somd914 |
Member ![]() ![]() ![]() Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region ![]() |
I was trying to find a tricked out Miata in the bumper reflection. Yah, he graduated last spring and is working on this side of the Bay, so you won't find the tricked out miata running around Salisbury anymore either. I'll stage a pic and send it your way... Salisbury, eh? I spent a fair amount of my time in Easton with my in-laws (and I know what you mean about summer temps on the Eastern Shore). I'm hoping to spend more time there at some point. No hill climbs, but fair number of twisty back roads that are probably fun in a teener. Yep, lots of twisties around here. Really flat. I work only 19 miles from where I live and it's virtually a straight shot by highway. I take the back roads every chance I get just for the turns. But speaking of summer on Delmarva...it's been very unseasonably warm here all month. Over 70 again today and the humidity is way up. The flies are back and some trees are budding. It's a bit strange coming up to Christmas and we're wearing shorts and T's again. Heck, I broke my motorcycle out yesterday. I'm over the other side of the Chesapeake from TargaToy, about 40 miles as a crow flies, but 160 miles via roads due to the Bay. Pretty much the same here, mainly back roads, flat. The best roads in the area are through the Mennonite and Amish areas, but the roads are frequented with buggies, bicycles, pedestrians, and littered with horse droppings - not a good area to enjoy driving. As mentioned, temps are crazy warm for this time of year - 60 degrees at the moment (5:45 AM) but the dew is like rain - soaked out there, and garage dehumidifier is pumping out August-like amounts of water. Hmmm, Porsche to work this morning and wash it when I get home...? |
Puebloswatcop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region ![]() |
I guess I am addict... Bought another '73, will pick her up next weekend. This one was a stalled project that sat for several years due to health issues. A friend of a friend who is a long-time reputable 356 mechanic/restorer purchased her (friends with the owner who started the project) and put her together sans new paint. I wasn't in the market, but this was one of those Cars and Coffee deals that I couldn't pass up. It's the proverbial SOCAL rust free car - yes, we've all heard that before, but the body is exceptionally clean and solid, had been re-sprayed at some point but trunks, door jambs, and underside are original paint. Engine is a fresh FAT Performance 2258 that outshines my 2056, new brakes, 5 bolt conversion, new suspension, re-chromed bumpers, wart removal, etc. Also comes with a large parts stash which I will likely sell most of it. Holding receipts for engine and parts north of $20k... Ravenna green isn't my favorite, but I will stick with it - not going the expense of a proper color change. Given the reputation of the mechanic who put it together, and given the overall condition, how could I say no? Am I crazy? More pics next weekend once I get her home. I know the addiction part, I now have 3. ! running, 1 a ground up restoration and another for parts....One can never have too many 14's |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Just basing it on what I've read and our 90-95 degree summer temps. Seems most feel for temps like this on the larger displacement engines an external cooler is needed, but this is new territory for me. Thoughts on a head temp gauge? One side or both? Head temp != oil temp. In fact, the two sometimes move opposite directions with load and RPM. If you're trying to figure out if you need a cooler, use an oil temp gauge. As for head temps, both sides is probably better than one. One may be better than zero, but only if you use a decent quality gauge. (Like an aircraft one; the common inexpensive VDO ones are not the greatest.) --DD |
somd914 |
Just basing it on what I've read and our 90-95 degree summer temps. Seems most feel for temps like this on the larger displacement engines an external cooler is needed, but this is new territory for me. Thoughts on a head temp gauge? One side or both? Head temp != oil temp. In fact, the two sometimes move opposite directions with load and RPM. If you're trying to figure out if you need a cooler, use an oil temp gauge. As for head temps, both sides is probably better than one. One may be better than zero, but only if you use a decent quality gauge. (Like an aircraft one; the common inexpensive VDO ones are not the greatest.) --DD Yes, I understand that head and oil temps are different, have to give some thought to the occasional inverse relationship. My plan is to replace the stock oil temp gauge and go with one that has temperatures on it's face rather than the simple red zone. Once summer hits I'll make a call on external oil cooler based on knowing what oil temps really are. Can say based on shooting an IR thermometer on various sump locations temps are reading in the 190 range with the factory gauge close to center. I also plan to look into dual aircraft head temp gauges as I've heard from other sources also that the VDO gauges are iffy and not temp corrected. Thanks for the feedback. |
Lo-Fi Version | Time is now: 29th June 2024 - 06:02 PM |
