1974 2.0 L Charcoal Canister |
Rsjg911 |
Aug 26 2016, 10:02 AM
Member Group: Members Posts: 89 Joined: 13-June 16 From: Weston, Florida Member No.: 20,105 Region Association: South East States |
Hi All:
I have some gas smell in my garage after I park the car. I don't see any gas leaking and thought it might be the gas cap gasket or charcoal canister or lines to the canister. The injector seem fine. The car is a 1974 2.0 L. Two questions: Any recommendations where I can source a NOS or high quality charcoal canister and required lines ? Am I missing something as to the gas smell? Thanks! Ron |
dflesburg |
Aug 26 2016, 10:05 AM
Senior Member Group: Members Posts: 1,719 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
if you really want to there was a thread on the bird about how to rebuild one.
Rsjg911 |
Aug 26 2016, 10:22 AM
boxsterfan |
Aug 26 2016, 10:23 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
I had similar smell. There is a gasket under the fuel filler neck and a gasket under the sending unit that I replaced (you can get these rubber gaskets from 914rubber.com). These seems to fix the smell for me.
As referenced, there is an article on how to refill the cannister (get activated charcoal from a local pet store.) Also note that I replaced every single vacuum line up there (and in the engine bay). Finally, if you still have smell, you may have a leak underneath at the fuel lines and/or you may have a pinhole leak in the tank itself. For example on the pinhole leak, if the hole was halfway up the tank and you would smell gas more readily after filling up.. |
boxsterfan |
Aug 26 2016, 10:27 AM
Rsjg911 |
Aug 26 2016, 02:20 PM
Thanks folks. All good info.
Does anyone know where to source NOS or aftermarket charcoal canisters? |
boxsterfan |
Aug 26 2016, 02:38 PM
Thanks folks. All good info. Does anyone know where to source NOS or aftermarket charcoal canisters? I didn't think they were made anymore? You could check a local VW Parts shop. Or put up a WTB in the classifieds. Part# is 113 201 813B I think. Otherwise, if you can get a hold of some activated charcoal (about 2lbs) from a pet store (or amazon), you can do the replenishing job yourself in about 30 minutes. |
boxsterfan |
Aug 26 2016, 02:42 PM
Here's a nice used one for $75 if you have money burning a hole in your pocket.
http://www.ebay.com/itm/VERY-NICE-USED-ORI...JZ2&vxp=mtr Here is another: http://www.ebay.com/itm/VERY-NICE-USED-ORI...%3D281686247096 Note the second one is from earlier years. It is much more difficult to refill because you have to drill holes. The first one you can simply take apart (carefully). |
boxsterfan |
Aug 26 2016, 02:47 PM
Hmmmm....maybe they are still made?
http://www.porschepartssuperstore.com/prod...3-201-801-b.htm Says part number has change to: http://www.porschepartssuperstore.com/Prod...e=1H0-201-801-C ($110!!!!!) |
Rsjg911 |
Aug 26 2016, 02:50 PM
Hi Bixterfan:
Yes, I saw those on EBay but figured they are spent by now. I am considering rebuilding my current fliter but wanted to "put it out there" first for a NOS or good aftermarket source in case someone had one. Thanks! Ron |
rhodyguy |
Aug 26 2016, 05:38 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If you redo yours, get the charcoal in the pellet type. Not the aquarium chunk. When I bought some sourced thru Amazon it was pretty cheap.
Aug 26 2016, 08:35 PM
74 was a transition year; the earlier 74s had the two vacuum lines running along the driver's side rocker and the canister was on top of the fuel tank, while the later ones had the single small line through the center tunnel and the canister was in the engine bay.
Double-check which you have; it would be easiest to put the system back to how it originally was. --DD |
Rsjg911 |
Aug 26 2016, 09:33 PM
74 was a transition year; the earlier 74s had the two vacuum lines running along the driver's side rocker and the canister was on top of the fuel tank, while the later ones had the single small line through the center tunnel and the canister was in the engine bay. Double-check which you have; it would be easiest to put the system back to how it originally was. --DD Thanks Dave. My car was manufactured 10/73 (it's a 1974) and the plastic canister is in the frunk in front of the driver, not on top of the fuel tank. It has 2 lines on one end, 1 on the other. Part #113 201 823A on one side, #113 201 813 on the otger. Ron |
Amphicar770 |
Aug 27 2016, 08:28 AM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Here is link to charcoal pellets. This bag is just the right size.
https://www.amazon.com/Acurel-LLC-Economy-A...s/dp/B000YIWT0M That said, I doubt this is source of fuel smell. Probably time to pull the tank / replace lines and hoses. |
rhodyguy |
Aug 27 2016, 08:42 AM
That be the product.
Rsjg911 |
Aug 27 2016, 09:13 AM
Here is link to charcoal pellets. This bag is just the right size. https://www.amazon.com/Acurel-LLC-Economy-A...s/dp/B000YIWT0M That said, I doubt this is source of fuel smell. Probably time to pull the tank / replace lines and hoses. Thanks Amphicar! I'll get some. What part of PA are you from? I grew up in Pgh. Ron |
Aug 27 2016, 02:28 PM
... the plastic canister is in the frunk in front of the driver, not on top of the fuel tank. If you're saying that it is in front of the bulkhead and is in the trunk proper, it has been moved. It should be on top of the tank. Here is a pic of the early-style location: (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-121-1472329684.1.jpg) You can see it between the fuel tank's evap chamber and the brake fluid reservoir. Black with a silver band around it. --DD |
Rsjg911 |
Aug 27 2016, 03:56 PM
... the plastic canister is in the frunk in front of the driver, not on top of the fuel tank. If you're saying that it is in front of the bulkhead and is in the trunk proper, it has been moved. It should be on top of the tank. Here is a pic of the early-style location: (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-121-1472329684.1.jpg) You can see it between the fuel tank's evap chamber and the brake fluid reservoir. Black with a silver band around it. --DD No Dave, my mistake. It IS on top of the gas tank exactly where yous is located in the picture. Sorry. Ron |
carcus |
Aug 28 2016, 11:34 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Great post and great info. Thanks!!!!
pbanders |
Oct 16 2016, 07:34 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Great thread and question: suggestions on how to open the early (1970) metal canisters so that you can recharge them, without destroying the canister?
Lo-Fi Version | Time is now: 28th April 2024 - 08:57 AM |
