Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,289 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
In for a penny, in for a pound. (IMG:style_emoticons/default/beerchug.gif)
Mitox |
Member ![]() ![]() Group: Members Posts: 416 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States ![]() ![]() |
Mitox |
Mitox |
Mitox |
Mitox |
Mitox |
It’s been a few months, and most progress isn’t very noticeable. After many hours of heating-scraping-heating-scraping, all of the seam sealer is gone.
Now I get to work on the fun stuff; welding pieces back on. The front jack points and seat/ floor reinforcements were replaced a couple days ago, and I just removed the pedal support bracket. This bracket seems to double as a water scoop, directing water into the hole under the pedals; great design to ensure the area rusts adequately. Maybe I should weld this hole closed instead of relying on the seem sealer method. ![]() ![]() |
Mitox |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
That pedal reinforcement is certainly a curious design and I wrestled with what to do about it too. Another issue is that water from wet feet is sure to accumulate around the pedal cluster and migrate through that drain slot or bolt holes into the reinforcement piece. I think the piece is engineered to let that water drain out but it sure is a dumb design. In the end, I just sprayed the inside area with 2 coats of 2K epoxy and put it back together, figuring I'll be dead by the time it becomes a problem again. (IMG:style_emoticons/default/beerchug.gif)
Mitox |
Mitox |
Mitox |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,777 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
horn mount 75-76
Mitox |
Mitox |
Mitox |
Mitox |
I found a pic of the inside of the 914 tunnel. Looks like I have a broken bracket: not sure I’ll secure the tube there.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
With a 3" holesaw open a hole on the top of the tunnel for adequate access.
Weld the plug back in when the repair is complete |
Mitox |
Mitox |
Lo-Fi Version | Time is now: 13th April 2025 - 07:00 AM |
