MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
You said you took the carbs apart and cleaned them. Did you put kits in them? Are you setting them up for the first time? If you are setting them up for the first time it would help if they were freshly rebuilt and the float levels were set correctly.
Seems odd that you could have a rich condition with 50 idle jets especially on a 2.3. A 60 or a 65 idle jet would be my guess for that size engine. I am at 2500 ft of elevation and run a 60 idle on a 2056. When trying to find a vacuum leak I have had good luck using a spray bottle with water in it. Flood the areas around the base of the carbs and around the base of the manifolds and listen for a brief rpm change. Carb cleaner strips paint and makes a big mess...water does the same thing. |
Perry Kiehl Clone |
Unregistered ![]() |
I have also seen the air bypass and mixture screws swapped, and while they will interchange, the functions do not (IMG:style_emoticons/default/smile.gif)
cashiersjm |
Member ![]() Group: Members Posts: 40 Joined: 6-December 09 From: Cashiers, North Carolina Member No.: 11,100 Region Association: South East States ![]() ![]() |
Unfortunately work calls and I will be unable to work on the car until Saturday. I'm not beyond missing some item you've all suggested so I will recheck all that I can Saturday. Thanks for the input/suggestions and I'll get back later. Jim
Lo-Fi Version | Time is now: 26th June 2024 - 06:33 AM |
