> Let off throttle, almost dies & cable dragging
LukeD
post Mar 31 2005, 04:57 PM
I finally got my 70 1.7 FI on the road w00t! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) When I come to a stop and press in the clutch the idle drops to almost dieing and then pops back up to 800. It has too be something simple. Do I need to clean a sensor or something? This also happened before I removed the engine.
Also, my throttle cable drags just a little. Before I pulled the engine I didn't have this problem. I have inspected the cable and it actually apears new, couldn't find any problems with it. If I un-hook it from the throttle body and mount point and have the wifey press the pedal it slides smoothly. Anyone have a picture of their engine compartment showing which side of the air cleaner bracket it routes through? I tried different ways but the only way it seems to reach is the way I have it. Come on show me those clean engine bays (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
Thanks
Luke D
LukeD
post Mar 31 2005, 05:04 PM
Oh, I wanted to mention that the cars runs perfect except for that symptom. I have inspected and repaired any questionable spots on the harness while the engine was out. I have also made sure every wire is hooked up properly.
Luke D
merrill
post Mar 31 2005, 05:11 PM
Dirt Pimp
Shouldn't you show us yours first (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
TheCabinetmaker
post Mar 31 2005, 06:24 PM
I drive my car everyday
Luke, do you have an adjustment knob on your ECU? A pic of your cable route would be very helpful. I really don't wanna dismantle half my FI stuff to take a pic!!!!
Dave_Darling
post Mar 31 2005, 07:24 PM
914 Idiot
Did you check to see if the cables were not wrapped around each other up near the pedal cluster?
--DD
- Lo-Fi Version Time is now: 21st December 2024 - 08:41 AM
