Tool for adjusting the trigger-points of Bosch D-Jetronic, - suitable for all car brands with D-Jetronic and Bosch distributor |
nordfisch |
Dec 12 2015, 12:50 PM
Member Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
I once misadjusted a trigger-points-set believing in this would solve the problems of my car... the unit was still functional afterwards, but I didn't believe in it's reliability anymore.
I found this device many years later in my cellar, decided to readjust it and therefore did some re-engineering. The result was a tool you can control and readjust your trigger-points-set with. The trigger-points themselves don't show any wear. But the fibre rubbing blocks are being grinded down when gliding on the distributor-camshaft, especially when this has become rusty or the original small amount of grease has been gone away. You can adjust even heavy worn trigger-points without any electrical function to the original values by using the tool, that simulates the bottom of the distributor-camshaft. The lifetime of the trigger-point-unit can be prolonged about two additive times this way. This new version is designed to work with the new trigger-points-sets with the plastic hoods covering the points, too. The tool has been well approved in four continents now - no reason to change anything on it in the future. You need a lathe to produce the tool by yourself. Registered users will get a figure - free for non-commercial use only - completed with the dimensions, on request. I don't want this figure to be published in a forum anymore. D-Jetronic is my hobby and I have no financial interest, but not everyone has a lathe to produce it by himself, therefore I have some ready-produced tools in stock most of the time. I can ship the tool worldwide for $ 20.-, shipment included. For further information / questions / additions post to this forum or contact me via PM. How to use the tool for adjusting the Trigger-points of the D-Jetronic The model-specific flute (notch) of the tool has to be pushed into the noses of the base-plate of the points-set or the base-plate itself. This flute centers the tool to the same position as it were in the distributor. This allows exact and symmetric adjustment. Because there exist base-plates in three different thicknesses, the matching flute has to be chosen (figure below!): 1 - On the top a flute for Volkswagen, Porsche...? 2 - On the bottom a flute for base-plates-sets with 3 'noses' (Opel, Volvo, Lancia, Fiat, Citroën, Mercedes - R6, BMW, ...?) 3 - On the second position from bottom a flute for Mercedes – V8 The figure below shows the tool in position (points set type '2'). 1. Adjust space between tool and fibre rubbing blocks to 0.02 in (0,50 mm) in this position by bending the sheets of the anvil-plate with flat-nose pliers, checking with a feeler-gauge. 2. By inserting a feeler-gauge of 0.04 in (1,00 mm) instead you can check the points in fully-opened situation. The points gap will be 0.03 in (0,75 mm) if correctly adjusted. Adjusting the points has to be approved with sense, power and skillfulness. I used flat-nose-pliers and after some trying out got exact adjustments. You have to take care of the following: 1. The tool has to be pushed into the the trigger-unit all the way up to the stop. Some turning the tool and trying again may help, perhaps a little grease will help. The tool has to fit exactly, therefore the tolerance is minimized. 2. The anvil-plate of the points is mounted insulated, therefore may have some tolerance towards the base-plate. After adjusting one side of the trigger-points-pair, you have to control the opposite side. Maybe you have to re-adjust this a couple of times. But: The D-Jetronic is not a direct injection system. You need not try to adjust the points too precisely. Adjustment to 0.02 in is the optimal value cause then all possible tolerances are adjusted to the average. Even new original trigger points have some tolerance, as I found out. Take care the points are absolutely clean, no grease or oil remains between them. Control the distributor-camshaft isn't rusty or worn-out, scratched You essentially have to grease the fibre rubbing blocks by applying a very small amount of points cam grease when re-installing the trigger-point-unit also. You use this tool at your own risk. It has not been approved by the OEM. Using the tool, you accept this term. (Tool Ver 3.1Xen © 10/2014) Norbert Fischer |
JeffBowlsby |
Dec 12 2015, 07:51 PM
914 Wiring Harnesses Group: Members Posts: 8,783 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hi Norbert, I would like to order one of these tools. Let me know how to pay you (send me an email or PM through this forum). Many thanks.
nordfisch |
Dec 13 2015, 06:51 AM
Hi Norbert, I would like to order one of these tools. Let me know how to pay you (send me an email or PM through this forum). Many thanks. Hi Jeff, you could transfer the money via PayPal. I then need your full postal adress. The customs have never been a problem up to this time, shipment will last about 10 days in normal times. But now is Christmas time, postal services maybe overcharged. Send you a PM. Regards Norbert |
McMark |
Dec 13 2015, 12:13 PM
PM me a PayPal address as well. I'll take one.
Krieger |
Dec 13 2015, 12:22 PM
Advanced Member Group: Members Posts: 4,771 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Nice! I'd like one too. Please PM a Paypal address.
jmalone |
Dec 13 2015, 06:27 PM
Member Group: Members Posts: 119 Joined: 3-July 09 From: reno,NV Member No.: 10,529 Region Association: Northern California |
Thanks for doing this. I would like one as well. Please send me your PayPal info.
DRPHIL914 |
Dec 14 2015, 07:58 AM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
This is excellent since the original OEM points are now no longer available!!
I'll take one as well |
BillC |
Dec 14 2015, 09:42 AM
Senior Member Group: Members Posts: 579 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
This is a great idea. I would also like to order one. Please send me a PM with your paypal info. Thanks!
nordfisch |
Dec 16 2015, 07:17 AM
Hi,
I now shipped all the tools. Would like to get informed, when they arrive. Best Wishes and a Merry Christmas (IMG:style_emoticons/default/santa_smiley.gif) from Germany Norbert |
DRPHIL914 |
Dec 16 2015, 07:19 AM
Hi, I now shipped all the tools. Would like to get informed, when they arrive. Best Wishes and a Merry Christmas (IMG:style_emoticons/default/santa_smiley.gif) from Germany Norbert Norbert, I just sent you payment for mine, sorry I forgot to do this last night, but you should have funds in your account as we speak!! thanks Dr. Phil |
ndfrigi |
Dec 16 2015, 11:06 AM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi Norbert, do you still have 1 set of this tool?
pilothyer |
Dec 16 2015, 12:16 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
If you have more, I would love to have one...........Jerry
ssuperflyoldguy |
Dec 23 2015, 11:14 AM
Member Group: Members Posts: 173 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
I would like one also, I'll send you a request via pm. Thanks for making this up, really appreciate.
BillC |
Dec 24 2015, 06:26 AM
Mine arrived last night, and it's very nice. Thanks! (IMG:style_emoticons/default/beerchug.gif)
liebe |
Dec 24 2015, 06:45 AM
Newbie Group: Members Posts: 17 Joined: 10-April 12 From: Spain/Houston Member No.: 14,357 Region Association: None |
Norbert i would also like one too please |
nordfisch |
Jan 13 2016, 01:00 PM
Hi,
two users informed me they did not receive the tools I shipped last year immediately after having received the payment up to this time. I can't track the letters I ship as 'Priority Mail'. Maybe they are still at the customs, maybe they got lost in Germany... Please inform me if you didn't receive the tool you ordered and paid, too Regards Norbert Fischer |
914werke |
Jan 13 2016, 01:05 PM
"I got blisters on me fingers" Group: Members Posts: 11,036 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
PM sent
Old Yella |
Jan 13 2016, 05:54 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
Bet they'll arrive, takes forever from Europe sometimes.
DRPHIL914 |
Jan 13 2016, 09:33 PM
Got mine, thank you!
McMark |
Jan 14 2016, 04:28 AM
Got mine awhile back. Took me a minute to remember what the heck I ordered.
Lo-Fi Version | Time is now: 2nd January 2025 - 10:03 AM |
