914bub |
Member ![]() ![]() Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None ![]() |
I would like #39 if the turn signal switch cancels and will fit my 72. 95354 is my zip
Mathman |
Newbie ![]() Group: Members Posts: 25 Joined: 10-May 14 From: Kansas Member No.: 17,330 Region Association: None ![]() |
I'll take a fuel pump and the passenger side exterior mirror. Shipped to 94583 let me know and I can PayPal you. Thanks, Kevin Just for clarification, the passenger side mirror is just the housing and gasket. There is no glass. Is that what you were expecting? I was expecting that it had glass but if it's the right size mirror I forget whether it's early or late I guess I'll still take it. My mirror is five and five eights by 3 1/2 if yours is the same I'll take it. I'll also still take the fuel pump. Thanks, Kevin Kevin, Just sent you a PM. Thanks! |
914bub |
I would like #39 if the turn signal switch cancels and will fit my 72. 95354 is my zip Um,...... Purdy Please? (IMG:style_emoticons/default/biggrin.gif) |
wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
914bub |
I would like #39 if the turn signal switch cancels and will fit my 72. 95354 is my zip Um,...... Purdy Please? (IMG:style_emoticons/default/biggrin.gif) Sent a PM. "I'll be your best friend"...... (IMG:style_emoticons/default/biggrin.gif) |
Mathman |
Has anybody said speedo? If not I am interested. Also a chrome piece that goes from the targa bar to rear fender. Thanks, kkid (IMG:style_emoticons/default/smile.gif) kkid, The speedo is gone. Did you still want the chrome piece? PM your ZIP, and I'll get you a total. |
Mathman |
9fourteen14 |
PORSCHE LUVA ![]() ![]() Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States ![]() |
Hi, all! I'm downsizing my 914 hoard, and I was curious if anyone had any need for this stuff before it goes away. I hate to toss it if someone needs it, so PLEASE make an offer. I promise that I won't be offended. I only list the prices because we're supposed to. Please note that all electrics are untested and all items are understood to be driver quality. The transmission was good when it was removed. If you have any questions, please shoot me a PM/E-mail/reply. I'll reply as soon as I am able. Payment via PayPal, shipping extra. Thanks for looking! 1 Key Blank $20 2 Heater Control Knob $5 3 HVAC Bezel $5 5 Voltage Regulators $5 each 6 Hub Covers $10 each 7 Rear Trunk Lock Spring $10 8 Fuel Lines $5 each 9 2.0 Plenum Brackets $5 for the pair 10 Fuel Injector Supports $5 each 11 2.0 Cold Start Valve Connectors $5 each 12 Belt Cover $5 each 13 2.0 Plenum $40 14 2.0 Fuel Intake Runners $20 per set 15 Starter $10 16 Alternator $25 18 Driver's Side Engine Shroud $150 for all tin 19 Various Engine Shrouds $15 per piece 21 Ignition Coils $10 each 22 Impeller Fan $50 23 More Engine Shrouds $15 per piece 24 Impeller Fan Shround $30 25 Smog Pump Pipe $20 26 Heater Pipe $15 27 Passenger Side Engine Shroud $150 for all tin 28 Defroster Vent $10 29 Leather Steering Wheel Cover $15 30 Side-Shift Transmission $150 31 Headlight Brackets $10 32 Headlight $10 33 Defroster Vent $10 34 Headlight Covers $10 35 Ashtray $15 36 Windshield Wiper Motors $10 each 38 Fuse Panel Board $10 39 Wiper/Turn Signal Stalks $5 40 Headlight Cowl $15 42 Fresh Air Vent Cover $5 43 Non-Fog Light Grille $40 46 Factory Radio $180 48 Chrome Trim $5 per piece 49 Rocker Arm Spacers $5 each 50 Windshield Wipers $5 each 51 Fresh Air Deflector $5 52 Rear View Mirror Base $5 53 Rubber Shift Boot $5 55 Turn Signal Bracket $5 56 Door Handle Bezel $10 57 Pedal Covers $5 each 58 Electric Fuel Pump $10 59 Window Crank $5 60 Trunk Bracket $5 61 Cigarette Lighter $10 (no element) 62 Seat Belt Light $5 63 Trunk Light $10 64 Steelie Lug Bolts $30 for the set 65 HVAC Cables $5 for the set Let's try this link: https://flic.kr/s/aHskwmzgof hi do you have value covers? i will take them? 914 luva |
danoswork |
Newbie ![]() Group: Members Posts: 1 Joined: 21-September 14 From: oregon Member No.: 17,930 Region Association: Pacific Northwest ![]() |
Hi, do you have a wiper motor that is fully functioning? Park, high and low speeds?
Thanks, Dan |
7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
I'll take #48 Sail Panel Trim for $5; do you have two?
Guberif |
Newbie ![]() Group: Members Posts: 33 Joined: 27-July 16 From: Washington Member No.: 20,227 Region Association: Pacific Northwest ![]() |
If steering wheel cover is still available, I'll take it. and do you have 4 or just 3 wheel spinners?
thanks |
buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
Do you have the sail panel horizontal trim piece below the vinyl passenger side?
Thanks, Buck |
Lo-Fi Version | Time is now: 26th June 2024 - 04:23 AM |
