Just soliciting ideas - tired of my /6 smell. |
matthepcat |
Dec 10 2015, 09:08 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I have owned a v8 conversion car. The "cut up" comment is not just the body. It's drilling holes, it adding/modifying wiring, it's modifying the transaxle and CV upgrades plus the modification of flares to fit bigger rubber.
Cost wise is always better to buy a stalled project, unless you plan to do an uber custom conversion. M This comment is too funny and often repeated ad nauseam regarding swaps. I have seen so many 914's with what appears to be roughly 25% of the metal cut away for restoration and repair - are you kidding me about the conversion cutting? Its absolutely minimal. With that logic, no one would be restoring them - just let them rot away. If I were you, I'd go to a 3.6 but even that wouldn't been as flexible or compliant as a nice LS motor. Just stop already with the lousy excuses over cutting cars. Hilarious it is... You have to determine if this car is your's for the long run...if so, those aircooled motors will be taking your money (forever). If you got it, no problem, you can feed the beast. The cost would be subtsantial to do a nice LS - basically a 15-20K deal to do it nicely - just keep that in mind. It takes a bit of time too. Go for the 3.6 - 3.2 would be my second choice (if I were you). Tony I agree with mepstein. Go 3.2...what do you have to loose other than money? Going water-cooled conversion would be better to start with a car than has been cut up for it already. Matt |
mb911 |
Dec 10 2015, 09:17 AM
914 Guru Group: Members Posts: 6,948 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have rebuilt hundreds of engines in my life and about 30 911 based engines over the last 10 years or so. The 911 engine itself is a very robust and typically are not big smokers unless they sit allot or in your case probably have aluisil cylinders and they tend to have issues with rings and will smoke. I used some QSC cylinders on my turbo build about 6 years ago and they were great. cost about 1k and bought them from supertec. I also used JE pistons. I drove the car a fair amount and it only smoked when it sat for extended periods but only for a few seconds. I ran a 3.2 intake with MEga squirt and it worked flawlessly. I did not smell like the car etc.
Now when I had carbs on a 2.7 of mine I always smelled like carbs.. I am a long way away from being ready to make any final decsions but I will probably do another 3.2 intake on what ever engine I decide on and do megasquirt or something similar. I am guessing carbs are the majority of your issues. Really consider ITB's or something else like that or swap a complete 3.2 in. The 3.2's are nice engines and as many have mention the cost difference is probably not a huge amount once you sell your 3.0 |
Justinp71 |
Dec 10 2015, 12:57 PM
Senior Member Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I recently rebuilt my 3.0 weber six, which did help some on smell but didn't cure the problem. Cured start up smoke.
I found out recently part of the problem is webers typically run 11.5:1 afr at a cruise which doesn't help. Also they are typically pretty rich at idle. A few tricks I've learned that help- When you first start up your car and its really stinky, rollup all your windows and leave the top on when you leave the house. Also buy an AFR gauge and tune your idle afr to be 14-15:1. These two items kept me from being a stinky bastard... You can also lean out your idle circuit some, but it will create a less desirable transition to the main circuit on the carbs... Another solution is PMO ITB's, if you have the time to dedicate it looks to take about 2 months to complete it as a weekend project and cost about $6-7k (and you can sell the webers) I considered a 3.2, but was concerned of the actual condition of the motor I'd get. Plus I love the sound and simplicity of carbs. If it were my daily driver I may have gone 3.2 for the efi perks. good luck! |
bretth |
Dec 10 2015, 05:09 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I have a set of Zeniths which I haven't run yet. Curious if they are any less stinky than the Webers in anyone's experience.
Brett |
patssle |
Dec 10 2015, 09:24 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
QUOTE Plus I love the sound and simplicity of carbs Yeah I just did some quick research. ITBs do look nice but certainly add some complexity to the car. My car has been stripped of non-essentials so it's about as basic as possible which I enjoy. But it's definitely something that warrants more in-depth research of what is needed to make it possible. |
mb911 |
Dec 11 2015, 07:03 AM
BK911 |
Dec 12 2015, 06:32 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Do a leak down test before anything else.
You have no idea if the engine needs rebuilding. Oil leaks are usually pretty easy to find and repair. Get everything clean, run the car, and look for fresh oil. |
barefoot |
Dec 12 2015, 06:50 AM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Some yrs ago I purchased a 1980 911SC with about 120K miles on the clock which had a bad oil leak. Turns out it was the oil pressure transducer that sits on top of the engine. This of course dripped down onto the H/E's. Could not get to it without pulling the motor. While I was in there, I pulled the heads & cylinders in order to inspect everything to that point. Had access to precision inspection equipment back then. The Nickisal cylinders still had cross hatch marks and were within OEM tolerance for bore size. The valve guides were also within OEM size, so all I did was a lap in valve job, new rings, pressure fed chain tensioners, and a gasket set. Got out pretty cheap other that jet hot coating the whole exhaust system. Of course this engine had the OEM CIS injection system, that yr was the first to use feedback from a lambda sensor wench helped me get the idle mixture correct.
Not sure which 3.0 motors ted the Nickles cylinders, but don't be too discouraged. |
Spoke |
Dec 12 2015, 07:46 AM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Is the smell an oil smell? I saw the question a few posts ago but not an answer.
I have a 2056 T4 with webers and I get the oil smell in the cabin with heat. I've tried to mount the crankcase breathers right on the carb filters. It helps but when I let off the gas the smell gets stronger. Trying to figure out how to get the air from the breathers to go 100% into the carbs. I'm close but still need some adjustments. |
Cairo94507 |
Dec 12 2015, 08:58 AM
Michael Group: Members Posts: 9,850 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Bruce (Flat6pak) on the Pelican site rebuilt my 3.2. Now, we have not installed it in the car or fired it yet, so I can only comment on working with Bruce. He was a terrific guy to work with and kept me well informed and updated throughout the project. We spent at least an hour on the phone talking about the build specs before he touched the motor. His advise is what I needed and relied upon to build an engine for my Six that would be bullet proof.
Now I did not want a "race" motor. I wanted a solid 3.2 with the original Motronic injection that would start and run perfectly every time. The only real upgrade to the 3.2 was the 964 cams and a custom Steve Wong chip. I would guess I am into the completed motor for <$11K, including purchasing the motor. I think that is very reasonable and hope that when Scotty installs it and turns the key it fires immediately and runs perfectly forever. I seriously considered a 3.6 for my car. But in the end I believed the 3.6 would be overkill for what I wanted. I am not going to be tracking or auto crossing my car. It is just going to be a fun street driver for mostly around town and some local trips. The 3.2 ticked off all of the boxes and the was that. OH, I found my 3.2 by placing a WTB in the Pelican classified section. A word of caution here. The motor was represented as being a slight smoker with 40K miles on it that had never been opened up. Now, I planned from day one at the minimum to split the cases and have it refreshed and resealed to provide me some comfort as to future performance and reliability. However, once Bruce got my engine it became clear it had been opened up before so we ended up doing more than expected to make it right. I am not mad about that, but a little upset the seller, a long-time Pelican member, misrepresented the motor. In the end, I am much better off knowing Bruce did a full rebuild as now I won't worry about the motor. Money well spent. |
Mark Henry |
Dec 12 2015, 12:26 PM
Not sure which 3.0 motors ted the Nickles cylinders, but don't be too discouraged. On the 3.0 there is a fin count method, You would have to look up the details. Doesn't work on most other sizes IIRC. On the sound/smell issues. besides other things mentioned above, I'd try a stock /6 air cleaner. Many say it's less noise, more power and not as much fumes. |
patssle |
Dec 12 2015, 12:55 PM
achman_73_2.0 |
Dec 12 2015, 03:25 PM
Newbie Group: Members Posts: 40 Joined: 28-October 13 From: NYC Member No.: 16,577 Region Association: Upper MidWest |
Justinp71 |
Dec 13 2015, 11:20 PM
Do a leak down test before anything else. You have no idea if the engine needs rebuilding. Oil leaks are usually pretty easy to find and repair. Get everything clean, run the car, and look for fresh oil. (IMG:style_emoticons/default/agree.gif) These motors can go for many miles. I pulled mine apart because of start-up smoke and decel smoke (was just going to do valve guides, but it turned into a larger project). |
horizontally-opposed |
Dec 13 2015, 11:26 PM
Advanced Member Group: Members Posts: 3,435 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Converted my car to a freshly rebuilt 2.2 six with Webers, and have to say I don't much care for the smell of fuel—which is now ever present if I bring the car home and park it in the garage, and we tuned these carbs on the dyno.
I suspect the smell might be reduced, but I also suspect we've really been spoiled by how "unsmelly" modern cars are. ITBs, or something else, sounds pretty appealing, to be honest. Pete |
PlaysWithCars |
Dec 14 2015, 01:45 AM
Senior Member Group: Members Posts: 528 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Is the smell oil or fuel? The Webers will certainly smell much more than a fuel injection system as they're vented to the air (especially with today's fuels). You may want to consider converting to a fuel injection system and sell the Webers to help offset the cost of the conversion. I personally would recommend keeping the Porsche engine in the car. This is the first question you need to answer for yourself, it leads to the options that will solve the root of the problem. FI is a great solution to fuel smell caused by carbs and there are systems that retain individual throttle bodies and the crisp throttle response you have with the carbs. They also enable a more precise fuel curve which helps with drivability, cold start, fuel economy, etc. If it's an oil burning smell then it's likely leaks like others have said and you can tackle most with limited mechanicing experience. Good luck and keep us posted. |
porschetub |
Dec 14 2015, 02:42 AM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Not sure which 3.0 motors ted the Nickles cylinders, but don't be too discouraged. On the 3.0 there is a fin count method, You would have to look up the details. Doesn't work on most other sizes IIRC. On the sound/smell issues. besides other things mentioned above, I'd try a stock /6 air cleaner. Many say it's less noise, more power and not as much fumes. Excellent points,I have researched this after buying my motor years ago and the late great Bruce Anderson had dyno'd a six with K&N and stock air cleaner,the K&N's lost 1hp over the stock filter and then theres the issue of fuming as mentioned. In the 914 there is also the issue of of rain water getting in the K&N's,not good for any engine (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) . |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:56 PM |
