Localboy808 |
Member ![]() ![]() Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None ![]() |
Hello everyone. My name is Scott and I've just checked off another box on my bucket list! I've purchased my first 914. I'm sure it's the fairly typical story. I've seen these cars since junior high and have always wanted one. I purchased a 72. Original color was blue. Looks like it's got one reaspray which is yellow. Unfortunately it's got a salvaged title. But I can see no signed of any prior collisions. In fact the body is very straight with only one section of bondo. Passenger side rear quarter just behind the door. But I can feel behind it and it's not bad. The rest of the car has zero rust! I mean zero. None in the trunk or any of the areas Ive read normally rust out.
Paid 4400 for it which was in my budget and thought it was a decent deal. Seats look good. Dash needs some love. Engine has a single carb and starts pretty much on the first crank. Pulls hard! Shifter is very stiff going through the gears. Hoping and guessing it's just dry or bushings. I'll have to research that here. Maybe it's a common problem. I'll post some pictures later. Just wanted to say hi. I've been around air cooled VWs all my life. Currently have a 66 crew cab. So this little 914 is going to be the sporty little toy for me and the wife. I'm going to need some parts. Want to do a full tune up on it. Appears it's been sitting awhile and sometimes dies at idle. Maybe a carb rebuild ect. Any suggestions on the best places for sourcing parts would be appreciated! Thanks, Scott ![]() ![]() |
daytona |
daytona ![]() ![]() Group: Members Posts: 438 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States ![]() |
Welcome to the 914 community.
I hope your 914 is everything and more than you hoped it would be. Enjoy your new project and keeps us posted the progress photos. |
Localboy808 |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Welcome,
Start checking the linkage, maybe something is wedged. Simply replacing the bushings will help. There may be something binding, but if you check each end you should find it. |
Localboy808 |
Welcome, Start checking the linkage, maybe something is wedged. Simply replacing the bushings will help. There may be something binding, but if you check each end you should find it. The linkage seems to be ok. It seems the tightness is coming from the trans itself. The arm that connects to the shift rod seems to be stiff. Other than that it's seems to shift through the gears fine. You just have to use a little more muscle to go through the gears. |
Mikey914 |
If is shifts, drive it. May just have a little crud from sitting. Check the fluid, and GO!
May just need to get some wear from usage to free it up. |
Localboy808 |
If is shifts, drive it. May just have a little crud from sitting. Check the fluid, and GO! May just need to get some wear from usage to free it up. That may be it. I suspect it was sitting for a time. Bought it at a dealer who has a partner that deals in exotics. He had a couple of 914s. But not sure. I'm just glad the body is so solid. Really no rust which I was shocked. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
(IMG:style_emoticons/default/welcome.png) I am sure you are going to be fine. BTW, post up some pics of the VW crew cab please.
Have fun and just take it one task at a time. Once these cars find a jack stand they seem to attach to them semi-permanently. |
whitetwinturbo |
Honey, does this wing make my ass look fat? ![]() ![]() ![]() Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California ![]() |
..........grab that guys yellow stripped jacket since it matches your banana paint job (IMG:style_emoticons/default/piratenanner.gif)
Localboy808 |
(IMG:style_emoticons/default/welcome.png) I am sure you are going to be fine. BTW, post up some pics of the VW crew cab please. Have fun and just take it one task at a time. Once these cars find a jack stand they seem to attach to them semi-permanently. I'm hoping to keep it off the jack stands as much as possible! (IMG:style_emoticons/default/driving.gif) Here you go! ![]() |
Cairo94507 |
Very Cool (IMG:style_emoticons/default/beerchug.gif)
jor |
Just happy to be here. ![]() ![]() Group: Members Posts: 183 Joined: 28-July 14 From: LA Member No.: 17,693 Region Association: Southern California ![]() |
Love the bus!
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Hey if you think it pulls hard with a single carb you will be thrilled when you get rid of it. Dual 40's will work great. Check your fuel lines, brake lines, then enjoy it. I agree, one task at a time. Drive it, drive it, drive it. LOVE your bus. You will fit right in here. |
blackmoon |
Member ![]() ![]() Group: Members Posts: 153 Joined: 27-May 08 From: Cal Bay Area Member No.: 9,106 Region Association: None ![]() |
(IMG:style_emoticons/default/welcome.png) Hey if you think it pulls hard with a single carb you will be thrilled when you get rid of it. Dual 40's will work great. Check your fuel lines, brake lines, then enjoy it. I agree, one task at a time. Drive it, drive it, drive it. LOVE your bus. You will fit right in here. (IMG:style_emoticons/default/agree.gif) |
Localboy808 |
Thanks everyone!
Lo-Fi Version | Time is now: 26th June 2024 - 05:01 AM |
