CptTripps' Real Progress Thread, :: Not that I'm making *real* progress : |
CptTripps |
May 22 2005, 07:04 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Ok...First the stuff from Friday.
Here are the new trunk seals from the AA kit... (IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/233.jpg) |
CptTripps |
May 22 2005, 07:05 AM
And the outer door seal. I put these two in so the paint wouldn't chip on the way home.
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/234.jpg) |
CptTripps |
I made my own rubber grommets for the valances by cutting up an old hose.
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/235.jpg) |
CptTripps |
May 22 2005, 07:06 AM
CptTripps |
May 22 2005, 07:07 AM
Front Bumper Installed. I'm going to adjust the hood later...I need the seal in there first.
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/237.jpg) |
CptTripps |
May 22 2005, 07:08 AM
Back Bumper...nice and shiney.
(NAMDRAH is my last name backwards...my other car is HARDMAN) (IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/238.jpg) |
CptTripps |
May 22 2005, 07:09 AM
Here's a good body shot. This thing glistens in the sun...I'm SO pleased with the paint!
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/239.jpg) |
CptTripps |
Installing the back glass....GREAT thread here on that BTW!
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/240.jpg) |
CptTripps |
May 22 2005, 07:10 AM
CptTripps |
Put the 3rd brake light in...
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/242.jpg) |
CptTripps |
May 22 2005, 07:11 AM
Put DynaMat in the interior...deadened the CRAP out of the panels. VERY nice...wish I had more. (I've ordered a bunch more already!)
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/243.jpg) |
CptTripps |
May 22 2005, 07:13 AM
Re-Built the outer-inner felt bad for the windows. I need to order the inner-inner ones. Easy install with parts from Lowes. Took me an hour, and looks/works VERY well.
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/244.jpg) |
CptTripps |
Here are the outer window seals installed. This pic takes us to the end of what I did Friday...
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/245.jpg) |
CptTripps |
May 22 2005, 07:17 AM
I started Saturday by re-covering the top-back dash. I used vynal that I got from Morphenspectra that matches the door panels I bought, and the center console. (diamond punch)
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/247.jpg) |
CptTripps |
CptTripps |
May 22 2005, 07:18 AM
Here is the rest of the interior stuff I need to cram in there...
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/250.jpg) |
CptTripps |
May 22 2005, 07:19 AM
Next Samson (newto914s) came over and we put the dash in. Sam REALLY liked this part! ("I give up...I cant get to that screw!")
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/251.jpg) |
CptTripps |
May 22 2005, 07:20 AM
Then we put the back-pad on. I had to re-drill a few holes after I put the chassis-stiffening kit in. Forgot about that part!
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/252.jpg) |
CptTripps |
May 22 2005, 07:26 AM
:::: FAST FORWARD BECAUSE MY BATTERY DIED ::::
Samson got the seats built for me, while I worked on the threasholds, seals and side carpet. (As seen in the pic above.) Then we re-blead the brakes, and THAT is when trouble started. We did all three leading up to the drivers front. We could NOT get the tire off the rim. Sounds funny, but YOU try to get that thing off of there! (Yes, we took all 4 bolts off!) So I figured I'd just bleed around it...then the bleeder valve broke off. "No Problem" I thought...I've got an easy-out! Then the Easy-Out broke off inside the broken bleeder. I have NO clue how I'm going to get THAT out of there. I got cleand up and went out to dinner with my wife. Then I came home, and got back to work...time to see if the carpet fits. (IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/253.jpg) |
michelko |
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
more, give me more (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
Lo-Fi Version | Time is now: 28th November 2024 - 10:39 AM |
