first 25 kamman porsche chassies, very early 914-6 where did they go to |
twash |
Aug 25 2016, 06:20 PM
Member Group: Members Posts: 63 Joined: 16-October 04 From: camarillo calif Member No.: 2,960 |
kamman produced 25 chassis for Porsche in 1969
Some of the chassis are kamman 0010,0011,0012,used in preproduction/ test cars/show cars #0011 and #0012. both 914-6 as #0011 & #0012 both made with euro spec. cars (00#36 engine case). Both cars sold as ( for off road use in usa) by porsche. Both 914-8's Porsche used the chassis's from the production run from kamman, not shur where the other bodies went or what is left of these cars. You can tell the difference as the front fenders ( no rubber in fender & body area , fill in solid area next to door jam, fenders used only on the first 52 cars produced . info provide from memory, please chime in if there is more info available |
Aug 25 2016, 08:22 PM
Resident German Group: Admin Posts: 41,937 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
kamman produced 25 chassis for Porsche in 1969 Not quite ... Info straight from the historic archives at Karmann: - 20 prototypes built in 1968 and delivered to Porsche between 03/07/68 and 12/17/68 - 48 /4 prototypes built in 1969 (IMG:style_emoticons/default/shades.gif) |
arkitect |
Aug 25 2016, 10:00 PM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
SirAndy = the man with tons of teener knowledge
Dave |
Aug 25 2016, 11:25 PM
Both 914-8's Porsche used the chassis's from the production run from kamman Nope, both 914-8 were built on prototype chassis, not production. At least 4 of the prototype cars survived the crusher: http://www.914world.com/specs/prototypes.php (IMG:style_emoticons/default/smile.gif) |
gms |
Aug 26 2016, 06:49 AM
Advanced Member Group: Members Posts: 2,707 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
kamman produced 25 chassis for Porsche in 1969 Some of the chassis are kamman 0010,0011,0012,used in preproduction/ test cars/show cars #0011 and #0012. both 914-6 as #0011 & #0012 both made with euro spec. cars (00#36 engine case). Both cars sold as ( for off road use in usa) by porsche. Both 914-8's Porsche used the chassis's from the production run from kamman, not shur where the other bodies went or what is left of these cars. You can tell the difference as the front fenders ( no rubber in fender & body area , fill in solid area next to door jam, fenders used only on the first 52 cars produced . info provide from memory, please chime in if there is more info available According to Porsche production started at 914.043.0011 not 914.043.0010. |
twash |
Aug 26 2016, 08:48 AM
kamman produced 25 chassis for Porsche in 1969 Some of the chassis are kamman 0010,0011,0012,used in preproduction/ test cars/show cars #0011 and #0012. both 914-6 as #0011 & #0012 both made with euro spec. cars (00#36 engine case). Both cars sold as ( for off road use in usa) by porsche. Both 914-8's Porsche used the chassis's from the production run from kamman, not shur where the other bodies went or what is left of these cars. You can tell the difference as the front fenders ( no rubber in fender & body area , fill in solid area next to door jam, fenders used only on the first 52 cars produced . info provide from memory, please chime in if there is more info available According to Porsche production started at 914.043.0011 not 914.043.0010. 0011 was an development model for work load assembly( how many people does it take to build the car, this is the reason the car was the only one made with a full set of matching #'s on body engine and trans. making this car unique ). Porsche also state's and glen's has paper work that's says 0012 was an engineering/ test car and both are production cars, as it is Porsche practice also used in the 930. . if you compare 914-8 bodies to the 0011 and 0012 you can see the same metal work. front fire wall, rear bumper rubber that was to mount to the body not the bumper, but the holes are there. |
twash |
Aug 26 2016, 08:57 AM
great fact's on the 914-6 early cars are coming out, keep up the good work. some of the early cars were redone as gt's, and helped development .
would like to know #'s of first 52 cars that are still out there, are the very early cars ( PROTYPE CARS) still around or are they rusting away |
Lo-Fi Version | Time is now: 22nd December 2024 - 12:15 AM |
