911 Reflector, It dont fit |
DavidSweden |
Jul 10 2016, 11:42 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Thanks guys for the advice & comments.
I have gone off the idea of mounting on the car I will hang it on the garage wall, maybe put a LED behind it as suggested. |
Jul 10 2016, 12:16 PM
914-6 GT in waiting Group: Members Posts: 19,516 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Like I said, I get $300 for one in nice condition. In Sweden, you might get double that.
Chris914n6 |
Jul 11 2016, 06:18 PM
Jackstands are my life. Group: Members Posts: 3,393 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Cramped but shows 4 of the 6 ~1/2" holes needed to flush mount the 911 reflector.
(IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-431-1468282690.1.jpg) |
struckn |
Jul 11 2016, 07:11 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
David...why not hold on to it and buy a 911 that's missing one?
I have one on my 914 that the previous owner installed. I like the look! Makes the car look wider. Also, my '68 AMX has one too! Came from the factory that way. If you install your's you'll have to cut a whole out in the middle for the Trunk lock button, or wire up a solinoid to electrically unlatch the trunk latch. This would also involve adding a switch hidden some where to power the latch. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1468285872.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1468285872.2.jpg) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/slap.gif) |
DavidSweden |
Jul 12 2016, 04:14 AM
David...why not hold on to it and buy a 911 that's missing one? I have one on my 914 that the previous owner installed. I like the look! Makes the car look wider. Also, my '68 AMX has one too! Came from the factory that way. If you install your's you'll have to cut a whole out in the middle for the Trunk lock button, or wire up a solinoid to electrically unlatch the trunk latch. This would also involve adding a switch hidden some where to power the latch. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1468285872.1.jpg) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/slap.gif) It looks nice on your car, not sure if the reflector I have is as good, maybe i will reconsider mounting it. Just a bit worried when it comes to the solenoid, i dont want to end up with a failed solenoid and a permanently shut trunk. Regarding buying a 911, the prices in Sweden have gone through the roof so that a no go. i am however negotiating for a 6 engine 2,2 from 72 |
struckn |
Jul 12 2016, 07:10 AM
I have a mechanical back up release I made using a Steel wire like a coat hanger wire. I bent it to hook over the top of the solenoid and then turned it to exit the trunk directly below the latch assembly by drilling a small hole in the trunk floor for the steel wire to pass thru. I ran it about six inches down from the trunk floor and I can reach it easily from under the car, pull it down and the latch easily releases.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1468329034.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1468329460.1.jpg) |
Lo-Fi Version | Time is now: 26th September 2024 - 05:27 PM |
