Removing transmission stub seals, I am struggling with this |
wndsnd |
Apr 2 2016, 07:38 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I do not know if these seals were ever replaced but I do know they are leaking. With good advice from RTowle, I ordered the replacements and took a shot at replacing today.
I am not sure how to get the old seal out without damaging the sealing bore. I expected them to come out easier than I experienced, so before I mess something up I thought I would ask how you have done it. Thanks |
BeatNavy |
Apr 2 2016, 07:45 PM
Are you referring to the output shaft seals? If so: I've heard using a dental pick is supposed to work, but it didn't for me. They were stuck in there too tight. So I did what some others recommended. I very carefully drilled a bit of a hole in the seal and then sunk a sheet metal screw in it. Then I used the other end of a claw hammer to get leverage and pull it out.
Apr 2 2016, 08:00 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I use a large flat head screw driver being very careful not to scratch the surface they mount against.
Slowly pry it around the edge till you find a weak spot, then work on that area till it gets high enough up to grab it or get under it from outside. Rich |
Lo-Fi Version | Time is now: 25th April 2024 - 09:10 PM |
