electrical question, headlight relay |
freezing14 |
Mar 30 2005, 08:11 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
Got some bugs with the high/low system,, they do not seem to work , the relay that does the switch seems to be dead,, but everytime i see one listed it looks different, the all list it under headlight relay but it has 5 pins instead of 4, do any one know if the flap can have it and if they can who do they get it from and what is the part #
thanks |
double-a |
Mar 30 2005, 09:01 AM
Senior Member Group: Members Posts: 989 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
search the archives, this subject has been discussed before, with pictures even. you can use the new relays without any problems, they operate the same as the oem ones. but you'll need to fashion a jumper wire from pin 30 to pin 56, if memory serves.
~a |
freezing14 |
Mar 30 2005, 09:49 AM
I found only one
http://www.914world.com/bbs2/index.php?act=...21750&hl=dimmer so apparently the other one will work OK,, I will order it at my flaps,, thanks guy (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
double-a |
Mar 30 2005, 09:57 AM
no prob. try this one:
headlight flasher relay look a few posts from the top for the image. the reason i remember is that i had the same problem, and posted a pic of the new relay with the jumper attached. ignore the other wires on pin 56, those are for the fog light flasher kit available from jwest. ~a |
Lo-Fi Version | Time is now: 26th December 2024 - 03:19 PM |
