Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
What transaxle are you running? I was watching a show the other day and race transaxle used straight cut gears. I wondear if that would be th direction to go when pushing that much torque? Straight cut gears would be freakishly noisy. OK if it's race only... In your case I would be looking at a 930 trans or a G50 off a 965 at the minimum. A motor like mine is capable of shearing off every gear on a ring an pinion and exploding weak axles, as is yours! Takes a fair bit to flip a 930, but it's a stout box. $1250 per gearset a few years back. IIRC Britain put a 930 in his subi 914, I think there's a thread somewhere.. Guy I know is building a Factory Five GTM, they use a g50 upside down. I've had both apart, 930 has bigger gears than a G50, but the G50 fixed the 901 1st gear weak link. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:20 AM |
