20 Pages V « < 17 18 19 20 >
> Mark's (914Rubber) Project Car
cary
post Oct 9 2016, 06:50 AM
Post #361
QUOTE(Mikey914 @ Oct 9 2016, 12:05 AM) *
We can easily fabricate these. Just needed to work out the details with Cary .
See, what did I tell you. IIRC the patterns work for both sides. You'll just fold it inside out for the left side.
cary
post Oct 9 2016, 07:28 AM
Post #362
Not much to add for Saturday. Installed the painted brake reservoir strap. Then we proceeded to bleed the brakes. Only to find once we pressurized the system the back calipers freeze up and don't release. (IMG:style_emoticons/default/sad.gif) And it needs new rotors too.
Emailed Mark
Installed the valve cover gaskets and covers. Then on to cleaning the bottom of the engine. Used wire brushes, brake cleaner and air. It was primarily left over blasting media stuck to the oil. Then changed the filter and refilled with Brad Penn 15-40.
While I was there I removed the thermostat and bagged it up for Mark. Bent up
Then back into office/clean room. I was really starting to struggle. The spark plug wires just wouldn't dress out the way I like. Did I have it set up right ? So I turn the engine 45 degrees on the stand and take off the valve cover and watch the #1 combustion cycle again. TDC, exhaust, both tight, intake then TDC again. Everything is dead on. At the end of the day it looks like someone re indexed the distributor, its off 90 degrees. Which is exacerbated by the fact this distributor has the #1 mark cut where we usually have #3. (IMG:style_emoticons/default/sad.gif)
Off to my twice yearly Tire Rack Street Survival instructor duties. 914 World member Gary Chapmen will be there also. He does the inside teaching portion.
cary
post Oct 9 2016, 10:14 PM
Post #363
Couldn't let the dizzy issue go ................
Headed back out to Forest Grove after the TRSS.
Doubled checked that every thing was at #1 TDC. Then set out to remove the distributor.
Then tried pulling out the dizzy gear drive with one of my multiple magnets. No Go. (IMG:style_emoticons/default/sad.gif)
Went to the Haynes manual and it suggested snap ring pliers. Grabbed them out of the special tool cabinet and went to work. Easy Deal .............
DANGER : After you pull the dizzy. The special oiling washer is just sitting on the dizzy boss. If left alone it could get knocked into the bottom of the engine. Please dont get distracted and retrieve it with a magnet.
Used the sticky grease to hold the washer in place when I dropped the drive back into the hole. Had to do it twice to get the alignment I wanted.
Took two attempts but I have number 1 back where I want it. Now it points right at the vacuum advance hose tube. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
Now I can dress the spark plug wires to my liking ...............
Cairo94507
post Oct 10 2016, 07:40 AM
Post #364
Michael
Very nice way to tidy up the spark plug wires.
cary
post Oct 15 2016, 08:54 AM
Post #365
Found my used pins from the rewiring of the 3.2 conversion on my 911.
cary
post Oct 15 2016, 09:37 PM
Post #366
Finished up the return line with a new twist (non CW). Added a couple zip tie holders to the rear engine tin. Keeps it all tidy. I'm also going to have Super In Law fabricate a brace to hold the rear engine tin place. I get tired of it laying over.
We'll see if I like the location after its back in the car. If not I'll hang it from the outer slot.
cary
post Oct 16 2016, 06:20 AM
Post #367
One little rust repair behind the drivers seat. Usual spot ..................
Cancer cut out. And entire area sprayed with cold galvanizing.
Patch welded in. Tough duty for a right hander. Upside down and backwards.
Super In Law made the patch piece. But after closer inspection I'll need a little extension right under the e brake tubes.
Went thru a few sanding belts to smooth down the weld. Not exactly my prettiest work.
A little metal degradation on the upper portion and brazing on the left.
cary
post Oct 16 2016, 08:49 AM
Post #368
QUOTE(BeatNavy @ Jun 1 2016, 06:38 PM) *
QUOTE(DirtyCossack @ Jun 1 2016, 09:21 PM) *
I'd love a pattern!!!
(IMG:style_emoticons/default/agree.gif) I could definitely use that as well, Cary. Thanks for any and all help!
For those that would like a copy of the suspension tie patterns PM me with your mailing address. I have Rich and Rob's already. But I need to go to Staples and get some thicker paper first.
cary
post Oct 18 2016, 08:02 AM
Post #369
Rich and Rob patterns going out in the mail today.
BeatNavy
post Oct 18 2016, 02:23 PM
Post #370
Thanks, Cary. You are the man (and so is Super-In-Law) (IMG:style_emoticons/default/beer.gif)
mbseto
post Oct 19 2016, 12:15 PM
Post #371
QUOTE(cary @ Oct 16 2016, 10:49 AM) *
I could use a pattern, but wouldn't it be easier for you to scan them and just email a scan?
cary
post Oct 20 2016, 08:44 AM
Post #372
Send me your email and I'll try it tonight ..........
cary
post Oct 23 2016, 02:08 PM
Post #373
QUOTE(mbseto @ Oct 19 2016, 11:15 AM) *
For those that want a PDF. I have the PDF scaled 100% dead on.
Send me your email.
JoeDees
post Oct 24 2016, 08:41 AM
Post #374
QUOTE(mbseto @ Oct 19 2016, 01:15 PM) *
Reading this, I remembered that I was supposed to scan in and send you my template...sorry. But on the bright side, I'm 100% sure Cary's will be better than mine.
cary
post Oct 28 2016, 09:26 AM
Post #375
Mark stopped by yesterday to drop off the first batch of steering rack cases (?) to be washed in the jet washer.
He also picked up the templates for the suspension ties to see about having them cut out with a CNC or plasma table.
BeatNavy
post Oct 28 2016, 09:58 AM
Post #376
Cary - thanks again for sending these out. You, sir, are an upstanding 914World citizen. Having said that, if Mark does make these and sell them reasonably priced, I will gladly go that route rather than attempt to make myself.
cary
post May 4 2017, 08:02 AM
Post #377
Mark stopped by yesterday and did a project review on the For Sale Car. It's been a while.
Work List ..................
* Inspect the fuel tank and lines
* Finish the rebuilding of the brake system (rears & bleeding)
* Finish engine/FI refreshment and install
Then it will return to 914 Rubber for the interior and trunk painting.
cary
post May 13 2017, 07:57 PM
Post #378
QUOTE(BeatNavy @ Oct 8 2016, 05:25 AM) *
As always, it's great to read your progress, Cary. I enjoy seeing the detail you put into this.
Did you ever get around to making a template for the suspension tie pieces? I know you have other fish to fry, but I'm going to have to deal with this sooner or later. No worries/no pressure, just curious.
Look what Matt dropped off this afternoon. Don't know the pricing .................
rhodyguy
post May 13 2017, 09:06 PM
Post #379
Nice trick with the zip ties and piece of hose on the wires.
cary
post May 29 2017, 09:05 PM
Post #380
As Super In Law is finishing up the engine tray patch on Doug's car. I jumped over and installed the new rotors and calipers on Mark's for sale car.
I did also crack the hose connections right below the engine tray on both sides. (IMG:style_emoticons/default/biggrin.gif) No issues. I removed the hard and soft lines on Saturday after pulling the calipers and rotors.
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th January 2025 - 05:11 AM
