mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,544 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Too much on my mind I guess. |
Bates |
Bates ![]() ![]() Group: Members Posts: 68 Joined: 27-December 13 From: Madison, Virginia Member No.: 16,800 Region Association: MidAtlantic Region ![]() |
Looking good Ben. I like the bottom brace, nice work. |
mb911 |
Thanks.. Making headway..
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,466 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
What would have been the reason it was brazed instead of welded by the PO? Up until MIG welders got affordable it was the fastest and easiest way to go. There's a few places on the car where the factory used brazed seams. A weld joint will stress crack where a brass will not. Years ago shops would braze a horseshoe shim on a dented panel to pull it out, they brazed it because done right, it won't fail. A good braze is also better than a bad weld. You wouldn’t believe how easy mig made things. |
mb911 |
What would have been the reason it was brazed instead of welded by the PO? Up until MIG welders got affordable it was the fastest and easiest way to go. There's a few places on the car where the factory used brazed seams. A weld joint will stress crack where a brass will not. Years ago shops would braze a horseshoe shim on a dented panel to pull it out, they brazed it because done right, it won't fail. A good braze is also better than a bad weld. You wouldn’t believe how easy mig made things. True for sure. So curious should the upper part of the door jamb be brazed? It was from the factory from what I see. |
mb911 |
mb911 |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Nice! But how can you call that ice fishing without a 3-bedroom "hut" on the ice with TV and satellite dish? What kind of person just braves the elements like that? (IMG:style_emoticons/default/lol-2.gif)
mb911 |
Nice! But how can you call that ice fishing without a 3-bedroom "hut" on the ice with TV and satellite dish? What kind of person just braves the elements like that? (IMG:style_emoticons/default/lol-2.gif) We sit in the cabin and look outside for the flags to pop up.. We got skunked but found this on our hike.I think it is left overs from grandpa's farm years ago. He farmed and was the local school superintendent.. ![]() |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Lots of cabins out on Lake Geneva and I don’t think any have fallen through the ice so far this year. It’s a great way to get through a Wisconsin winter (assuming you have some refreshing adult beverages to help you spend your time). Spring will eventually arrive, but it’s all about snow and cold this week!
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,842 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Nice! But how can you call that ice fishing without a 3-bedroom "hut" on the ice with TV and satellite dish? What kind of person just braves the elements like that? (IMG:style_emoticons/default/lol-2.gif) We sit in the cabin and look outside for the flags to pop up.. We got skunked but found this on our hike.I think it is left overs from grandpa's farm years ago. He farmed and was the local school superintendent.. ![]() Is that a 356 part (IMG:style_emoticons/default/confused24.gif) |
mb911 |
Lol I think its a an old school pulley..
Lol I think its a an old school pulley.. You said you buried a 912, I didn't know if it ran in the family. (IMG:style_emoticons/default/confused24.gif) |
mb911 |
Lol I think its a an old school pulley.. You said you buried a 912, I didn't know if it ran in the family. (IMG:style_emoticons/default/confused24.gif) Yup thats true.. |
mb911 |
mb911 |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,655 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Your body work looks very nice Ben.....you could make a 914 Ice Shanty to drive out onto the lake. Best, Mark
PS just spent Saturday at Sebring with the Accumoto Motorsports team, great fun. |
mlindner |
Ben, seeing your lower turbo valve covers. Have they been machined (modified) so removal is possible for valve adjustment with engine in car. Mark
mb911 |
Ben, seeing your lower turbo valve covers. Have they been machined (modified) so removal is possible for valve adjustment with engine in car. Mark Mark sounds like fun.. Almost finished accumotos heat exchangers for the headers they gave me.. As to the valve covers I did not.. I don't plan to do much valve adjustments while in the car.. I figure I will run on test stand etc then adjust valves then install in the car and it will take many years before I need to adjust again. |
bbrock |
Why do those butt welds look "different" to me? Any chance you are using EZ grind? I'm circling in on that same repair and hoping to poach your process to make it truly invisible. There is a spool of EZ grind sitting down at the welding shop but I haven't committed to buying it yet. Thinking I could use any little help on this one though. |
Lo-Fi Version | Time is now: 18th April 2025 - 05:20 PM |
