27 Pages V < 1 2 3 4 5 > »
> CptTripps' Real Progress Thread, :: Not that I'm making *real* progress :
CptTripps
post Mar 21 2005, 10:02 AM
Post #41
:: Punch and Pie ::
QUOTE (rhodyguy @ Mar 21 2005, 10:51 AM)
is there some kind of hi-tech antenna that will replace the old mast style?
Yeah, It's called Sirius Satelite Radio. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I'm giving up on terestrial radio all together. I've got a $2,500 tuner on my stereo at home, and I haven't used it in the 6mos since I got the $100 'Sportster'. The content is awesome, the quality is fine for the car.
The antenna is little, and will hide nicely under one of the side engine grills. Probably the one on the drivers side.
Gint
post Mar 21 2005, 05:05 PM
Post #42
Mike Ginter
Lookin pretty good DOug. You do nice work. Re-think that brown interior though. I always liked it a yellow teener.
CptTripps
post Mar 21 2005, 06:08 PM
Post #43
:: Punch and Pie ::
QUOTE (Gint @ Mar 21 2005, 06:05 PM)
Too late...I already have the interior, and carpet (ordered).
I'm going to have the brown interior re-apolstered for the next car. I want to do a complete ox-blood interior with silver paint.
rhodyguy
post Mar 21 2005, 06:30 PM
Post #44
oooh silver and red, nice!!! delete all the inside door stuff save the handles and it's a winner.
k
CptTripps
post Mar 21 2005, 10:14 PM
Post #45
:: Punch and Pie ::
Got some more accomplished tonight...It's nice to not be dusty when I get in the house!
Drilled the holes for my 3rd brake light...
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/107.jpg)
CptTripps
post Mar 21 2005, 10:15 PM
Post #46
:: Punch and Pie ::
I'll get it painted up with the rest of the car...should look sweet.
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/108.jpg)
CptTripps
post Mar 21 2005, 10:16 PM
Post #47
:: Punch and Pie ::
Now here is a question...I want to take off all the lettering, but HOW IN THE HELL do you get these little rubber things off without breaking them?
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/109.jpg)
CptTripps
post Mar 21 2005, 10:18 PM
Post #48
:: Punch and Pie ::
I also got all the tires off, and pulled all 4 calipers, and all the lines. I'll replace everything tomorrow with rebuilt BMWs up front, and stock in the rear.
I'll need to add a T instead of the prop, and put the new 19mm master on, and make new lines for up front. But that's tomorrow's project...
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/111.jpg)
redshift
post Mar 21 2005, 10:41 PM
Post #49
Bless the Hell out of you!
Don't worry about the retainers, get them from Pelican.
Uhh... do worry about breaking the attachments off of the letters.... retainers cheaper than dirt, letters cheaper than... uhh...
Cheaper than extremely expensive dirt?
M
morph
post Mar 21 2005, 11:04 PM
Post #50
quality parts builder
James has a small air grinder and it takes like 10 seconds for him to remove all retainers. I did it wrong a couple of times with pliers and broke the posts off.
HIEDI
CptTripps
post Mar 22 2005, 06:47 AM
Post #51
:: Punch and Pie ::
So are they just rubber? I should slice them in half? I REALLY don't want to mess these up! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
I've searched Pelican's site...any idea what they are called? I tried 'Retainer' and got nothing that resembled what I'm looking for.
Thanks for the help.
Gint
post Mar 22 2005, 08:12 AM
Post #52
Mike Ginter
There's a little round metal circular dealy in there with a hole in the center and relief cuts coming off of that. Like a speed nut sorta, I don't know the terminology off the top of my head. Bu thtese are really meant to be one time use probably. They push on to the plastic and dig in. That's why they break the plastic pins off oif the letters if'n you gorilla them. If you take a grinder to them, you won't be re-using 'em and I would imagine it would take some skill or practice to even do that without breaking the letter's pins.
IronHillRestorations
post Mar 22 2005, 08:16 AM
Post #53
I. I. R. C.
QUOTE (CptTripps @ Mar 21 2005, 08:14 PM)
3rd brake light is a good idea. For a little less invasive look, I probably would have mounted it upside down on the bottom of the roll bar. Just my .02 though
CptTripps
post Mar 22 2005, 09:05 AM
Post #54
:: Punch and Pie ::
QUOTE (9146986 @ Mar 22 2005, 09:16 AM)
I tried that....it was too wide, and the way I could have made it work, would have put a lip that water could sit in. And we ALL know what happens to metal when water sits. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
E-Man
post Mar 22 2005, 02:17 PM
Post #55
I used a Dremel (high-speed rotary tool) with a cut-off wheel to get the speed nuts off. Cut just left or right of the post all the way across so you have two pieces.
Pelicanparts.com sells new ones for 80 cents each. They call them Porsche Emblem Mounting Speed Nuts and are made of metal and rubber. -Mike
morph
post Mar 22 2005, 02:53 PM
Post #56
QUOTE (CptTripps @ Mar 22 2005, 04:47 AM)
They are rubber on top with metal inside. Performance products has sets of 4 for $3.99, however the new ones are not the same as the factory ones. They are a pain to remove, I ended up damaging the retainers when I removed them anyways.
HIEDI
CptTripps
post Mar 22 2005, 10:58 PM
Post #57
:: Punch and Pie ::
Tonight I was WICKED productive!!!
First things first...I needed some more light in my garage.
Went to Lowes, and picked up 4 Florescent 'shop lights' for $7.68 each! So for under $50 (with bulbs) I have LOTS more light in the garage. This is a good thing!
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/112.jpg)
CptTripps
post Mar 22 2005, 10:59 PM
Post #58
:: Punch and Pie ::
Now for 'real' work...
I started with an easy one...the guage cluster tin.
Sanded down, and primed. Ready for guages. Check it off the list!
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/114.jpg)
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/115.jpg)
CptTripps
Post #59
:: Punch and Pie ::
Now it was time to dig into the brakes. First, we had to get the old ones off. Here's what happens when you try to use an adapter for something like lug-nuts!
(That's what prompted the trip to Lowes in the first place)
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/113.jpg)
CptTripps
post Mar 22 2005, 11:00 PM
Post #60
:: Punch and Pie ::
But since I had good tools now, it didn't take long to get all 4 off. Now fortunately, My car came with a set of rebuilt rear calipers, and I'd bought a pair of milled 320i calipers, so all I was really doing was cleaning everything up, and putting it on.
(IMG:http://www.hardman.org/pix/914_progress/914_progress-Images/116.jpg)
- Lo-Fi Version Time is now: 27th November 2024 - 08:43 PM
