1970 Turn Signal Relay |
ChristopherB |
Mar 29 2017, 07:12 PM
Member Group: Members Posts: 93 Joined: 18-May 11 From: Towson, Md. Member No.: 13,086 Region Association: MidAtlantic Region |
The turn signal indicators on the dash are gently lit at this point with or without the brake engaged and the car running. There is also a buzzing sound as well that does not go away. This began over the winter on a very, very wet day.
Mikey914 |
Mar 29 2017, 09:20 PM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Sorry for the delay in getting the pics and details. I would have to say that I didn't think this was going to be such a challenge. I went searching for the replacement and found they have the relay on amazon with amazon prime. So I ordered the part and it came the next day. Unfortunately that is where my troubles came. The part was manufactured by URO and when I put it in the car it didn't work at all. When I was pulling it back out the part broke in my hands. So what ever you do, don't by URO parts. I then tracked down another manufacture from a local parts house. This time is was made in Germany. I plugged it in and worked like a charm and all my problems are solved. Here are the pics of each product. Really URO made a $hit part!!! Almost unbelievable!!! Do I have to start making flasher units too? (IMG:style_emoticons/default/chair.gif) |
Spoke |
Mar 30 2017, 06:40 AM
Jerry Group: Members Posts: 7,116 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The turn signal indicators on the dash are gently lit at this point with or without the brake engaged and the car running. There is also a buzzing sound as well that does not go away. This began over the winter on a very, very wet day. When you say "The turn signal indicators on the dash are gently lit at this point", do you mean with either left or right turnsignal on, both indicators light gently? |
eitnurg |
Mar 30 2017, 11:23 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
The turn signal indicators on the dash are gently lit at this point with or without the brake engaged and the car running. There is also a buzzing sound as well that does not go away. This began over the winter on a very, very wet day. Go back and read post no 6. You need a 914 specific flasher unit: the generic ones will work ok but they don't like trying to flash that 1w handbrake warning bulb on its own. They try and flash at a million times a second which is why they make that buzzing noise and the lights are dim. |
ChristopherB |
Mar 30 2017, 02:12 PM
Thanks!
Lo-Fi Version | Time is now: 13th January 2025 - 01:27 PM |
