Matty900 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest ![]() |
Engine build is progressing along nicely. Case is now closed.
Attached thumbnail(s) ![]() Attached image(s) ![]() ![]() |
Matty900 |
Scott rebuilt the steering rack for me with new bushings and bearings. We will be putting turbo tie rods on next
Attached thumbnail(s) ![]() |
Matty900 |
Added front sway bar with new 914Rubber sway bar bushings.
Matty900 |
Cleaning up and replacing everything possible on the suspension.
Matty900 |
New struts/shocks from PMB that I bought right after getting the car. Thought I was going to be driving it with just a few tune up items. (IMG:style_emoticons/default/av-943.gif)
Matty900 |
Had to figure out how to get the spring purch off. (Thank you Cary)
Matty900 |
Cap and purch cleaned up and on the new shock
Matty900 |
Rebuild steering rack back in with powder coated parts.
Matty900 |
I will be upgrading to a side shift transmission. Getting the already powder coated kit from Bruce Stone.
Matty900 |
Adding new 914Rubber control arm bushings.
Matty900 |
Been a little warm in the shop the past week.
Matty900 |
We pulled out the parts for under the car today and started getting them on the car.
Matty900 |
Cary made lots of progress today. Got new 914Rubber bushings and bearings pressed on to the control arms and trailing arms.
Matty900 |
New bearings in.
Matty900 |
New shocks on cleaned parts. Ready to go back on the car.
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Looking great, time well spent.
Matty900 |
Looking great, time well spent. Thank you. Thats a pretty big complement from the build off winner (IMG:style_emoticons/default/first.gif) . Will you be at Okteenerfest again this year? |
Matty900 |
Lost a few wields on the nuts for the sway bar. Cary got them fixed and I touched up the paint.
Matty900 |
Had to fix one of the taillight housings to keep moisture out in the future.
Matty900 |
Cary mixed up some fuser to patch it.
Lo-Fi Version | Time is now: 19th April 2025 - 11:23 PM |
