911 Ignition Switch, What is this hole for ? |
jim_hoyland |
Aug 30 2016, 11:46 AM
Get that VIN ? Group: Members Posts: 9,263 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The left side of the ignition switch has a threaded hole; what isi it for ?
7TPorsh |
Aug 30 2016, 12:35 PM
Steering lock?
Aug 30 2016, 01:16 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Steering lock? No, the steering lock is at the end of the long shaft. (IMG:style_emoticons/default/shades.gif) My 911 switch didn't have that hole, what year/car is your switch from? (IMG:style_emoticons/default/idea.gif) |
jcd914 |
Aug 30 2016, 01:26 PM
Later 911s 1996 - on (maybe earlier not sure) Porsche added a key lock for car with automatic transmissions. It prevents you from removing the key unless the shifter is in Park. The cable from the shifter screws into the ignition lock at that threaded hole.
Jim |
jim_hoyland |
Aug 30 2016, 01:34 PM
Later 911s 1996 - on (maybe earlier not sure) Porsche added a key lock for car with automatic transmissions. It prevents you from removing the key unless the shifter is in Park. The cable from the shifter screws into the ignition lock at that threaded hole. Jim Makes sense; when I turn the key to the off position, I can see something move at the back of the hole. Thanks for the info. The switch is from the 964 model..... |
rgalla9146 |
Aug 30 2016, 05:29 PM
Later 911s 1996 - on (maybe earlier not sure) Porsche added a key lock for car with automatic transmissions. It prevents you from removing the key unless the shifter is in Park. The cable from the shifter screws into the ignition lock at that threaded hole. Jim Makes sense; when I turn the key to the off position, I can see something move at the back of the hole. Thanks for the info. The switch is from the 964 model..... The 964 part number is certainly a big clue. Never touched one that new. Would probably work in a 6 conversion. Get the switch and plug that go with it. |
jim_hoyland |
Aug 30 2016, 06:38 PM
Later 911s 1996 - on (maybe earlier not sure) Porsche added a key lock for car with automatic transmissions. It prevents you from removing the key unless the shifter is in Park. The cable from the shifter screws into the ignition lock at that threaded hole. Jim Makes sense; when I turn the key to the off position, I can see something move at the back of the hole. Thanks for the info. The switch is from the 964 model..... The 964 part number is certainly a big clue. Never touched one that new. Would probably work in a 6 conversion. Get the switch and plug that go with it. It came complete; right now I'm looking at fitment without doing major changes. I studied Sir Andys thread and would like to install the switch without all the other mods he did |
Aug 30 2016, 07:37 PM
Later 911s 1996 - on (maybe earlier not sure) Porsche added a key lock for car with automatic transmissions. It prevents you from removing the key unless the shifter is in Park. The cable from the shifter screws into the ignition lock at that threaded hole. Jim Makes sense; when I turn the key to the off position, I can see something move at the back of the hole. Thanks for the info. The switch is from the 964 model..... The 964 part number is certainly a big clue. Never touched one that new. Would probably work in a 6 conversion. Get the switch and plug that go with it. It came complete; right now I'm looking at fitment without doing major changes. I studied Sir Andys thread and would like to install the switch without all the other mods he did I don't think that's possible, at least not with out major fab. Our 914 column's are not set up to take a 911 switch. If it was, the whole 914-6 conversion would be much easier. |
jim_hoyland |
Aug 30 2016, 07:55 PM
QUOTE ] I don't think that's possible, at least not with out major fab. Our 914 column's are not set up to take a 911 switch. If it was, the whole 914-6 conversion would be much easier. You think my best 2nd option is to cut the "arm" off ? NARO did it that way; but I would prefer to not cut it. A non-working lock would be ok. And, I contacted the guy you referred me to, Tom Butler, he had the full conversion parts. Still kicking around that path, concerned I could get in over my head. |
Eric_Shea |
Aug 31 2016, 07:18 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Jeff Hines had a pretty easy solution Jim. Maybe do a search here with "sixnotfour" as the member and +911 +ignition +switch as the search string.
jim_hoyland |
Aug 31 2016, 09:20 PM
Jeff Hines had a pretty easy solution Jim. Maybe do a search here with "sixnotfour" as the member and +911 +ignition +switch as the search string. Thanks; looks very interesting and probably the easiest option so far Attached image(s) |
theleschyouknow |
Aug 31 2016, 10:54 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
wow did that search work for you?
I tried on the site and via Google and didn't turn anything up (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/beerchug.gif) cjl |
Steve |
Sep 1 2016, 12:50 AM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
This is all I could find regarding cutting the 911 ignition switch and cuttng off the 914-4 switch.
http://www.914world.com/bbs2/index.php?sho...43875&st=20 |
jim_hoyland |
Sep 1 2016, 05:54 AM
This is all I could find regarding cutting the 911 ignition switch and cuttng off the 914-4 switch. http://www.914world.com/bbs2/index.php?sho...43875&st=20 That's got some good pics, thanks for posting the link. I'm curious whether the complete switch could be mounted but not have a working steering wheel lock; such that the steering column, and turn signal/wipers switches would not have to be changed ?? |
Steve |
Sep 1 2016, 07:25 AM
According to the thread Naro914 cut the locking part of the 911 ignition switch off. He also cutoff the 914 switch and welded up the hole. The 75 has a plastic housing. I don't know if that would help or make it harder to close up. I have a 73 metal housing. I could bring it this Saturday to compare the two.
Sep 1 2016, 07:45 AM
QUOTE ] I don't think that's possible, at least not with out major fab. Our 914 column's are not set up to take a 911 switch. If it was, the whole 914-6 conversion would be much easier. You think my best 2nd option is to cut the "arm" off ? NARO did it that way; but I would prefer to not cut it. A non-working lock would be ok. And, I contacted the guy you referred me to, Tom Butler, he had the full conversion parts. Still kicking around that path, concerned I could get in over my head. Tom is a good guy. I've bought a good amount of parts from him. |
jim_hoyland |
Sep 1 2016, 09:31 AM
According to the thread Naro914 cut the locking part of the 911 ignition switch off. He also cutoff the 914 switch and welded up the hole. The 75 has a plastic housing. I don't know if that would help or make it harder to close up. I have a 73 metal housing. I could bring it this Saturday to compare the two. Great, I'd like to see it; this maybe comeing together. Thanks all for all the input, it's a big help |
John |
Sep 2 2016, 01:24 PM
I fabbed a small sheet metal box when I did my car.
I made my steering column from a 1973 911 part and welded wings on it to match my 1974 Chassis then plated it. My steering column locking mechanism as well as all of the switches work as designed. |
jim_hoyland |
Sep 2 2016, 05:15 PM
I fabbed a small sheet metal box when I did my car. I made my steering column from a 1973 911 part and welded wings on it to match my 1974 Chassis then plated it. My steering column locking mechanism as well as all of the switches work as designed. Really nice professional looking job ! (IMG:style_emoticons/default/smile.gif) Does the steering column use the original shaft ? Are the 911 and 914 shafts splined alike ? If different, what mods are required.... |
Sep 2 2016, 07:21 PM
I fabbed a small sheet metal box when I did my car. I made my steering column from a 1973 911 part and welded wings on it to match my 1974 Chassis then plated it. My steering column locking mechanism as well as all of the switches work as designed. Really nice professional looking job ! (IMG:style_emoticons/default/smile.gif) Does the steering column use the original shaft ? Are the 911 and 914 shafts splined alike ? If different, what mods are required.... 911 & 914 have the same spline. If you are using a 911 steering shaft it would be best to use a wheel from a 70 or 77, 914. No mods required. The later wheels require a small mod and the fit is ok but not perfect because of a chamfered shaft vs flat. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:34 PM |
