falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
Put the SC struts in the front. The lower balljoint mount on the early 911's was upgraded to the later version in 1973? (just learned this myself as I need to change my struts)
Mitox |
Member ![]() ![]() Group: Members Posts: 416 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States ![]() ![]() |
Put the SC struts in the front. The lower balljoint mount on the early 911's was upgraded to the later version in 1973? (just learned this myself as I need to change my struts) Thanks for the heads up; currently the plan is to swap in a full SC front suspension. |
Mitox |
The 914 is beginning to look like a GT now. White epoxy was applied last evening. It is looking fine, and is getting a lot closer to going to a paint shop for the green. Attached thumbnail(s) ![]() |
Mitox |
I have a question for those much more knowledgeable than I.
While stripping the bottom of the 914, I noticed the lip around the inside of the GT flares. They are about 5/8" wide; this looks too wide. Does anyone know the correct width? I'm thinking about 3/8" would look OK. |
jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
I don't know the "correct" width, but I rolled mine in with a hammer. Smoother and about 1/4-1/2" more tire clearance
Mitox |
I don't know the "correct" width, but I rolled mine in with a hammer. Smoother and about 1/4-1/2" more tire clearance I think the rolled look may be better even if I trim it shorter. The lip in currently angled into the wheel opening rather than away from it as it would be if rolled. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,732 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
I have a question for those much more knowledgeable than I. While stripping the bottom of the 914, I noticed the lip around the inside of the GT flares. They are about 5/8" wide; this looks too wide. Does anyone know the correct width? I'm thinking about 3/8" would look OK. Yes, they are wide and irregular. I'm going to use a stock lip as a reference. It will take time and patience. Your car is white and you are going to paint it green. My steel flare GT project started life Palma green and I want to go white !!! You're doing a beautiful job. |
Mitox |
I have a question for those much more knowledgeable than I. While stripping the bottom of the 914, I noticed the lip around the inside of the GT flares. They are about 5/8" wide; this looks too wide. Does anyone know the correct width? I'm thinking about 3/8" would look OK. Yes, they are wide and irregular. I'm going to use a stock lip as a reference. It will take time and patience. Your car is white and you are going to paint it green. My steel flare GT project started life Palma green and I want to go white !!! You're doing a beautiful job. I still think about staying white. Guess I'll make the final decision a day before it gets painted. As for the fender lips, I'll find an older Porsche somewhere and measure it. |
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
My lovely wife is an x-NYWS stockbroker,m&a manager for a fortune 5 firm / and today sees the uptick in a 914 conversion project if properly undertaken. go. Now is the time.
I have converted 3.2 K 914 in AZ into a 60-+ asset in CA and not for sale.. It is a thing to do now.. but not for the faint of heart... (IMG:style_emoticons/default/WTF.gif) |
krazykonrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,144 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 ![]() |
[/quote] Signal orange is the awesome-est! ![]() My $0.02 |
Mitox |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
You've got emerald, viper, Conda and Zambezi green.
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,054 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Those appear to be Conda Green. L2626 is the code I think.
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
Bottom one looks like viper green.
jmill |
Some pics.
Attached thumbnail(s) ![]() ![]() Attached image(s) ![]() |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Viper Green is siiiiiiiiiick.
The #19 car color wins. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,987 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
The replica flares have more "flange" than the original factory GT flares. McMark clearances mine a bit to fit the rear tires. In the front, it's not a problem. I'll edit in a picture from my project thread in a minute or two...
Ok, here are before and after pictures of my rear flares. Before would tear up sidewalls. After? Just right! Attached image(s) ![]() ![]() |
Mitox |
The replica flares have more "flange" than the original factory GT flares. McMark clearances mine a bit to fit the rear tires. In the front, it's not a problem. I'll edit in a picture from my project thread in a minute or two... Ok, here are before and after pictures of my rear flares. Before would tear up sidewalls. After? Just right! Thanks, your "before" pic is exactly what my flares look like. At the top, yours now look like roughly 1/4" or maybe slightly more, so that works. I'm thinking I should trim the lip to about 3/8", and roll the top of the arch up. |
Mitox |
jmill |
Not really. I found it on Rennlist. Here's one that includes a description. I also included another pic with 2 colors side by side.
Looking at photos of Conda, Signal, Viper, Green, and Zambezi it's difficult to tell them apart unless they are side by side. Attached thumbnail(s) ![]() Attached image(s) ![]() |
Lo-Fi Version | Time is now: 12th April 2025 - 10:15 AM |
