| stugray |
Jul 5 2016, 07:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I checked each one so I could measure for each rod and cut them to exact length individually. I measured them all and found the average and cut them all to that length. I didnt want to have to keep rods with certain valves. And regarding the rocker ratio: If you know the cam lobe lift and now measure the valve lift, you can calculate the ratio. If you felt like measuring it now, measure how much vertical motion you have on the pushrod with a second dial indicator while measuring the valve lift: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1355972519.3.jpg) I used a tiny clamp on the pushrod When I did this the first time I was given the lift at the cam and had to determine that the valve lift was within the 5% of predicted, but then you need to know the rocker ratio to at least two decimal places.... |
| sdoolin |
Jul 7 2016, 10:43 AM
Member ![]() ![]() Group: Members Posts: 423 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
| sdoolin |
Jul 10 2016, 08:11 AM
I've gone over the top again. I didn't like the way the swivel foot adjusters were lining up on the valve stems. First pic shows how the #1 intake swivel foot is not even covering the entire valve stem...
Pretty much all of the valves were like this, with the intakes being farther "off" than the exhausts. Back to the lathe to make each of the rocker shaft clamps slightly oval allowing them to move the rocker(s) over on the shaft... Each clamp was cut in the neighborhood of .5mm, one set was cut .75mm. This got the swivel foot adjusters nicely aligned with the valve stems (picture in next post). Note they are still slightly off center which may allow for the swivel foot to spin the valve, but I'm not sure that spinning the valve even happens with the swivel foot adjusters? |
| sdoolin |
Jul 10 2016, 08:13 AM
| Montreal914 |
Jul 10 2016, 11:39 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,192 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Isn't that mis alignment there so that the valve is actually rotated over time as it is being opened? (IMG:style_emoticons/default/confused24.gif)
| sdoolin |
Jul 11 2016, 12:59 PM
Isn't that mis alignment there so that the valve is actually rotated over time as it is being opened? (IMG:style_emoticons/default/confused24.gif) Yes I believe that is the reason for the "mis-alignment", and why I left them somewhat mis-aligned. Though I don't see how the swivel foot adjuster is going to be successful rotating the valve. Maybe it does, I just don't know... |
| jcd914 |
Jul 11 2016, 05:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Isn't that mis alignment there so that the valve is actually rotated over time as it is being opened? (IMG:style_emoticons/default/confused24.gif) Yes I believe that is the reason for the "mis-alignment", and why I left them somewhat mis-aligned. Though I don't see how the swivel foot adjuster is going to be successful rotating the valve. Maybe it does, I just don't know... Yes the off set of the rocker is by design not a manufacturing error. The rocker pushing off center causes the valve to rotate slightly each time it is opened, this helps keep the valve and valve seat clean. Jim |
| sdoolin |
Jul 28 2016, 06:41 AM
Life has gotten in the way of this project for a few weeks, traveling for work and all. I believe I have finally arrived at a happy place with respect to pushrod length.
Cyl IN Lift EX Lift 1 0.449 0.427 2 0.451 0.426 3 0.452 0.416 4 0.450 0.423 Note 1: All with thickest rocker shaft spacer Note 2: All with 10.754" pushrod All of those lift numbers are within the +- 5% range suggested by Raby. Also all adjusters nicely aligned with the valve stem at half of measured lift. I still plan to measure valve - piston clearance before final assembly. It does seem like the swivel foot adjusters may contact the valve covers, I still need to measure that. |
| sdoolin |
Aug 8 2016, 11:29 AM
| Dave_Darling |
Aug 8 2016, 12:33 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,358 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
How about with the valves opening? Or am I jumping ahead too far?
--DD |
| sdoolin |
Aug 8 2016, 12:39 PM
| stugray |
Aug 8 2016, 12:55 PM
Did you measure cam lobe lift before you installed the cam?
Just curious. And the valve clearance seems a little close @ 2mm. That is ~.080. I seem to recall someone telling me they liked no less than .120, but I would have to check my notes, so don't quote me yet. And my final length on pushrods was 269.5mm (10.61 in.) |
| draganc |
Aug 12 2016, 06:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
sorry for the OT request: can you post a pic of your Ducati frontend setup. i'm curious what you did to the caliper mount(s). I tried to zoom into the pics but it's either covered or blurry.
| barefoot |
Aug 13 2016, 05:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,546 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Did you measure cam lobe lift before you installed the cam? Just curious. And the valve clearance seems a little close @ 2mm. That is ~.080. I seem to recall someone telling me they liked no less than .120, but I would have to check my notes, so don't quote me yet. And my final length on pushrods was 269.5mm (10.61 in.) Just got my WebCam #494 and measured lobe lift at .345". WEB card says valve lift is .465" so they assume a rocker ratio of 1.347 |
| HAM Inc |
Aug 13 2016, 06:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
In most of my experiences degreeing T4 cams and setting geometry the intake ratio came in around 1.33 and the exhaust around 1.29.
For years most cam manufacturer used a factor of 1.3 for intake and exhaust. When we prep heads we set valve spring coil bind limits for any given cam based on my findings. |
| stugray |
Aug 13 2016, 01:08 PM
In most of my experiences degreeing T4 cams and setting geometry the intake ratio came in around 1.33 and the exhaust around 1.29. For years most cam manufacturer used a factor of 1.3 for intake and exhaust. When we prep heads we set valve spring coil bind limits for any given cam based on my findings. Thank you! You might recall my thread about rocker ratios. I got my ass chewed by people telling me "Just use 1.3 like everyone else!" (IMG:style_emoticons/default/shades.gif) They must not understand that to get within the 5% valve lift that Jake advertises that you MUST achieve (that is 0.05) you need more than TWO significant figures! So there is a big difference between 1.29 & 1.33 when trying to calculate valve lift to THREE significant figures. And my webcam 86b has an advertised valve lift of 0.500/0.500 I measured the cam lobe lift before installation and got 0.365/0.365 So for them to make a cam with 0.365 lobe lift and advertise 0.500 valve lift (.500/.365 = 1.37) they used 1.37 for their rocker ratio. I installed the cam and measured .504/.475 so the rocker ratio in my engine is closer to 1.38 I/1.30 E. |
| sdoolin |
Aug 15 2016, 07:21 PM
sorry for the OT request: can you post a pic of your Ducati frontend setup. i'm curious what you did to the caliper mount(s). I tried to zoom into the pics but it's either covered or blurry. Happy to post Duc pics. I made the Brembo mounts such that I could go back to the APs if ever needed, keeps value in the bike. The forks were not modified at all. I think they are kinda fugly, but they sure do work. Note that the pads don't sweep the entire rotor so there is some rust that develops on the inside "ring" of the rotor. Scotchbrite was invented to fix that. Pic... |
| sdoolin |
Aug 15 2016, 07:31 PM
| RoadGlue |
Aug 15 2016, 07:32 PM
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,034 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California
| sdoolin |
Aug 15 2016, 07:36 PM
Lo-Fi Version | Time is now: 12th September 2026 - 12:43 AM |
