73 Pages V « < 27 28 29 30 31 > »
> 914-6 conversion/ rusturation GT style, EFI is done
whitetwinturbo
post Jun 25 2018, 09:38 PM
Post #561
.............just got a pair of anti-gravity boots to help watch this coo build (IMG:style_emoticons/default/smoke.gif)
mb911
post Jun 26 2018, 10:33 AM
Post #562
Here is Finished prototype for front oil cooler. It will have a foam rubber seal up front and rubber washers top to bottom.. Now to lay out trunk for cutting. Attached Image
mb911
Post #563
mb911
post Jun 26 2018, 10:34 AM
Post #564
mb911
post Jun 27 2018, 11:28 AM
Post #565
So I know welding is not done.. Making progress on the oil cooler though.. Happy about that.Attached Image
mb911
post Jun 27 2018, 11:29 AM
Post #566
bbrock
post Jun 27 2018, 11:40 AM
Post #567
Wow! The fab work is fantastic but what really caught my eye are those plug welds. They are works of art. Those will look just like spot welds after paint. (IMG:style_emoticons/default/smiley_notworthy.gif)
mb911
post Jun 27 2018, 11:58 AM
Post #568
QUOTE(bbrock @ Jun 27 2018, 09:40 AM) *
Thanks.
Also note how my car was clipped on passenger side.. I know we have reviewed that but this is why I feel this is a perfect car for the build.. If I had a virgin rust free car I am not sure I could do all this cutting etc.. I also would have worried more about metal finishing.
mb911
post Jun 28 2018, 05:47 AM
Post #569
Figuring out hose lengths.. Might neck down to 26mm cooler hoses. 30 is a tight fit..Attached Image
mb911
post Jul 6 2018, 12:20 PM
Post #570
Just got back from vacation and had some goodies waiting for me.
Thanks Mark E, Mark H, and Brad .. These are the last bits to get the engine started. Also not pictured is the 22 to 30mm fitting and the oil pressure gauge.
And picture fixed
mb911
post Jul 7 2018, 11:52 AM
Post #571
Distributor just came yesterday along carb gaskets etc. Yeah.. Attached Image
mb911
post Jul 11 2018, 09:42 AM
Post #572
Carb repair.. Drilled/tapped/loctite brass bushing for the drain plug.. Attached Image Attached ImageAttached Image
Who said welders can't be machinist (IMG:style_emoticons/default/wink.gif)
RektOne
post Jul 22 2018, 06:25 PM
Post #573
QUOTE(bbrock @ Feb 27 2018, 08:03 AM) *
QUOTE(mb911 @ Feb 26 2018, 07:10 PM) *
I have access to a small 5 gallon sized blaster.. Might try that.. I have a decent sized compressor that should work for the areas I need done..
I have the HF 40 lb. blaster and it works well. I'm using crushed glass for media. My only problem is finding a hood that doesn't cost a fortune and doesn't fog up. I just bought one on Amazon that got good reviews but I haven't tested.
We had a HF model for a long time. We recently upgraded to this wet blast cabinet: https://www.raptorblaster.com/wet-blast-cab...abinet-rb4836s/. Good visibility, and works great for removing powder coating.
mb911
post Aug 2 2018, 05:02 PM
Post #574
Today's update.. Finally got the factory replacement fender from Garold epoxy primed, got the flywheel on along with mounting the engine trans combo into the test run stand. Decided to just place the carbs and air cleaner on.. Good progress. Attached Image Attached ImageAttached Image
post Aug 2 2018, 06:00 PM
Post #575
914-6 GT in waiting
QUOTE(mb911 @ Aug 2 2018, 07:02 PM) *
Drop the engine down to the floor, glass top on the metal frame, your done.
mb911
post Aug 3 2018, 06:21 AM
Post #576
QUOTE(mepstein @ Aug 2 2018, 04:00 PM) *
Very true.. Lol
GeorgeRud
post Aug 3 2018, 09:09 AM
Post #577
Just have to correct the snorkel position to the other side of the engine and it’ll be perfect! Truly would make an impressive (though expensive) table!
toolguy
post Aug 3 2018, 09:31 AM
Post #578
QUOTE(GeorgeRud @ Aug 3 2018, 08:09 AM) *
It looks like the snorkel has the 'warm air' tube for 911 applications. .
mb911
post Aug 3 2018, 10:41 AM
Post #579
QUOTE(toolguy @ Aug 3 2018, 07:31 AM) *
Yup.. Gotta grear deal on it.
mb911
post Aug 7 2018, 09:06 AM
Post #580
Small project today.. Did get a great deal on some high quality semi H4 headlight housing for my eventual LED setup.. Attached Image Attached Image
- Lo-Fi Version Time is now: 14th December 2025 - 05:19 AM
