Creamsicle New Zealand |
Member ![]() ![]() Group: Members Posts: 83 Joined: 5-February 15 From: New Zealand Member No.: 18,403 Region Association: Australia and New Zealand ![]() |
Hi all I have a question for the electrically minded amongst us. My car arrived with a 5 pin head light relay - one of the pins is not being used which is causing confusion and fog light operation issues, but the wiring diagram shows it should be a 4 pin relay so I will purchase a 4 pin relay.
My question is at what stage of the park/head light switching should the fog lights be able to be switched on? Thanks Steve |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Fog lights only come on with head lamps in the dim position. The new 5 pin relays need a jumper wire on the unused terminal. Jump wire# 56 to 30.
orbit398 |
Member ![]() ![]() Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region ![]() |
Hi all I have a question for the electrically minded amongst us. My car arrived with a 5 pin head light relay - one of the pins is not being used which is causing confusion and fog light operation issues, but the wiring diagram shows it should be a 4 pin relay so I will purchase a 4 pin relay. My question is at what stage of the park/head light switching should the fog lights be able to be switched on? Thanks Steve hope the attached helps Attached image(s) ![]() |
Fantastic just what I was after, both myself and my auto electrician couldn't work it out. Thanks for your help we can now move on to the next job on the list.
Cheers Steve |
Lo-Fi Version | Time is now: 26th June 2024 - 04:30 AM |
