Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
These carbs were in a 911, so I assumed they were going to fit in my 914. I'll wait until the engine is in to decide which air cleaners will fit.
Or, some one with a /6 conversion can let me know how close their filters are. I think they will work, only an inch or too difference on these manifolds. |
'73-914kid |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California ![]() ![]() |
Stock 911 airbox won't fit. (Crashes into engine lid) Hell, the stock airbox is close with the factory length intake manifolds on my car, and I've gone back and lowered the front of the engine by 1/4 inch... If you run the PMO K&N watershield combination, you will probably have to trim the passenger side rain hat away from the aft engine bay bulkhead. That extra 1.5 inches or so makes a pretty big difference.
In all likelihood, standard K&N filters without rain shields will probably fit not problem. Are those the PMO "tall" manifolds? |
Larmo63 |
Larmo63 |
I installed the engine tin seals, on the rear one, which side goes up? The wider skirt, or the narrow?
I forgot. |
Larmo63 |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Though they're not ideal, the K&N air filters with the Weathershield air cleaner housings are a reasonable way to solve the clearance issues.
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
t collins |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None ![]() ![]() |
These carbs were in a 911, so I assumed they were going to fit in my 914. I'll wait until the engine is in to decide which air cleaners will fit. Or, some one with a /6 conversion can let me know how close their filters are. I think they will work, only an inch or too difference on these manifolds. As best as I can measure in the car , my PMO intakes are 85mm tall and with the K&N filters and rain hats they just barely clear the rear bulkhead. ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
My K&Ns fitted without weathershields just the top cast alloy piece on ,I very much doubt the weathershields would clear in my situation,I didn't have a lot off space from the bulkhead ,you need to allow for a small amount of engine movement also.
With the stock manifolds I have room to fit the original plastic air filter and the lid will close but I had to cut off and reposition one of the spring clips so I could latch it up. I have noticed the stock air cleaner is a fair amount quieter than the K&Ns but takes up a lot more room (IMG:style_emoticons/default/biggrin.gif) . There isn't a lot wrong with the original not when you compare aftermarket ones ,they all seem to have drawbacks of some kind or another (IMG:style_emoticons/default/dry.gif) . |
Larmo63 |
I finally took the plunge and cut an access hole in the firewall. I'm actually surprised at how easy it was. I had a spare firewall piece, and I made a great hatch for it. It fits tight, and appears to be completely fireproof.
(IMG:style_emoticons/default/confused24.gif) |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
You will be so happy you did that. A friend of mine convinced me to do it.
Larmo63 |
I'm pretty frustrated now. Things going slow.
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
Have a completion party and invite some folks over to help get it done. It looks like you are down to just installing the engine and a couple little things? You are almost there.
horizontally-opposed |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,435 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None ![]() ![]() |
I'm pretty much at the point where I'm going to list the whole project for sale. I'm over it. Too much disappointment and frustration. I don't think I can finish this thing, maybe someone else wants to take a shot? I'll probably part this mess out. This is the moment you most need to carry on. Been there, done that. Felt the same way. If you sell it now, someone reaps all the reward with only a sliver of the input. It will be worth it...if you doubt that, come by for a lunchtime drive. |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Oh gimme a break, will ya? :violin:
On second thought - How Much? (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/poke.gif) |
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
Lawrence, stick with it. When you drive it all your hardships will turn into big smiles of satisfaction.
I'm still fussing over details, and have to stop myself to just go out and drive. Keep the faith dude. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I can't remember the number of times I issued that edict during my Subaru conversion. Considering the number of folks that had done Suby 6's support was marginal at best. If I hit a brick wall, I moved onto something that I could do. By moving back n forth thru tasks it eventually happened. You just need a beer or 3. (IMG:style_emoticons/default/beerchug.gif) Kent
SO.O.C914er |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,289 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California ![]() |
Are you serious Lawrence I can't see you throwing in the towel at this point. Take a break and enjoy a good drink (IMG:style_emoticons/default/beer3.gif)
Larmo63 |
<----just so fucking frustrated
'73-914kid |
<----just so fucking frustrated Been there, done that with this type of conversion. Let me know if you want a hand over the weekends getting over the "hump" One drive in a 914-6, and all the stress will become worth it. Pm me for my cell number if you want it.. happy to help |
Lo-Fi Version | Time is now: 25th June 2024 - 05:22 PM |
