74ravenna |
Member ![]() ![]() Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States ![]() ![]() |
Hi All,
I switched out the original 3-port fuel pump and installed the 2-port. I've replaced the plug with spade terminals but I can't remember which wires (Black/red wire and brown wire) goes to + and -. I have it written down somewhere (plus i was sure i'd remember) but i can't find my notes. Tia Steve |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Brown is always chassis ground, or negative (-).
74ravenna |
Jimz73 |
Newbie ![]() Group: Members Posts: 10 Joined: 15-April 03 From: Maumee, Oh. Member No.: 575 ![]() |
Which fuel pump are you using? Nothing to do with the electrical question you asked, just curious as I am getting ready to change out my furl pump. But I agree with the answer you got. Brown is negative.
Thanks, |
74ravenna |
Which fuel pump are you using? Nothing to do with the electrical question you asked, just curious as I am getting ready to change out my furl pump. But I agree with the answer you got. Brown is negative. Thanks, Its a Carter. Not sure of the PN, but I can get back to you with that. This one is for Carbs. I bought it from CFR. I comes with the filter, mounting bracket and all hardware needed to install. Very simple to install. Chris is quick to ship too! Steve |
Lo-Fi Version | Time is now: 26th June 2024 - 06:47 AM |
