DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,819 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
And - bottom coated with Raptor @Mitox what did you use to apply the Raptor to the outer floor pan? Phil |
Mitox |
Member ![]() ![]() Group: Members Posts: 416 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States ![]() ![]() |
And - bottom coated with Raptor @Mitox what did you use to apply the Raptor to the outer floor pan? Phil Late answer, sorry, just saw the question. I believe he used the simple sprayer typically used with the Bed liner kits. |
Mitox |
Mitox |
Mitox |
Mitox |
Mitox |
I have a question for anyone that can help. There is a seem on the back side of the sail panels where a small permanently mounted section of the engine cover is. Does it have sealer at the locations shown in this pick? (Not my car, but it shows the area well)
It’s been a few years since I stripped everything, so I can’t recall. ![]() |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,727 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
No sealer in the long seam from the factory. The area close to the glass is space for the rubber seal Both are difficult to 'flood' with paint. I've never seen rust jump out of that area in spite of how vulnerable it looks. |
Mitox |
No sealer in the long seam from the factory. The area close to the glass is space for the rubber seal Both are difficult to 'flood' with paint. I've never seen rust jump out of that area in spite of how vulnerable it looks. Thanks for the info. My vague memory is the same for the seam n the side , however I think I remember digging out seam sealer from the section just under the window. I’ve also looked through the part diagrams and can’t find a seal that would be in this location. Does anyone have a rubber seal in the section under the window? |
mate914 |
Matt ![]() ![]() ![]() Group: Members Posts: 828 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States ![]() ![]() |
rgalla9146 |
Mitox |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,766 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Just go with the last "GT"
Mitox |
Mitox |
East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
Nice! Gratifying to see some color on it, isn’t it….
Mitox |
Mitox |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,271 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Really coming along nicely. (IMG:style_emoticons/default/beerchug.gif)
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,939 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
I have a question for anyone that can help. There is a seem on the back side of the sail panels where a small permanently mounted section of the engine cover is. Does it have sealer at the locations shown in this pick? (Not my car, but it shows the area well) It’s been a few years since I stripped everything, so I can’t recall. ![]() ![]() |
Lo-Fi Version | Time is now: 4th April 2025 - 01:57 PM |
