1970 Turn Signal Relay |
podiummotorsports |
Mar 23 2016, 12:29 PM
Newbie Group: Members Posts: 39 Joined: 7-October 12 From: Rossmoor, CA Member No.: 15,011 Region Association: Southern California |
I am wondering if anybody knows if the early 914 has a turn signal relay. The only reason I ask is because when I use the right turn signal and press on the brake I get both flashers flashing but when I use the left turn signal and press the brake it works fine. After reading many post people suggested cleaning the ground (done) and replace the turn signal relay. Here is a pic of my fuse box/ relays. It doesn't look like any of the others I have seen people post. Since this is a 1970 914 I was wondering if it was located somewhere else or if they didn't use them and I need to keep researching.
Attached thumbnail(s) |
jcd914 |
Mar 23 2016, 01:10 PM
The flasher relay is square with 4 wires to it.
It is not attached to the fuse panel but under the dash near by. Jim |
podiummotorsports |
Mar 23 2016, 02:54 PM
913B |
Mar 23 2016, 07:06 PM
Senior Member Group: Members Posts: 855 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Can I ask you how the square silver relay on the far right is attached to relay board. Apparently mines is not attached in anyway, is there like a clip on the top of the relay that clips to the board or something ??
Thanks. |
913B |
Mar 23 2016, 07:17 PM
FYI if you can't find a replacement. I wasn't successful. (IMG:style_emoticons/default/sad.gif)
http://www.914world.com/bbs2/index.php?showtopic=272915 Good Luck |
eitnurg |
Mar 24 2016, 01:39 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
QUOTE Now going to track down a replacement. Just be aware that for everything to function properly you will need a 914 specific item. The generic ones will plug in and work the flashers/hazards ok but the issue is the flashing warning light for the handbrake: they're not designed to cope with it and activating it just confuses them with all sorts of weird results. Rumour has it that 911s of a similar vintage had the same feature, so maybe there's another source. |
podiummotorsports |
Mar 24 2016, 04:32 PM
porsche913b_sp I will send a pic of the bottom when I get home from work. I purchased something but after reading a number of threads I am getting the feeling that I purchased the wrong item. I will also let you know when I get home from work.
913B |
Mar 24 2016, 05:25 PM
If you can take a pic of the part number of that relay it would be appreciated as well for my reference.
Thank you Ted |
podiummotorsports |
Mar 26 2016, 07:34 AM
Sorry for the delay in getting the pics and details. I would have to say that I didn't think this was going to be such a challenge. I went searching for the replacement and found they have the relay on amazon with amazon prime. So I ordered the part and it came the next day. Unfortunately that is where my troubles came. The part was manufactured by URO and when I put it in the car it didn't work at all. When I was pulling it back out the part broke in my hands. So what ever you do, don't by URO parts. I then tracked down another manufacture from a local parts house. This time is was made in Germany. I plugged it in and worked like a charm and all my problems are solved. Here are the pics of each product.
913B |
Mar 26 2016, 11:10 AM
Thanks Aaron for pics ! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif)
Mar 26 2016, 11:44 AM
914-6 GT in waiting Group: Members Posts: 19,698 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Sorry for the delay in getting the pics and details. I would have to say that I didn't think this was going to be such a challenge. I went searching for the replacement and found they have the relay on amazon with amazon prime. So I ordered the part and it came the next day. Unfortunately that is where my troubles came. The part was manufactured by URO and when I put it in the car it didn't work at all. When I was pulling it back out the part broke in my hands. So what ever you do, don't by URO parts. I then tracked down another manufacture from a local parts house. This time is was made in Germany. I plugged it in and worked like a charm and all my problems are solved. Here are the pics of each product. But URO has 10 scientist on staff, lots of fancy testing equipment and a periodic chart of elements hanging on the wall. (IMG:style_emoticons/default/lol-2.gif) |
Strudelwagon |
Apr 4 2016, 05:08 PM
Member Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
who was the local supplier of the GOOD one?
podiummotorsports |
Apr 5 2016, 08:34 AM
In southern california these guys are located in Huntington Beach. They are not my first choice but they do have odd ball items and ship worldwide.
http://www.einmalig.com/ |
ChristopherB |
Jul 31 2016, 10:48 AM
Member Group: Members Posts: 93 Joined: 18-May 11 From: Towson, Md. Member No.: 13,086 Region Association: MidAtlantic Region |
I am trying to replace my turn signal relay. I have the fuse panel dropped and I don't see it. Does anyone have a picture of it in place? What color wires go to it?
ChristopherB |
Jul 31 2016, 10:51 AM
ChristopherB |
Jul 31 2016, 02:16 PM
Found it. Hard to wiggle out of its connector, but the new one went in easily. Turn signals are working again.
914Sixer |
Aug 1 2016, 05:49 AM
914 Guru Group: Members Posts: 9,043 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Large and small silver (metal) at the right end is the headlight relay. The larger version came from the VW Type 3. Small one was from the Beetle.
ChristopherB |
Aug 2 2016, 03:34 PM
I got in the car today delighted that everything is working well, and my parking break now causes both turn signal indicators to light on the dash. There is also a strange buzzing sound coming from the dash with the parking brake engaged. Is this related to the new turn signal relay? When I pulled the old relay, the four tabs were considerably splayed. The new relay had nice straight tabs and seemed to install just fine. The turn signals work normally. What is going on here?
Mike Bellis |
Aug 2 2016, 06:48 PM
Resident Electrician Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
RIch Bontempi at High Performance House in Redwood City has a bunch of these relays. They run about $50 each.
Spoke |
Aug 3 2016, 04:55 PM
Jerry Group: Members Posts: 7,116 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
It sounds like your flasher is pulling in the 4 th terminal in when the e brakeis up.
Do the tach turnsignal indicators flash or stay gently lit with ebrake pulled? |
Lo-Fi Version | Time is now: 13th January 2025 - 08:31 AM |
