4 Pages V < 1 2 3 4 >
> Pictures of 914s running 7 inch fuchs at both ends, Open the kimono
maddin
post Jan 26 2016, 02:05 AM
Post #41
Region Association: Australia and New Zealand
Great topic! I now know what I want..16x7 it is! :-D
Mueller
post Jan 26 2016, 10:30 AM
Post #42
914 Freak!
I know not Fuchs....
16x7 with 205/50-16s
53mm offset and 20mm to 25mm spacers (will have to confirm for sure) with would give an effective offset of 33mm to 28mm offset which is still 5mm more inboard than the Fuchs with a 23mm offset.
Previous owner installed them, the rear fenders look stock but I think the rear trailing edge might have been tweaked a little, I'd like to compare with a bone stock car one of these days.
Mueller
post Jan 26 2016, 10:31 AM
Post #43
914 Freak!
For the Fuchs, I know a few members have actually modified the rear trailing arm to move the hub inboard 15mm or so.
brant
post Jan 26 2016, 10:51 AM
Post #44
here is a picture of how much pulling, cutting, and welding it took to fit 15x8's under the rear:
(test wheel was a 5.5 x 14)
Alapone
post Jan 26 2016, 11:25 AM
Post #45
I have 16x7 rear and 16x6 up front? I went with 205/40/16 all around has anyone else done this? The lowest profile in this thread is 45 I think.
I am trying to find out what is the highest profile I can go to without anything more than a gentle rolling for the fenders.
malaga_red75
post Jan 26 2016, 05:12 PM
Post #46
'74 2.5L N/A Subie
QUOTE(bradtho @ Jan 25 2016, 06:28 PM) *
QUOTE(malaga_red75 @ Jan 25 2016, 05:34 PM) *
16x7 with rolled rear fenders.
this car looks great! why have I never seen pics of it before? maybe I need to spend more time reading our site!
I haven't posted in a while, and mostly lurk now. But I have a build and paint thread on here somewhere...
whitetwinturbo
post Jan 26 2016, 09:27 PM
Post #47
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
914Timo
post Jan 27 2016, 12:52 PM
Post #48
Region Association: Europe
7x15 911R Fuchs and 205/55 tires.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i125.photobucket.com-137-1453920727.1.jpg)
7x16 Fuchs with 205/50 front and 205/55 rear. Rear trailing arms 20mm narrowed.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i125.photobucket.com-137-1453920727.2.jpg)
3d914
post Jan 27 2016, 01:12 PM
Post #49
QUOTE(bradtho @ Jan 20 2016, 09:00 PM) *
15x7 w/ 205/50 (could be 55, can't remember and out of town right now) all around. Like everyone else, stock front fenders, had to pull the rears, but Mark at Eurotech Bodywerkes did such a great job it's hard to tell. Rear driver side is super tight, but no rubbing after a year and a half. Front struts have raised spindles.
PM me if there's some specific angle you're after. I took a full set after I got my car painted.
I love this color! Sooo unique. Enjoy!
(Weird - quoted images show up in preview, but not in post!)
Alapone
post Jan 27 2016, 03:13 PM
Post #50
how much more are 16x7 worth than 16x6?
Mueller
post Jan 27 2016, 04:41 PM
Post #51
914 Freak!
QUOTE(Alapone @ Jan 27 2016, 01:13 PM) *
I thought the 16x6 are worth more...the easily fit a 914 narrow body and it "the" Fuch to use when making a set of 3 piece modular rims using Fuch centers.
914_3.0
post Jan 27 2016, 06:23 PM
Post #52
15x7 front, 15x8 rear w/1" spacers
puffinator
post Jun 5 2016, 08:28 AM
Post #53
15x7 Fuchs with 195/65 Dunlop SP 5000
23e Heure
post Jun 10 2016, 11:31 AM
Post #54
Busy overtaking 911s
Region Association: England
QUOTE(puffinator @ Jun 5 2016, 03:28 PM) *
Thanks for reviving the thread, that's one great looking car.
Now... who can show me cars running 15x6 on the front with 15x7 on the rear?
JRust
post Jun 10 2016, 01:19 PM
Post #55
My old v8 car. Ran 951 fuchs on it 7x16 up front & 8x16 in back. 225,40,16's in back. This is with the rear fenders pulled & rolled. I had run 911 7x16's on all 4 corners before this with only the rear fenders lips rolled. Ran 214/45/16's on those with no problems.
DBCooper
post Jun 10 2016, 01:42 PM
Post #56
14's in the 13's with ATTITUDE
Just for some perspective most of these cars, including mine, had the rear fenders "pulled." That's not always simple. Pulling mine cracked the paint, making me realize too late (DOHHH!!) that I should have heated it first with a hair drier to soften it.
sixnotfour
post Jun 10 2016, 02:08 PM
Post #57
7 x 17 et40 CIP 1 has em $99 each on special slight finish blemished..
205/45
205/55
daytona
post Jun 10 2016, 02:53 PM
Post #58
daytona
Hi all,
I love and appreciate this thread. I have a bone stock 74' 914 that I have been thinking about upgrading? to the 5 lug fuchs, and have been wondering how big I can go without modifying the rear fenders, or at least with minimal modification.
I have two questions that may add an additional dimension to this thread:
1.what hardware did you use for the 5 lugs (what year front suspension, and rear hub solution) ?
2. How do you feel that this upgrade changed/improved the handling of the 914?
Thanks for all the pics and info on this thread so far. I now want to do this more than ever.
Bill.
Mueller
post Jun 10 2016, 03:12 PM
Post #59
914 Freak!
Handling should be exactly the same between 4 lug and 5 lug if same size tires/rims.
Max size varies car to car, side to side. Did you read all the replies?
Seems to be enough info to get you started using your car as a reference with what you have already. I suggest learn how offset works if not familiar with it.
bradtho
post Jun 10 2016, 05:39 PM
Post #60
that's right, ignoring the changes from the rubber you won't be able to tell a difference. imo, there's only 1 reason to do the switch and that's the look. It's all about what wheels you like.
make sure you can find tires you like for whatever wheels you like. 15 & 16" tires are getting harder to find.
- Lo-Fi Version Time is now: 22nd April 2025 - 10:26 AM
