fuel pump relocation....Where? |
surfdogskier |
Jul 19 2016, 06:21 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Hey guys,
Got to play around with my 914 yesterday. With the help of my neighbor, we were able to figure some things out. The fuel pump is mounted in the wrong spot. Mine was the one that was zipped tied from a previous post. Really stupid. It should be mounted on the passenger side fender area under the car from what I can tell. However, those rubber mounts at hold the bracket on are broke. No way to attach it back. Pelican parts does not have these any more. Is it safe to install it in the engine compartment underneath the PCM or does this area get to hot? Any other places you guys would recommend? Thanks, Jason |
914_teener |
Jul 19 2016, 06:27 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Firewall underneath on the passenger side. Perfect location.
There are a few threads on the subject. |
rhodyguy |
Jul 19 2016, 06:32 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Definitely NOT in the engine compartment.
Tom_T |
Jul 19 2016, 06:33 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Hey Jason,
Do yourself a favor now, & just do the factory service bulletin's relocation of the FP to the front up behind the steering rack cover & below the fuel tank to the passenger side of where the fuel lines exit the center tunnel on the FRONT trunk firewall, so you can avoid the hot start/vapor lock problem. Auto Atlanta sells the kit including rubber isolator mounts. Do a search for topics, as it's already been discussed on here several times this hot season ... as it is repeatedly every year. Search or Google is your freind! (IMG:style_emoticons/default/smile.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Mark Henry |
Jul 19 2016, 06:54 PM
You can get the pump isolators from aircooled.net or most AC VW shops.
surfdogskier |
Jul 19 2016, 06:55 PM
Thanks guys! I will definitely look into the relocation in the front.
surfdogskier |
Jul 19 2016, 07:16 PM
Went to AutoAtlanta.com and they had it for 50% off. Thanks again!
zambezi |
Jul 19 2016, 10:24 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
UH-OH
Elliot Cannon |
Jul 19 2016, 11:09 PM
Definitely NOT in the engine compartment. My pump has been in the engine compartment to 14 years. Hasn't been a problem. (IMG:style_emoticons/default/biggrin.gif) |
JawjaPorsche |
Jul 20 2016, 03:56 AM
This has been debated many times on this forum. Front or Back. Both are okay. Back on Firewall is much easier and faster to do.
Located mine twenty years ago on firewall with no problems. Vapor problem gone! Much easier to change fuel filter too. Attached image(s) |
rhodyguy |
Jul 20 2016, 06:55 AM
Elliot, you're saying the FP in the yellow 6 was in the engine compartment?
napasteve |
Jul 20 2016, 07:54 AM
914 driving winemaker Group: Members Posts: 510 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
JeffBowlsby |
Jul 20 2016, 08:28 AM
914 Wiring Harnesses Group: Members Posts: 8,784 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
There was an October 1973 factory service bulletin (#213) on this subject, but it did not recommend relocating the FP. It was about redirecting hot air away from the pump area and insulating the fuel lines (with asbestos cloth!!!).
http://bowlsby.net/914/Classic/zSB_1973-10-06_P213.pdf Note that the bulletin was issued near the beginning of 1974 model year production. It was not until the 1975 model year that the FP was relocated to the under fuel tank location. |
napasteve |
Jul 20 2016, 08:58 AM
Jeff, I would have been happy to leave the fuel pump in its original position but this was not possible if you switch to a 2-port pump (as shown in Jawja and my pictures). And lack of availability of the original 3-port pumps forces the switch to the 2-port pump and I'm not aware of a 2-port pump with both ports on one end like the 3-port configuration. Do you know of such a 2-port pump?
914_teener |
Jul 20 2016, 09:13 AM
Both pictures show a two port fuel pump and mounted on the rear fire wall. I have had mine there for 7 years and driven in over 110 degree heat and no issues.
It is less work to locate it there than underneath the rack cover IMHO. I mounted mine with riv nuts and the stock hardware. Your choice. |
JeffBowlsby |
Jul 20 2016, 10:28 AM
worn |
Jul 20 2016, 02:42 PM
can't remember Group: Members Posts: 3,376 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
There was an October 1973 factory service bulletin (#213) on this subject, but it did not recommend relocating the FP. It was about redirecting hot air away from the pump area and insulating the fuel lines (with asbestos cloth!!!). http://bowlsby.net/914/Classic/zSB_1973-10-06_P213.pdf Note that the bulletin was issued near the beginning of 1974 model year production. It was not until the 1975 model year that the FP was relocated to the under fuel tank location. Maybe you can help me source the NOS asbestos! Sweet sweet asbestos. I can quit anytime I want. |
ClayPerrine |
Jul 20 2016, 08:26 PM
Life's been good to me so far..... Group: Admin Posts: 15,964 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Jeff, I would have been happy to leave the fuel pump in its original position but this was not possible if you switch to a 2-port pump (as shown in Jawja and my pictures). And lack of availability of the original 3-port pumps forces the switch to the 2-port pump and I'm not aware of a 2-port pump with both ports on one end like the 3-port configuration. Do you know of such a 2-port pump? Airtex part number E8445 is an aftermarket 2 port pump that provides the same pressure and volume as the stock 3 port pump. I have been running one on Betty's car for about 6 years now with absolutely no issues. |
napasteve |
Jul 22 2016, 07:49 PM
Clay, is Betty's car running the stock FI?
I just installed a Bosch 69133 that I bought from Amazon but they don't seem to have them anymore. Your Airtex seems to be a good alternative. |
Elliot Cannon |
Jul 22 2016, 08:45 PM
Elliot, you're saying the FP in the yellow 6 was in the engine compartment? I sold the yellow six years ago. I'm talking about this used to be yellow type four. (IMG:style_emoticons/default/biggrin.gif) You can just see the pump and filter at the bottom of the picture. I will NOT argue this subject. I'm just saying that it has worked for me for a long time. Attached image(s) |
Lo-Fi Version | Time is now: 3rd January 2025 - 09:37 PM |
