 bucks that you get the factory diagrams in addition (or maybe instead of) the last remaining color prints. There are several threads on the net that show more detail for certain portions of the system (pin numbers on relays and such). You can get lucky and find detail on what you are looking for sometimes. Good luck. |
914Sixer |
Nov 10 2015, 03:55 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
FYI, the Porsche factory diagram was never labeled. The Art Zapf is the ONLY one that has the information on it.
gereed75 |
Nov 10 2015, 05:05 PM
FYI, the Porsche factory diagram was never labeled. The Art Zapf is the ONLY one that has the information on it. I think that the color one that I got is not the best one. It is one printed over an image of a 914-6 (Art Show's class winning six from the 2012 parade). When I talked with him, he had none of the color ones that are shown on his site left. He may have gotten some reprinted since then, but he did not sound inclined to do so when I spoke with him earlier this year. If he has some of the B&W versions left they are excellent and all that you really need. |
0396 |
Nov 10 2015, 05:40 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Art and I got together for lunch last year. I asked him about his wiring diagram. Based on his comments, plan on getting the black / white ones and that's if he has any left.
Cairo94507 |
Nov 10 2015, 05:52 PM
Michael Group: Members Posts: 9,714 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I have sent surfer a PM re this. I may be able to help him out. I just have to find my diagram - I packed it when I sold the last house and it is still backed after moving to our new (old) house.
Nov 10 2015, 07:24 PM
I think Pelican may have the B&W ones on their Electric Diagrams page.
--DD |
gereed75 |
Nov 11 2015, 10:59 AM
Nov 11 2015, 11:43 PM
Good point--Art's stuff is the best!
--DD |
mharmon |
Nov 11 2015, 11:57 PM
Member Group: Members Posts: 129 Joined: 1-November 06 From: Los Angeles Member No.: 7,133 |
If I recall correctly the Factory 914/6 technical introduction booklet has a color wiring diagram that is labeled.
They are kind of hard to find but do come up from time to time. |
JeffBowlsby |
Nov 12 2015, 02:30 PM
914 Wiring Harnesses Group: Members Posts: 8,478 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
skier2.0 |
Dec 29 2015, 08:53 PM
Newbie Group: Members Posts: 34 Joined: 30-May 14 From: United States Member No.: 17,422 Region Association: MidAtlantic Region |
Jeff is correct I am looking at it now. Rick
larryM |
Dec 30 2015, 01:47 AM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
i have art's earlier edition laminated full-color diagram - no shadow watermark image on it
maybe he included the watermark to discourage bootlegging? (if memory serves, Art's first "color" diagram was B&W with the color names written on it) - maybe still have that one too and, yes. the oem factory repair manual set, section 9, has color "current flow charts" - i have got my set about 1993 as a "no longer needed" discard from the Stevens Creek Porsche parts department - both have been a godsend over the years - whatever diagram you have, even if only the one in the Haynes book - - take it down to Kinko's et al and enlarge to table-top size on a giant copy machine; so you can actually read & discern the lines, and make 2 copies, so you can write & color all over the first one . |
Tbrown4x4 |
Dec 30 2015, 02:26 AM
Senior Member Group: Members Posts: 702 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
First thing I do with any wiring diagram. Make a copy so I can write all over it. I use a highlighter on the circuit in question and write test results where I found them.
TedK |
Dec 31 2015, 08:34 PM
Member Group: Members Posts: 163 Joined: 1-August 07 From: Thousand Oaks, CA Member No.: 7,961 |
Mike Bellis |
Dec 31 2015, 08:38 PM
If it helps, I have color Zapf diagram, it measures about 17 x 21. I can't remember the details of how I acquired it - its been years. Looking closely at it, I can see its actually 4 letter-sized pages carefully scotch taped together. Showing a little age, but totally usable, readable, etc. Scan it to a PDF and attach the PDF here... |
TedK |
Dec 31 2015, 08:51 PM
I'd rather just fold it up and mail it. Its too big for any scanner I have access to. I suppose I could scan in four sections but not sure how much would be lost in translation.....
JeffBowlsby |
Dec 31 2015, 10:35 PM
Art Zapf holds a copyright on his work gentlemen...we should not be copying his work. His website says they can still be purchased.
0396 |
Jan 1 2016, 07:30 PM
Art Zapf holds a copyright on his work gentlemen...we should not be copying his work. His website says they can still be purchased. Jeff, Thanks for reminding those who simply want to get free work from Art's efforts. I'm sure if and when he finds out he's not going to be too happy with folks simply copying his work. |
Lo-Fi Version | Time is now: 25th April 2024 - 08:56 PM |
