> more distuction pics, this time it's personal
scotty b
post Mar 11 2005, 07:49 PM
rust free you say ?
I laeft the house this morning to drop of a load of scrap metal and pic up some new stuff for some jobs. On the way home I hear this gnarly growl coming from the drivers front. Pull over sounds goes away. Get back up to speed (65) sounds gone, 2 miles later it's BACK and worse. Get off at the next exit, as I am approaching the intersection I find that I have NO, ZIP, ZERO, NADA, ZILCH, brakes (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Drop the truck into neutral, swing wide and coast to a stop.Look around,look under and find........nothing (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Put it in drive and coast up the road to a school, stopping via e-brake. Call AAA,cal my dad to bring his truck for the trailer and check the brake resevior........FULL?? Then I notice my pass wheel isn't straight,must be the damn wheel bearing! But out of the blue?? Got home rain starts two hours later I pull the wheel off and find over an inch of lateral play in the wheel?? Took 2 hours to get the wheel off because of an exploded Warn hub (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Inside of hub "now with metal chips"MMmmm MMmmmm good!
scotty b
post Mar 11 2005, 07:51 PM
rust free you say ?
still on the truck
scotty b
post Mar 11 2005, 07:53 PM
rust free you say ?
The two pieces on the ground are errrr were one of the bearings
TheCabinetmaker
post Mar 11 2005, 07:55 PM
I drive my car everyday
Glad your ok man. Brakes to the floor is scary stuff.
BTW, looks like its time for a new screwdriver. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
scotty b
post Mar 11 2005, 07:56 PM
rust free you say ?
NIIIICE
Resident German
(IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) glad it didn't lock up on you while you were doing 65 ...
scotty b
post Mar 11 2005, 08:01 PM
rust free you say ?
These are the larger pieces that I found (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) the black mass is about 3/4 of the chunks and chips that were in there
scotty b
post Mar 11 2005, 08:04 PM
rust free you say ?
Last one. The inner teeth are actualy filled up with fused metal. (IMG:http://www.914world.com/bbs2/html/emoticons/finger.gif) Warn. The hubs are only two years old and have maybe 6 months worth of drive time on them (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
scotty b
post Mar 11 2005, 08:07 PM
rust free you say ?
QUOTE (vsg914 @ Mar 11 2005, 05:55 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Whatchu talkin bout? Theres plenty of metal left on that screwdriver! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
SpecialK
post Mar 11 2005, 08:39 PM
aircraft surgeon
What caused the brakes to fail? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Blow out the slave cylinder on that wheel?
Edit: Okay....disc brakes (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) But the other 3 should've done something I would think.
scotty b
post Mar 11 2005, 08:48 PM
rust free you say ?
QUOTE (Special_K @ Mar 11 2005, 06:39 PM)
I havn't gotten that far yet. It got dark by the time I was done inspecting the hub and spindle. It actually would get a little (very very little) pressure if I pumped it. Right now I'm assuming the two are coincidental, (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) because I can't see how they could be connected. I'm guessing either the master cylinder is bad or something has obstructed the inlet side of the proportioning valve.I used to plow snow with this thing and it has caught HELL between that and towing. I'm going to replace the whole braking system... I think (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Mike9142.0
post Mar 11 2005, 10:54 PM
When the bearings failed the brake rotor tilted and pushed the piston in to the calliper.
When you pushed on the brakes it tryed to take up that extra space and went to the floor.
post Mar 11 2005, 11:32 PM
Resident German
QUOTE (Mike9142.0 @ Mar 11 2005, 08:54 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
or
your caliper blew up when the rotor hit it. overheated, blew out the seals and drained all the brake fluid.
i had that happen to the 914 once. not fun ...
(IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) Andy
Tom Perso
post Mar 12 2005, 07:24 AM
Crazy from the Cold...
Huh - Must be bad truck wheel bearing week...
I just had to replace both of my front wheel bearing hubs. Easy to do, just not light on the pocket... $130 each.
Oh - and the CV's that were attached to them. What a PIA.
2000 Dodge Dakota, 69,500 miles. Nice.
Later,
Tom
scotty b
post Mar 12 2005, 08:57 AM
rust free you say ?
QUOTE (SirAndy @ Mar 11 2005, 09:32 PM)
or
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Wrongo, reread my original post, I lost NO brake fluid and my rears went out also. I also checked all lines front to back and none are cracked busted or leaking.I could understand if only the fronts went, but the rears being on a seperate circuit indicates something wrong between the master cylinder and the prop. valve. I'm going to fix the wheel first and then attack the brakes. I also had a revelation last night on the reason for the hub/bearing issue. I think the c.v. joint in the axle (2piece, full floater) was wearing causing the outer axle to run around,thus eating the hub and bearing simutaniously (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Thoughts on that?
scotty b
post Mar 12 2005, 07:34 PM
rust free you say ?
Just for anyone interested (curious) Autopsy #1 is complete and the culprit for the hub explosion was the universal joint in the axle. (inside the steering knuckle) I had thought it was worn and wqas running wide...quite the opposite. One side had actually frozen so it was only moving in one direction instead of circular thus eating away at the bearing and hub. Sorry Warn for blaming you (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Part 2 of the autopsy will be perfomed on the braking system once the axle is fixed.(spindle,hub,outer axle, bearings)
Oh and the 924's price has been reduced for quick sale (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) No connection though (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
jwalters
post Mar 12 2005, 10:39 PM
Sooo Close.......
Region Association: Europe
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Dude--sorry to read about your day---glad you are still in one piece!
Man I can tell you that I have owned some real pieces of crap cars in my life ( read: Domestic ) but even on them my braking system always got a complete overhaul--don't care if it will only do 60--as long as it stops I am happy.
Were you plowing when it happened???
This is really good stuff because I went out to the skunk works and gave my steering universals a once over--guess what--the one connected to the wheel is locking up and when I pivot it around it ratchets like a ratchet----THAT is one universal I would hate to see let go when I am shittin and gettin it around an off ramp--( we don't have curves in SoFl....so I have to pick certain on and off ramps to exploit Black Sabbath's prowess.. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) )
scotty b
post Mar 12 2005, 10:48 PM
rust free you say ?
Nah ,I quit the plowing gig 3 years ago when I realized I was spending more in repairs to the truck than I was making with it! You can make a shitload of $ quick, and burn it up in parts even quicker. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) I did get my tranny done and paid for the diffs, so I guess there was some good in it.Plus running for 36 hours straight isn't for me (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
jwalters
post Mar 12 2005, 10:55 PM
Sooo Close.......
Think about the Steve Fosset fella---he did what? 79 hours straight???? oh my freeking head!@! Screw that--
In the navy while over in the med we did an exercise called ******-********* ( I could tell ya, but would have to kill ya )--just a plain vanilla training evolution--but it lasted for 9 days straight w/o stopping-- (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
- Lo-Fi Version Time is now: 2nd January 2025 - 07:31 PM
