veekry9 |
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada ![]() |
A trip to the wreckers,an old rusty crank brought to new life by dirty '30s tech.
A little pickle to remove the rust,then a shoestring polish. All of this came from before,the T Fords and babbit bearings. This low level flying,or retrotech can be applied to your VW crank if you are looking to stroke for a larger displacement. A few passes of weld,turning and grinding,and presto,a piece of work.For the all hands on deck type of machiner. https://www.youtube.com/watch?v=j7DZxqPUQto http://175.103.60.140/globalindo/carbon-st...cst60aisi-1045/ An entire industry was built out of this,this enterprising approach to the make it better cheaper and faster equation. (IMG:style_emoticons/default/biggrin.gif) http://www.hotvws.com/catalogs-2013/2/ / https://www.youtube.com/watch?v=6lfpip4u-pA / |
Darren C |
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England ![]() |
I appreciate the contributions to this thread very much, but you guys are seriously mixing PhD-level lathe processes with middle-school, with high-school, with 2nd grade.... Right now, I'm in lathe Kindergarten. Let's keep it on that level for the moment. I've always been a quick study, but I didn't start my flying career by sitting down in a jet. (IMG:style_emoticons/default/smile.gif) You're most welcome, When I get home from Work this evening I'll take some pictures of some of my lathe tools to explain "rake angle" and post them. In the meantime, my worry is that a loaded gun left in Kindergarten is just as likely to harm as one left in high school in naive or untrained hands. |
veekry9 |
http://www.914world.com/bbs2/index.php?sho...73101&st=52
The details of the'Hopping Herbert'is entertaining to some degree. Must have been late'70s,an aquaintance of the shop owner,looking for work,I suppose the music biz not panning out. A simple collet chuck turret lathe series of operations. https://en.wikipedia.org/wiki/Oxygen-free_copper Copper alloy bar 1-1/2"dia X 20'length. Well,neglecting to clamp the barfeeder clamps,the bar,unencumbered,began flapping around the back end of the heavy lathe. From the other side of the shop,I saw the heavy'wire'create a giant spiral whipping about at high rpm. Crossing the plane of the whirling,hopping mass,I stopped the spindle,again. The unbalance of the unique creation had been lifting the Herbert almost a foot,noisily. When I released the collet,the Danish bun looking thing came out without breaking,the plasticity of the material saving us. Had it broken,the spinning wheel would have raced around the shop wreaking havoc at 1200 rpm. Needless to say,that ginger was frozen in fear,the ashen pale look on his face said incomprehension. A common household 12ga wire might show the same results if spun up in a hand drill. / Safety: Brings to mind the'starting plane',that,which is directly in line with the chuck and work. Always stand clear of the projectile plane,when starting the spindle,ensure no tools can fall off into the spinning chuck or work. A place for tools is in safe areas only,secured. Make a box for them as required. / |
Darren C |
Ok……home from work now.....
Lets get down to basics…. There are 6 important angles to understand on a simple HSS lathe tool. The best illustration I can find is this. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1456173478.1.gif) Looking down on the tool you have front and side cutting angle. This relates to cutting in line with the lathe or across it (turning down or facing off). These angles can be set or fixed by grinding the tool or by clamping the tool post at differing angles. Back rake and side rake are in the horizontal plane and I think were the ones perplexing you? These refer to the top surface of the tool. It can angle downwards to left or right (side rake) in LH or RH tools and angle back towards the lathe operator (hence back rake angle) Side relief and front relief are in the vertical plane, and hopefully self explanatory in the picture above. I have been making lathe tools for over 40 years and I’m a qualified toolmaker for my sins, yet I'm still learning stuff. Here’s a few home made basic samples in “proper” High Speed Tool Steel. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1456173478.2.jpg) This is what good old fashioned HSS lathe tools should be like. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1456173478.3.jpg) The tool steel is purchased as a bar (far right in photo) and you precision grind it by hand, sometimes to within + or – 1 thousandth of an inch where the rake angles are hand ground to minutes of degrees. Today however these skills are lost and most lathe users are NOT tool makers, just tool sharpeners and the majority are blissfully unaware of what a true tool maker can do. Most HSS lathe tools today are like this…. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1456173479.4.jpg) Only a small amount of quality HSS is brazed or welded into a poor quality steel holder. The tip is only HSS. These come in all shapes and sizes. But fundamentally they’re pre made so you don’t need to grind any angles or profiles, just dress them on a stone to keep them sharp. I’m not sure what you have with your lathe, but this is just a real basic guide/help for you to understand simple tool shape. The possibilities of shape and angles are limitless. Understanding what the correct angle on all 6 planes takes years to master and is variable on material, speed and feed. Hopefully that’s helpful to you for now. Ceramic or tipped tools are another thing altogether with usually zero apparent back and side rake. Here’s one I set in my lathe tonight to show zero rake. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1456173479.5.jpg) My advice is start with some basic HSS tools, learn and understand how they work before going on to tipped tools. Plus get yourself on a basic lathe class! |
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
That is incredibly helpful.
The amount of time you spent on that for me is greatly appreciated. Thank you. |
Series9 |
Attached image(s) ![]() |
Series9 |
This is the tooling that came with the lathe.
I've been operating on the assumption that you "get what you pay for" with this stuff. I have successfully turned some pieces and I've also destroyed some tools. I'm not afraid to spend some money on high quality bits. I'm looking at carbide and ceramic. Attached thumbnail(s) ![]() |
Darren C |
Ok, you got a fair mix there..
(IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1456222810.1.jpg) Some are no good, others need work and just a few are useful to you as a beginner. I’ve numbered them so you know which tool I’m referring to. 1. Parting tool HSS and Holder. (very good, keeper. Get it sharp, grind the correct front relief, very tiny side relief and no side rake. A medium back rake will see you through most materials) A very good basic and useful parting tool. As it wears you re-grind and move the HSS steel forwards. ALWAYS set the tip contact with the job at dead centre height or ever so slightly low. NEVER go above centre height. 2. Plain Parting HSS (looks to be too wide for holder 1, you may need another holder for this) 3. Resolution on photo poor, but looks like a badly ground/messed up HSS parting. Cut off re-grind and start again with a suitable holder. (may fit same holder as 2) 4. Including 9, 16 & 30. HSS tool holders for smaller maybe what looks like ¼ or 3/8 HSS. You buy the HSS as in my first photo of the early rake descriptions and grind whatever tool you need. Very good old tool holders worth their weight in gold but too advanced for you for learning without good HSS ground tools to fit them. (keepers. Put them in your tool drawer for the future and get a new locking screw for 30 it looks a little chewed up) 5. Including 6 are RH knife tools profile for bevel turning steel Side & Front cutting angle too steep for straight turning and facing off steel, but ok with brass & aluminium. 7.Including 24 & 20 LH knife tool uses as for 5 & 6 above. 8. Including 10, 14, 22 & 23 Ream tools. I doubt you’ll ever need these. 11. Including 17 from the poor resolution photo look like unground tool steel. (put them in a draw for the future) 12. Including 18, 25 & 26 RH Knife tools. These have better side and front cutting angles for steel but they look well used and poorly re-ground. This is the sort of shape tool you need as a beginner but unfortunately these four look in a poor condition and need grinding work to restore them. 13. Including 27 are LH knife tools but old 13 looks useable as 27 needs a re-grind like your RH knifes. 15. Knurl tool. Good basic tool. Check the wheel spindle pins aren’t worn and the wheels are firm and don’t wobble or side in the shaft as any movement will make for a "double" inprint knurl. Plus also check the knurl profile is sharp. They do get worn down over the years and then they’ll be no good. 19. RH facing tool, looks badly ground on top surface back and side rake. Profile looks ok for facing off, but rakes need re-grind. 21. Including 28 & 29 are HSS thread cutting tools. Again these are not for you at this learning stage, stick them in the drawer for the future. Overall you have a reasonable selection of tools but none are really up to scratch for using successfully. Try and find a good machine shop or college nearby, take them in and get someone who knows what they’re doing to re-grind them for you. This shouldn’t cost too much money (may be just a crate of beer) and will be far cheaper than buying carbide/ceramic tipped tools and holders that you’re not ready for just yet. You only need 1, 18 & 19 to learn with at an early stage. Good choice on new tool post, very handy for setting tool height easy without shims under tools. |
Series9 |
Fantastic information. Some of the tools have a wax-like protective coating on the tips. That's probably what you're seeing as "poor resolution".
mbseto |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,255 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States ![]() |
This is turning into a pretty cool thread!
(see what I did there?) |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
I haven't tried using carbide on my lathe so take it for what it's worth, but there are a number of disadvantages to carbide.
I'm not sure how fast your machine will turn or if it's got the horsepower to sustain recommended feed rates at higher speeds, but I can say that mine doesn't come even close. Carbide doesn't like sudden changes in temperature, which means running full coolant is preferable. If you stall out your spindle which carbide, you are going chip your tool. In my experience running production lathes with indexable carbide tooling, it's just a different word as far as rigidity. HSS is going to be much more forgiving of chatter, any flexation. Also the nature of using turn screws to manually feed vs even a jog wheel much less cnc control makes hss seem more at home on a toolroom style manual lathe. HSS can be sharpened easily in whatever grinder, carbide is going to be more difficult to sharpen. At lower spindle speeds of a manual lathe, you're going to chip and dull carbide bits a lot more than if you could go 3x faster, which is where carbide shines. There may be a sweet spot for heavy cutting if you are turning large material (high surface feet per minute) where a carbide insert tool would be handy, but it will probably come down to if your lathe has the heft to maintain that. Like I said, stall the spindle and you'd be flipping the insert. We never ground carbide when I did production. With indexable turret style tooling, you flip the insert when it gets dull. Each insert has like 2 -4 sides, and they are expensive, like $20 for each insert - and you don't buy just 1. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.sixstarhardmetal.com-11782-1456237590.1.jpg) So problems with carbide are need to run flood coolant ideally, not enough spindle speed, not enough spindle power at higher sfm, difficult/not possible to sharpen depending on what style you get, and more expensive. Like I said, I don't have any carbide tooling for my little lathe. Based on my reading/research, it wouldn't be worth it. |
Series9 |
This is turning into a pretty cool thread! (see what I did there?) (IMG:style_emoticons/default/sunglasses.gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
http://blog.cnccookbook.com/2016/02/17/peck-parting-lathes/
More info on parting. Yes the story is mainly for CNC, but still some good reading. Also check out the comments as there is some good information there as well. |
Darren C |
Fantastic information. Some of the tools have a wax-like protective coating on the tips. That's probably what you're seeing as "poor resolution". Again you’re most welcome! The wax on the tool ends comes on new HSS tools to protect them in transit and storage, so hopefully if the cutting edge is intact, they should be good to go. As Nathan says Carbide, Ceramic tool tips come in box sets 6, 10 12 etc and at $20 a tip it’s a big initial expense. You also need the correct tool holder that can be anything from $50 to $200 to fit them in. Yes you flip them once the edge is chipped so you get 2 or 3 cutting sides per tip but you CANNOT sharpen them, just throw them in the trash can. Speed, feed, material, angle and depth of cut need to be right for these type of tools (as Nathan has said) they chip and break real easy. Generally used for high spindle speed turning 1000rpm upwards by operators with a good knowledge. This is why I’m steering you away from this type of tool as a beginner. Besides you can do pretty much everything you need at home with HSS tools for less cost and lower lathe speeds. |
Series9 |
Here's a close up of some of the tools that were unclear in the larger picture:
Darren C |
The top two have most probably been ground for detail undercutting or for cutting a square thread. I’m drawn more to under cutting due to the side clearance. Both are RH tools which cut using topslide (in and out at 90 degrees to lathe only) An example of undercutting would be where you make a machine thread or basic bolt and a small area under the bolt head is undercut to the thread core diameter for the thread tool to exit into at the end of a cutting stroke. Or basically the area at the end of any machine cut thread (particularly against an obstruction like a bolt head or shoulder) that has no thread.
Basic Bolt threads that are rolled not machine cut, don’t have an undercut. DONT be tempted to try and part off using these tools, they're not going to be strong enough or have the correct clearance angles and relief. The bottom larger tool is a LH knife. Looks a nice tool, good for turning steel (has a good side and front angle for steel) ideal for turning and facing off in a LH situation. |
Series9 |
CAUTION: THE FOLLOWING CONTENT MAY HAVE ENTERTAINMENT VALUE.
So.....my titanium wedding ring has always had annoying sharp edges at the top. I know you told me to not put the small chuck in the large chuck, but it helped me solve my problem. My ring is much better now. Chamfered on both edges, nice and smooth. (IMG:style_emoticons/default/happy11.gif) Attached thumbnail(s) ![]() ![]() |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Divorce coming soon?
Series9 |
Darren C |
I'd have kept the sharp edges....
In the same way as those dog collars that gives the dog a small electric shock so it knows when its done wrong.... :-) |
Lo-Fi Version | Time is now: 30th June 2024 - 12:28 PM |
